![](/i/fill.gif) |
OK, I'm starting to play with Java and have a couple of questions.
I have several objects that are nested and have collections that I want
to iterate through
object playground
collection of ball(s)
collection of kid(s)
collection of shoes
collection of bat(s)
object ball
object balltype
object color
object kid
name
object shoe
object color
object bat
length
object color
colorname
object balltype
type
I know how to put this together with VB NET using "Inherits CollectionBase".
But how do I go about this with Java?
Thanks,
Tom
![](/i/fill.gif) |
![](/i/fill.gif) |
The equivalent abstraction collection in Java is called the Collections
Framework.
http://download.oracle.com/javase/6/docs/technotes/guides/collections/index.html
I'm not sure what exactly the confusion is?
"Coding without comments is like
driving without turn signals."
![](/i/fill.gif) |
![](/i/fill.gif) |
> Framework.
Hi Darren,
Thanks for your reply.
I guess the confusion is that I have not done any programming in Java
and was trying to explore some ways of doing things.
In the end I am after some good practices that I can follow. What was a
good practice in VB is not necessarily good in another language.
Given the example, do you have any suggestions as how they should be stored?
Thanks
Tom
![](/i/fill.gif) |
![](/i/fill.gif) |
The example isn't really detailed enough for me to say.
The Java collection framework gives you a bunch of interfaces for things
like lists, maps, sets, bags, etc. It then gives you a bunch of concrete
implementations like lists-based-on-arrays, maps-based-on-hashtables,
maps-based-on-trees, etc.
Without knowing how you expect to access the sub-collections, it's hard to
say whether you have a bag of balls, a list of balls, or a map of balls, for
example. Are you going to look up balls by name? Do you need to know what
order they are in?
It looks to me that everything you described as "collection of ..." should
be a class from the collections framework, and the other stuff should be
your own classes. In other words, based on what you wrote, I wouldn't expect
you to declare any class of your own as implementing any of the collection
interfaces.
class playground {
public Set<ball> balls;
public Set<kid> kids;
public Set<bat> bats;
class kid {
public List<shoe> shoes;
// shoes[0] is left shoe, shoes[1] is right shoe
![](/i/fill.gif) |
![](/i/fill.gif) |
This is a little more tutorial in nature.
http://download.oracle.com/javase/tutorial/collections/index.html
![](/i/fill.gif) |
