POV-Ray : Newsgroups : povray.off-topic : Internet research problem #45784 Server Time
17 Jun 2026 04:01:40 EDT (-0400)
  Internet research problem #45784 (Message 11 to 16 of 16)
Subject: Re: Internet research problem #45784
Date: 10 Apr 2011 20:01:52
Message: <4da244f0@news.povray.org>
Alain wrote:
> By the way, anybody know how to repair the windows fonts folder that
> stopped to works as intended? I can't install new fonts and the folder
> acts just like a regular folder. On Win XP.
There's a "Repair Fonts Folder" option in the TweakUI Powertoy.  I don't
know where MS is hiding it these days--it doesn't seem to be where
Google thinks it is:
http://windows.microsoft.com/en-US/windows/downloads/windows-xp
...but it does appear to be here:
http://windowsxp.mvps.org/tweakui.htm
I've never used that particular feature, but it might be what you're
looking for.
--Sherry Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
Date: 11 Apr 2011 11:38:17
Message: <4da32069$1@news.povray.org>
On 4/6/2011 10:04, Alain wrote:
> By the way, anybody know how to repair the windows fonts folder that stopped
> to works as intended? I can't install new fonts and the folder acts just
I'm guessing you deleted the desktop.ini hidden system file from the
directory, which is what tells Explorer that it's an unusual folder. See if
putting these two lines into a file in your font folder called desktop.ini
and making it hidden and system does the trick. It has the secret GUID code
that tells Explorer what to invoke to modify what it displays.
[.ShellClassInfo]
UICLSID={BD84B380-8CA2-1069-AB1D-08000948F534}
   "Coding without comments is like
    driving without turn signals."
Date: 11 Apr 2011 12:49:37
Message: <4da33121@news.povray.org>
>> stopped
> if putting these two lines into a file in your font folder called
> desktop.ini and making it hidden and system does the trick. It has the
> secret GUID code that tells Explorer what to invoke to modify what it
> displays.
> [.ShellClassInfo]
That was it, sort of!
The file WAS there, and it's content /looked/ identical, but it seems
that there was something wrong with the content, like an invisible
control character in the string...
Sherry, your proposition was the very first thing that I tried.
Date: 11 Apr 2011 14:08:31
Message: <4da3439f@news.povray.org>
On 4/11/2011 9:49, Alain wrote:
> The file WAS there, and it's content /looked/ identical, but it seems that
> there was something wrong with the content, like an invisible control
I can't imagine what happened that wound up changing parts of the file.
Nobody really looks at that except explorer.  The only thing I can think of
is you dragged the whole directory (or at least something including
desktop.ini) from a different OS and wound up changing the class id to
something visually similar but different. (I.e., where the class id might be
BD48B380... in Vista or some such.)
Odd. Glad to have helped, tho.
Date: 11 Apr 2011 16:03:02
Message: <4da35e76@news.povray.org>
>> that
> of is you dragged the whole directory (or at least something including
> might be BD48B380... in Vista or some such.)
Nothing like that.
The text was exactly the same, just did a compare with a copy I made
while trying to see what was wrong. The file was hide but not system.
It was working. I had a disk crash on my OS drive. I reinstalled on a
freshly formated drive.
Immediately after the reinstall, the normal functionality was broken.
This mean that the installation process did something wrong, like miss
set the system flag or something.
As they say: Two identical computers, with the same periferals and OS
ARE'NT...
Date: 11 Apr 2011 17:18:02
Message: <4da3700a$1@news.povray.org>
Thanks for the info. That's definitely odd. :-)
