Subject: Re: A kind of revolution is happening in the United States
Date: 15 Apr 2011 23:52:38
Message: <4da91286$1@news.povray.org>
On 4/15/2011 20:05, Patrick Elliott wrote:
> There is a battery for small devices in the works that "does" that. The
> problem, in most cases, is that its not the radiation that is used, its the
> heat. That is why the reactors are made the way they are.
You can do it for small stuff with thermocouples. That's what's running
things like the voyager space ships. Stick a lump of uranium next to two
different types of metal pressed together, and bingo instant current. But it
only generates a couple of watts that way.
"Coding without comments is like
driving without turn signals."
Date: 16 Apr 2011 06:09:08
Message: <4da96ac4$1@news.povray.org>
On 15/04/2011 07:24 PM, Darren New wrote:
> On 4/15/2011 10:00, Orchid XP v8 wrote:
>> If it's so simple and easy, why isn't everyone doing it?
> Hey, 3GHz 4-core processors only cost like $200. Why didn't we have
> those back in the original PC?
I've often wondered about this. Why did people design a 33MHz CPU, and
then a 66MHz one, and then 100MHz, and so forth? Why didn't they just go
straight to 4GHz?
> The longer the half life, the less radiation is being emitted per pound
> of material. That just falls out of the definition of half life.
So the radiation is actually *caused by* the substance decaying?
http://blog.orphi.me.uk/
Date: 16 Apr 2011 06:10:47
Message: <4da96b27@news.povray.org>
>> I *would* be surprised if you can make a car that can withstand a 100MPH
>> crash. :-P
> Yet again, reading comprehension is low. ;-) I didn't say anything about
> the *car* surviving the crash.
Designing it so the car doesn't survive the crash but the people inside
do would be even more miraculous...
> It's pretty commonly understood, and really not at all difficult to
> prove, considering you can go out and buy one of those cars and plug it
> in to see. It's hard to have controversial statements about things like
> "how much does gasoline cost?" or "how much electricity does this
> commercially-available consumer product use?"
It's news to me that anybody is producing electric cars yet. I'm aware
that they've been producing proof-of-concept designs for decades. But I
didn't think any of this stuff had reached the shops yet.
Date: 16 Apr 2011 06:18:03
Message: <4da96cdb$1@news.povray.org>
Le 16/04/2011 12:09, Orchid XP v8 nous fit lire :
Indeed.
When the atom splits (a bit of paradox for the greek atom), it results
in two or more atoms and radiation (alpha, beta or/and gamma).
(as well as heat)
radiation alpha, beta & gamma are in fact: photon, electron or positron
and helium nucleus (in opposite order, gamma is a photon, alpha is helium)
There is also neutron radiation.
Radiation can be spontaneous (hence the half-life) or generated by a
collision with another atom/particule/radiation.
Date: 16 Apr 2011 08:44:13
Message: <4da98f1d@news.povray.org>
Jim Henderson <nos### [at] nospam com> wrote:
> On Thu, 14 Apr 2011 15:04:11 -0400, Warp wrote:
> >> A solution to global warming? No. A solution to running out of oil?
> >> Quite possibly. A solution to having a power generation technology
> >> that a poor uneducated population can use without fear of actually
> >> killing people on the other side of the world when they screw up? Sure.
> > Burning coal is only a temporary solution, and a bad one.
> I'd have to agree with Darren here, it may be a bad solution, but unless
> there is another solution, the alternative is "well, it sucks to be you
> since you won't have power - deal with it."
The problem is that if poor countries started increasing their burning
of fossil fuels significantly, *the entire world* would suffer from it,
not just them.
So if it sucks, then it sucks.
Date: 16 Apr 2011 09:14:34
Message: <4da9963a@news.povray.org>
Invisible <voi### [at] dev null> wrote:
> And the alternative is...? What exactly?
You don't need to throw out current power generation technologies and
come up with something new in order to significantly reduce pollution.
Not all developed countries pollute even nearly as much as eg. the US,
Greece or China (not even if you scale it per capita).
Finland is a pretty developed country, with a pretty advanced industry
and high living standards, yet Finland is on the lower end of the pollution
scale. (The same is true for many other European countries, especially the
northern ones.) The trick is to produce and use energy more smartly.
For example, in China the most common way to heating homes is to burn
coal on each building. (For example this is extremely common in Beijin,
and not surprisingly Beijing is one of the most polluted cities in the
world.) In many other countries homes are heated using electricity, which
is extremely wasteful.
Not so in Finland. The heating of homes in cities is centralized (iow.
so-called district heating). It basically works by having central heating
plants which heat water, which is then transported via tubes to homes.
(The water is then run through radiators.)
There are efficient, low-polluting ways to heat the water (such as using
geotermal heating), but even if more polluting methods are used, reducing
the pollution (by using filters etc.) is easier, more efficient and cheaper
when this is centralized, reducing the total amount of pollution.
Automobiles can be made less polluting via legislation (for example by
demanding the installation of catalytic converters, and overall defining
a maximum allowed amount of pollution for each car, such as is the the
case in Finland).
Improving public transportation to reduce the need for private cars is
another efficient way to reduce pollution.
If every country in the world used the same ecologic techniques as the
best ones, the amount of pollution in the world would be significantly
lowered.
Date: 16 Apr 2011 09:22:46
Message: <4da99825@news.povray.org>
Darren New <dne### [at] san rr com> wrote:
> On 4/14/2011 11:55, Warp wrote:
> > I don't understand how it can be legal to expel someone for the sole
> > reason of wearing a t-shirt that says you're an atheist.
> The authorities treated it the same as someone wearing a shirt that said
> "nigger" on it or something. Basically, it was insulting and harassing the
> people who aren't atheists. They treated it the same way as they would have
> treated someone religious preaching at you during class.
Seems that the authorities there have a rather poor understanding of
their own constitution. (Perhaps it's a case of tl;dr.)
Date: 16 Apr 2011 11:58:20
Message: <4da9bc9c$1@news.povray.org>
> not just them.
This is true. What's the alternative?
The argument I've heard usually goes along the lines of "get them rich
enough that pollution, rather than starvation, is what they're worried about."
Date: 16 Apr 2011 12:06:28
Message: <4da9be84@news.povray.org>
On 4/16/2011 3:11, Orchid XP v8 wrote:
> Designing it so the car doesn't survive the crash but the people inside do
http://www.youtube.com/watch?v=fEBQ399k3aU
He broke a le:
http://www.youtube.com/watch?v=BJfQ-5pYjJQ&NR=1
Date: 16 Apr 2011 13:23:19
Message: <4da9d087$1@news.povray.org>
LMGTFY.
Date: 16 Apr 2011 13:30:33
Message: <4da9d239@news.povray.org>
This works when things are planned out in advance. In the USA, most college
campuses, apartment complexes, business parks, etc work this way. (And use
chilled water for cooling.) When you build things a little at a time (like,
a few hundred houses in an area every year for 15 years), I imagine making
this work out would be more difficult, planning-wise.
I'm pretty sure that California was the leader in this to the point where
everyone else (at least in the USA) adopted the same standards, just because
it was easier.
I'd certainly prefer public transportation to work well. Distances in the
USA aren't always conducive to that. Figuring out a way to make public
transit profitable and feasible using existing infrastructure would be
great. (Like, one idea I saw is that you run essentially trains along the
highways every 10 minutes or so, and have spots where people can drive
motorcycle-sized cars up on to the flat-bed for the long part of the
commute, but still get where they're going at the end without having to
build a public transit stop every 2 blocks. The USA tends to be much more
spread out than most of Europe that I've seen.)
> lowered.
And it still wouldn't matter, because in 50 years we'll have 3x the population.
Date: 16 Apr 2011 13:31:35
Message: <4da9d277$1@news.povray.org>
No, the authorities just *disagreed* with it and decided to be a PITA about
it in spite of knowing it's wrong. That's exactly why we have the
constitution: to reign in people like that. :-)
Date: 16 Apr 2011 13:42:05
Message: <4da9d4ed$1@news.povray.org>
See, now, where I live, the government thinks that making private
transport too expensive will make everybody use public transport.
This is absurd, of course. The way to make people use public transport
is to make it ACTUALLY FRICKING WORK.
I still remember visiting my sister in Manchester one time. I was amazed
when we just wandered up to the nearest bus stop, stood there for about
2 minutes, and a bus arrived. If you did that in my town, you might
stand there for *days* and never see a bus!
Date: 16 Apr 2011 13:45:05
Message: <4da9d5a1@news.povray.org>
On Fri, 15 Apr 2011 14:04:56 -0400, Jim Henderson wrote:
> On Fri, 15 Apr 2011 18:48:14 +0100, Orchid XP v8 wrote:
>>>>> Which tells you that it isn't *that* dangerous or there wouldn't be
>>>>> any life in the ground.
>>>> It's also an extremely rare element. Not like a reactor core, which
>>>> is make out of pure Uranium...
>>> A reactor core is NEVER "pure uranium".
>> It's far nearer to being pure than anything in nature.
> Would you like me to have a bona-fide nuclear physicist refute this? I
> have a very close friend who has a doctorate in nuclear physics (and two
> others who hold advanced degrees, one doctorate and one masters), and
> after he stopped laughing, I'm sure he'd be more than happy to give you
> all the nitty-gritty details about what is wrong about that statement.
Here's what he had to say:
--- snip ---
It depends on the type of reactor and the fuel composition differs
between them. But generally they are not of "pure" Uranium but often
a mix but with a HIGH U content - most of the reason is that the
"unpureness" gives you a higher melting point and is a little
"safer."
Here is a good article about the different fuel types:
http://en.wikipedia.org/wiki/Nuclear_fuel
--- snip ---
Jim
Date: 16 Apr 2011 14:06:38
Message: <4da9daae$1@news.povray.org>
>> >> Sure.
>> unless there is another solution, the alternative is "well, it sucks to
>> be you since you won't have power - deal with it."
> not just them.
I don't disagree with you, Warp, but unfortunately there are those who
have power who think what happens in other countries doesn't matter. *I*
am not one of those people, and I wish those who are would pull their
heads out.
Jim
Date: 16 Apr 2011 14:08:44
Message: <4da9db2c$1@news.povray.org>
> straight to 4GHz?
Because they didn't have the technology.
Jim
Date: 16 Apr 2011 14:11:48
Message: <4da9dbe4@news.povray.org>
You've never seen a car crash (or the results of one), have you? Most of
them are *designed* to crumple in order to protect the passengers.
My father-in-law and brother-in-law used to operate an auto body shop.
Most of them are hybrid petrol/electric vehicles, but there are a few
production models. You just need to look at the stuff on The Register
(where I've read about a few as recently as *yesterday*).
Jim
Date: 16 Apr 2011 14:31:33
Message: <4da9e085@news.povray.org>
> straight to 4GHz?
Exactly.
When an uranium nucleus emits an alpha particle, it's no longer uranium
as it just lost 2 protons and 2 neutrons to become thorium. That thorium
will, in turn also deckay into radium, then radon, polonium and finaly
into lead.
This is the alpha deckay of uranium. Plutonium can alpha deckay into
uranium.
The beta radiation is usualy caused when an extra neutron mutate into a
proton. The electron is emited to maintain the electrical balance.
The beta deckay of uranium 238 transforms the uranium into neptunium 238
that further deckay into plutonium 238 in a second beta event.
Date: 16 Apr 2011 15:02:14
Message: <4da9e7b6@news.povray.org>
Le 2011/04/15 22:53, Patrick Elliott a écrit :
> On 4/15/2011 5:26 AM, Bill Pragnell wrote:
>> Invisible<voi### [at] dev null> wrote:
>>> Nuclear power works in theory. In practise, if you make even the tiniest
>>> mistake, just once, everything is ruined forever. (Or at least, for
>>> several centuries.) And there's nothing you can do to fix it.
>> That's not really true. Chernobyl was caused by a very long chain of
>> mistakes,
>> all committed with a reactor design which was already itself a long
>> chain of
>> mistakes. It should be noted that most other countries have never built a
>> reactor that could fail as catastrophically as this, even through wilful
>> sabotage.
>> TMI was also long chain of mistakes, which resulted in only the
>> reactor being
>> ruined, and they did fix it.
>> I suppose you could say that Fukushima was really only one very big
>> mistake,
>> i.e. how big a tsunami was ever likely to be. However, they show every
>> sign of
>> being able to fix it eventually.
> No, the "big" mistakes where:
> 1. Having no way to cool it, or certainty that the power systems would
> still work, to do so, if enough failures happened. And, no, battery
> backup doesn't work, if it lasts less than 24 hours.
> 2. Placing the old, spent, fuel in something that was ever *less*
> effectively cooled.
> And, I would add 3. Presuming that a *big* reactor, which produces
> massive amounts of power, but where it would be nearly impossible to
> either make it less hazardous, or run battery backup long enough, or
> otherwise create a system that *could* compensate for major problems,
> remains bloody stupid.
Some more gross mistakes at Fukushima:
a. Need *EXTERIOR* power source to run the cooling system when you
produce that power localy.
The pumps failed when the power lines TO the reactor got damaged by the
tsunami. That's a humongously huge mistake!
b. NO passive shutdown mechanism. Sanity *demands* that there are
several controll rods suspended by electro magnets powered by the
reactor itself over the core. If the cooling system fails, the turbines
stop, they no longer produce current, shutting down the magnets whitch
let the controll rods fall into the core, stoping the nuclear reaction
and thus the heat generation. Those rods are usualy made of cadmium
because that metal can absorbs huge amounts of neutrons.
Those rods must be set and designed so that gravity alone will make them
fall completely into position.
There where obviously none! Totaly insane!
c. NO passive cooling mesures. A passive cooling mesure should be enough
to evecuate the residual heat from the shut down reactor.
d. Severly skipping on maintenance for over 10 years.
The director of the station said so himself...
Date: 16 Apr 2011 18:47:41
Message: <4daa1c8d$1@news.povray.org>
On 4/15/2011 8:50 PM, Darren New wrote:
> On 4/15/2011 19:57, Patrick Elliott wrote:
>> The problem isn't nuclear explosions, its hydrogen generated by the
>> system,
> Are you talking about the alpha radiation or something? I can't imagine
> where hydrogen would come from unless they're cracking water or something.
As I understand it, with the reactors in question, the rods are stored
in a "casing", which can resist the heat of a normal reactor, but.. and
I may be incorrect with this, when they get hot enough to start
corroding/failing, they either release hydrogen themselves. Right,
confirmed from the a news link on it: "When the fuel rods are left
uncovered by water, they'll get far too hot--we're talking thousands of
degrees Celsius here--and begin to oxidize, or rust. That oxidation will
react with the water that's left, producing highly explosive hydrogen gas."
So, the "steam" that breaches the containment on these isn't just steam,
its hydrogen gas, which gets released at those excess temperatures.
While some is produced during normal operation, its small, and easily
dealt with. So.. Its not just a case of it getting real hot, and the
water boiling off. You have *that* problem, then due to the construction
of the rods/casings, you *also* produce a gas that is both a) expanding
into the chamber, which can breach it, and b) extremely flammable, if
air can mix into it at all, through say, a large enough crack, when
combined with some ignition source.
All in all, a bad design, since any failure doesn't just create a known,
and easy to deal with problem, i.e., getting it cool again, it escalates
and produces even *more* problems, which turn a non-explosive system
into one that emits flammable materials. Its sort of like building a car
so that, if you hit something, the rear seat pops loose and hurls all
the trunk contents into the passenger cab as well.
Date: 16 Apr 2011 19:02:45
Message: <4daa2015$1@news.povray.org>
On 4/16/2011 15:47, Patrick Elliott wrote:
> That oxidation will react with the water that's left,
OK. That's what I guessed. Cracking the water to release hydrogen.
Certainly not the best design, yeah. :-)
Date: 16 Apr 2011 19:04:04
Message: <4daa2064$1@news.povray.org>
>>>> tiniest
>>> mistakes,
>>> chain of
>>> built a
>>> sabotage.
>>> reactor being
>>> mistake,
>>> sign of
>> effectively cooled.
> Alain
Yeah. Those would have been a damn good idea too.
a) makes no damn sense to me at all (even if it was some minimal system,
enough to just keep pumps going), unless the tsunami took out
lines/systems in the actual turbine part of the system. I would have
thought those would be internal to the reactor, but.. Then again, their
systems reuse a lot of waste heat/energy, so its hard to say how complex
the whole thing was, and thus "where" those systems where, and thus
whether it was even feasible to have the turbines in the reactor
buildings. Its a definite WTF for me, but may go towards the whole, "If
you make the thing so damn big you can't do *basic* shit to keep it
working, you may be building them too big." If I where to guess... They
probably have "internal systems that funnel water to and from the
reactor, then a "heat exchange" point, with and entirely separate
system, which is external to the reactors themselves. This would then
run out to their actual turbine systems, where the heated water produces
the actual power, is cooled, then pumped back into the exchanger. You
don't want to run radioactive water through the turbines, or use a
system where water from one might get into the other. This means that,
for practical purposes, power isn't generated "in" the reactor itself,
at all. So...
b) not sure any of them have this. Its not enough to just drop in a few,
in most cases, and.. well, if you can bend the damn things to shit in a
system that runs them in slowly, you can imagine what sort of mess you
end up with if some of them jam being "gravity dropped" into place.
Again, the whole design seems a problem, and most of it due to scale,
not just this one issue.
c) Hmm.. This is an interesting problem. How do you make a passive
cooling system which doesn't move contaminated air, or water, or
something else, and exchange it often/fast/effective enough to do that?
We are talking about something heating to temperatures on massive
scales, pretty damn fast, with a *major* exchange requirement. Again,
size here matters. Think of it like trying to cool a high end CPU, using
only a bit of foil taped to the top, because someone had to build the
case so an actual radiator grill and electric fan wouldn't fit in there.
You can get by with it if you are using low power, a lower end chip,
etc., but... scale up to a PC, or, in the case of power plants, a full
size nuclear reactor... and you "passive" systems are just not going to
cut it in any practical sense.
So.. Again, seems to me, once you get past the basics of, "make sure the
damn thing can run the active systems long enough to matter", everything
else is, "scale, scale, scale", and the impracticality of doing jack to
solve such problems at the scales being talked about. And, short of
building the damn things in Antarctica, and somehow getting the power
from there to every place else, I don't see "passive" being too viable...
Date: 16 Apr 2011 19:31:34
Message: <4daa26d6@news.povray.org>
>>> crash. :-P
A fair percentage of the stuff ending up on the road recently is in this
category, at least in "new" cars, in places where there are credits for
hybred/electric vehicles. It was giving some of the Regressives fits, at
least the full electric ones, at least until they got the message that
we would still, for now, need oil to run the power plants, to charge the
cars. Then they all scrambled to buy power company stocks, while
simultaneously whining at a lower volume anyway.
Part of the lack of whining has also been do to most being "hybred".
But, that is just a way of saying an "electric", which has a generator,
for when you don't have a way to charge the batteries. It adds range,
which hasn't been so good for all electrics, but all the
power/speed/etc. is still in the same motors and electronics for both
types. They also tend to cost more.
I can't find clear statistics on the matter of them though, since they
tend to lump hybred in with pure electric, but..
Chevy Volt - Hybred, 40 miles electric, ???
Coda - 90-120 miles/full electric
Fisker Karma - Hybred 50 miles electric, 300 total, 125mph max speed,
0-60 in 6 seconds.
Tesla Roadster - 245 miles on a charge, full electric?, 0-60 in 3.7
seconds. Top speed = 168.56km/h/104.79 mph - From a drag test done with it.
Think City - 75-100 miles full electric.
So, yeah, they are out there, and some of them, if you can afford them,
are getting insane, like the Tesla.
Date: 16 Apr 2011 19:35:15
Message: <4daa27b3@news.povray.org>
> college campuses, apartment complexes, business parks, etc work this
> way. (And use chilled water for cooling.) When you build things a little
> at a time (like, a few hundred houses in an area every year for 15
> years), I imagine making this work out would be more difficult,
> planning-wise.
> where everyone else (at least in the USA) adopted the same standards,
> just because it was easier.
Try smog testing a car from Arizona in California, to re-license it,
then tell me how "everyone else in the use adopted their standards". lol
Date: 16 Apr 2011 19:42:40
Message: <4daa2970$1@news.povray.org>
Well, the "government" theory, at least among randian regressives is,
"If we make driving your car expensive, companies will, for some
unspecified reason, invest money in more public transportation, instead
of just adding more and more cost to the already overly costly driving
of cars." These people have stripped so many gears in their heads that
they can't even work out that "public", means, "things not in the
interest of big corporations, who already proved that they would, if
given the task of doing this, pave a road between their warehouse and
their store, while leaving ***every other street*** in the city, or
between cities, dirt." They have no incentive to improve something that
doesn't help their business, and they would have a bus service too and
from work, only for their own employees mind, and not for free, if they
could help it, and then only if they couldn't be sure you would show up
on time if you walked, or they issued you a bicycle. They damn well are
not going to start a light rail system, if they can pay someone half as
much to drive a truck 18 hours a day, for the same distance, even if
building it would mean making money off passengers at the same time
(hell, having to load unload those might delay delivery!).
Date: 16 Apr 2011 19:48:27
Message: <4daa2acb@news.povray.org>
You think? Nah.. I am sure its just a fluke that most of them, when
asked, think that the Declaration of Independence is part of it, can't
name the first 4 amendments without getting them wrong, or, when asked
about SCOTUS, or anything else the government does, can't name one damn
program, decision, or law in "any" of it, other than, of course, the
ones they want to get rid of (and then, more often than not, they can't
describe what they hell it is, or why they actually appose it).
Its not a case of tl;dr. For way too many of them its more a case of
nib;dr, "Not in Bible, don't read", or nmpp;dr, "Not my parties policy,
do not read". That this leads to idiot things like them apposing their
own, or their own party member's, own state laws/policies, while
attacking federal ones, is just a bonus for the people watching the
circus. It gets a little less fun though, when the elephant shits on
you, on the way out the door of the tent.
Date: 17 Apr 2011 03:59:39
Message: <4daa9deb@news.povray.org>
> > not just them.
You are basically asking me how to remove hunger and poverty from the
world. If I knew the answer, do you think I would be just sitting here
writing to this newsgroup?
What I am saying is that burning fossil fuels is *not* a good solution
to the problem in the long term (or the short term, for that matter).
Date: 17 Apr 2011 04:09:51
Message: <4daaa04f@news.povray.org>
> > lowered.
Lowering birth rates was kind of also implied in my statement above.
(Most of the first-world countries have pretty low birth rates.)
Date: 17 Apr 2011 05:57:18
Message: <4daab97e$1@news.povray.org>
Yes, I know what a crumple zone is. But at 100MPH, there are going to be
fatalities, no matter which way you design a car.
> production models.
OK, fair enough.
Date: 17 Apr 2011 12:07:25
Message: <4dab103d$1@news.povray.org>
I take it the UK doesn't have any Formula-1 races?
Date: 17 Apr 2011 12:09:25
Message: <4dab10b5$1@news.povray.org>
On 4/16/2011 16:35, Patrick Elliott wrote:
> Try smog testing a car from Arizona in California, to re-license it, then
It has been relatively recent. Try buying a Japanese car in the last 5 or 10
years that doesn't meet the restrictions California imposes.
Date: 17 Apr 2011 12:10:12
Message: <4dab10e4$1@news.povray.org>
OK. And much of the argument for letting third-world countries pollute is to
get them up to first-world economics where the birth rate is much lower.
See? :-)
Date: 17 Apr 2011 12:17:09
Message: <4dab1285$1@news.povray.org>
No. My point wasn't in expecting the answer. My point was that complaining
that the best answer still sucks doesn't help until someone comes up with a
better answer.
I don't think we're disagreeing there. But complaining about a problem that
everyone in the world would like to solve that nobody has come up with a
solution for isn't too helpful. People aren't denying that burning fossil
fuels isn't the best of all possible worlds. People are merely denying that
something better is feasible.
Date: 17 Apr 2011 12:28:56
Message: <4dab1548@news.povray.org>
> See? :-)
I don't think lowering birth rates requires first-world economics.
It just requires politics. (I don't know if China is considered a
"first-world country", but they have the birth rate problem somewhat
under control at least, but not for the same reasons as many first-world
countries.)
Date: 17 Apr 2011 12:34:42
Message: <4dab16a2@news.povray.org>
First-world economics seems to be the reliable method. Basically, when you
have machinery working for you, you don't really need or want as many kids.
Unfortunately, that takes energy to run the machinery.
I think you're underestimating the difficulty of convincing someone to
starve today in order to save the world 50 years from now.
Date: 17 Apr 2011 12:36:55
Message: <4dab1727$1@news.povray.org>
And that hydrogen comes handily premixed with just the right amount of
oxygen.
That's the big problem when you start heat cracking water. You get an
explosive mixture ready to recombine into water while producing yet more
heat... When it's hot enough, you don't need any spark or flame.
Date: 17 Apr 2011 13:03:02
Message: <4dab1d46@news.povray.org>
>>>>> tiniest
>>>> mistakes,
>>>> chain of
>>>> built a
>>>> wilful
>>>> sabotage.
>>>> reactor being
>>>> mistake,
>>>> sign of
>>> effectively cooled.
>> Alain
> at all. So...
The reactor heat water in the primary cooling loop.
It circulate between the reactor and a heat exchanger just outside the
reactor housing.
This water, in turn, turn water in the secondary loop into steam.
That steam powers the turbines.
All of this is housed in a building that contains the reactor housings.
One big buiding that contains the reactors, the primary to secondary
heat exchangers and the turbines. The transformers are located outside
and alongside that building, as shown by the satellite and aerial photos
of the site.
The link from the building to the transformers station are very short
and shielded from the sea by the large building.
The transforming station was unaffected by the stunami.
The main building did NOT suffer from the stunami at all, but did stop
it and protected a significan area.
The power lines where cut over 100m BEHIND the plant.
It's the lost of those lines that caused all the problems.
Not just a few. Those drop controll rods are realy calles *Stop* rods.
They are present in the Candu reactors and several other models. They
are also mandatory in several countrys. After Tree Miles Island, they
became mendatory in the USA. Some older US reactors where shut down
because they lacked that feature.
At the end of the drop, they are stopped from the top. They can't bend,
just stretch a little. Think of a big nail shaped rod suspended above
the core by an electro magnet.
No horizontal heat exchanger, you maximize the vertical to horizontal
proportions of the cooling loops to increase the thermal syphon mechanism.
That way, the heat will greatly help you to circulate the cooling fluids.
Then, once the stop rods are droped, you have MUCH less heat to
dicipate. This, in turn, makes passive cooling easily feasible and
practical.
Date: 17 Apr 2011 14:38:16
Message: <4dab3398@news.povray.org>
On 4/17/2011 9:36, Alain wrote:
> And that hydrogen comes handily premixed with just the right amount of oxygen.
Nah. It sounds like the hydrogen gets released because something is ripping
the oxygen off it to form "corrosion".
You only get the right mixture if you put in energy without actually doing
any chemical reactions.
Date: 17 Apr 2011 17:10:35
Message: <4dab574b@news.povray.org>
> complaining that the best answer still sucks doesn't help until someone
> comes up with a better answer.
> that everyone in the world would like to solve that nobody has come up
> with a solution for isn't too helpful. People aren't denying that
> burning fossil fuels isn't the best of all possible worlds. People are
> merely denying that something better is feasible.
No, all too many of them are arguing worse. That its flat out simply not
a problem, and every step taken to limit/clean/reduce it is unnecessary.
If it was merely that its not feasible to get rid of it, we wouldn't be
having much of a heated discussion on the subject.
Date: 17 Apr 2011 17:15:03
Message: <4dab5857$1@news.povray.org>
>> at all. So...
> reactor housing.
> of the site.
In other words, there was no logical reason it couldn't have run from
the power being still generated. Well, unless there was something in
there so that, under disaster conditions, it "stopped" generating power,
so shorts couldn't happen. Still... I don't get it.
Date: 17 Apr 2011 17:16:41
Message: <4dab58b9$1@news.povray.org>
> or 10 years that doesn't meet the restrictions California imposes.
Yes, but Japan isn't in the "Hick" zone USA. The problem isn't that
people "shipping" to California would match those standards, its that
people 10 feet across a damn state line don't have to. :p
Date: 17 Apr 2011 17:21:08
Message: <4DAB59C5.6060903@gmail.com>
On 14-4-2011 21:52, Orchid XP v8 wrote:
> You've got to admit, when you read about stuff like people believing
> that ID is real science, it does make you wonder what kind of people
> live there.
If you take ID to be the idea that some protein(complexe)s can not have
been evolved from earlier proteins, then that is a testable hypothesis.
Stating and researching that idea was real science.
It turns out that all proposed systems were proven to be very easily
evolvable from known components with no intermediate non-functional
systems. All that is left now is the idea that such proteins might
exist, but haven't been found yet. IMO the *search* for such unevolvable
systems is still science. Though science that is so unlikely to be
successful that no public money should be used to fund it. If a wealthy
person want to support it, that should be OK and results should be
published in the usual way.
However *teaching* it in a classroom as an alternative hypothesis
against the theory of evolution is not science (education). Simply
because the theory as it stands was proven wrong.
BTW would dissecting the cases brought forward by Behe at al. count as
spending time on ID? Because that would be an ideal way to teach
students how real science works.
Apparently you can afford your own dictator for less than 10 cents per
citizen per day.
Date: 17 Apr 2011 17:26:04
Message: <4dab5aec$1@news.povray.org>
>> live there.
There are a few teachers that have done that, as I understand, most of
them college level though. The ID people, for some reason, haven't been
at all happy with the few they found doing it. lol But, heh, what do you
expect when some moron babbled "ontological depth", and then can't show
you how to "messure" it on a pencil, never mind an organism. ;)
Date: 17 Apr 2011 17:38:23
Message: <4dab5dcf@news.povray.org>
Yes, but I don't think that's serious debate over the reality. That's just
lying.
Date: 17 Apr 2011 17:40:28
Message: <4dab5e4c$1@news.povray.org>
On 4/17/2011 14:16, Patrick Elliott wrote:
> The problem isn't that people
> "shipping" to California would match those standards, its that people 10
My point is that it's hard to buy a car outside of California that doesn't
match California standards, because it's too expensive to retool for two
different versions of the cars any more. If you buy a Toyota while you live
in Texas or New York, you're going to get one that meets CA emission
standards. And you won't have to pay to bring it into CA.
Maybe that's not the case with Detroit cars, but I would be surprised.
Date: 18 Apr 2011 04:10:46
Message: <4dabf206$1@news.povray.org>
On 15/04/2011 22:25, andrel wrote:
> Oh no, that means that someone really believes that because the society
> as a whole seems to have almost exactly the right amount of bakers,
> plumbers and housewives that must imply that the society is designed by
> a supreme being. And that the proof of that is that society is
> irreducible complex because if you remove one group, the bakers or the
> policeman, or the bus drivers, or... the whole thing stops working,
> hence it cannot have been evolved.
That's not gonna work. Society is composed of individuals with
intelligence [allegedly]. Complex things can only come about due to
intelligence, so if unintelligent chemical soup becomes living,
breathing complexity, it must be my invisible friend's intelligence that
made it so.
Date: 18 Apr 2011 04:15:55
Message: <4dabf33b@news.povray.org>
Yeah, they do. But I'm pretty sure people driving road cars don't wear
full-body flame-retardant suits, high-end crash helmets, custom-moulded
seats, custom-calibrated seatbelts and heat restraints. I'm also fairly
sure no known road car weighs as little as an F1 car, nor is quite as
low to the ground. Also, walking around the Silverstone race circuit,
there is a rather conspicuous absence of solid objects to collide with.
If you crash a road car, you're not going to fly across a gravel trap
for half a mile and then hit a deformable tire wall. You're either going
to hit another car, or else a tree or a concrete wall. I doubt anybody
is going to walk away from that alive.
This is presumably why driving at 100MPH is an instant license revocation...
Date: 18 Apr 2011 04:17:47
Message: <4dabf3ab@news.povray.org>
> unspecified reason, invest money in more public transportation"
This is the real WTF.
Date: 18 Apr 2011 04:21:43
Message: <4dabf497$1@news.povray.org>
>> live there.
So there's a theory, the theory has been repeatedly proven wrong,
there's no particular reason to believe that it might be right in some
unknown case, and yet people continue to assert the truth of this theory
as *fact*? Doesn't sound very rational to me...
I commend the idea.
Right along side showing how String Theory, despite looking far more
professional than ID, is also not [yet] science. (And examining why it
has the potential to /become/ science in a way that ID does not.)
Date: 18 Apr 2011 08:31:26
Message: <4dac2f1e$1@news.povray.org>
On 4/12/2011 4:06 PM, Warp wrote:
> Following this from abroad, I don't know if this should be amusing or
> frightening...
> http://ncse.com/news/2011/03/antievolution-bill-tennessee-progresses-006545
> http://ncse.com/news/2011/03/intelligent-design-legislation-texas-006531
> http://ncse.com/news/2011/03/antievolution-legislation-florida-006524
> http://ncse.com/news/2011/02/antievolution-legislation-new-mexico-006469
> http://ncse.com/news/2011/01/second-antievolution-bill-oklahoma-006439
> http://ncse.com/news/2011/01/antievolution-legislation-missouri-006421
> http://ncse.com/news/2011/01/antievolution-legislation-kentucky-006389
Both ....
~Mike
