POV-Ray : Newsgroups : povray.off-topic : The marvels of Win32 Server Time
13 Apr 2026 00:52:39 EDT (-0400)
  The marvels of Win32 (Message 1 to 10 of 19)
Subject: The marvels of Win32
Date: 9 Oct 2009 08:43:18
Message: <4acf2fe6$1@news.povray.org>
You know, if you sit down and read this stuff, there's actually a *hell*
of a lot of switches and options in there...
Like, you'd think creating a window would just be "hey, please create a
window with this title please". But no. Apart from being able to specify
the title, icon, and initial size and place, you can do a whole heap of
other things:
- You can disable the close button.
- You can adjust the border style.
- You can remove the titlebar completely.
- You can enable or disable resizing the window.
- You can add that little help-icon thingy. You know, the one where the
user clicks the help button, clicks something in the window and gets an
error message saying "sorry, no help available".
- You can select "keep on top".
- You can select horisontal and/or vertical scrollbars.
- You can select whether whatever the window obscures is cached for fast
redraw.
- You can enable file drag/drop. (I'm not kidding...)
- You can do that thing that floating toolbars have, where the titlebar
is rendered smaller than usual and the window won't resize.
- You can have the window initially minimised or maximised.
- You can make it so the window can't become the active window. (I.e.,
you can see it, but can't select it.)
- You can "open" the window but have it invisible initially. (Presumably
you'll make it visible at some point - again presumably once you've
finished adding controls to it.)
This not including all the low-level stuff like what clipping to do,
which drawing context to use, which window messages to send, and a bunch
of other stuff I don't even comprehend yet.
And you thought you could just OPEN a window... ha!
Subject: Re: The marvels of Win32
Date: 9 Oct 2009 09:29:21
Message: <4acf3ab1@news.povray.org>
Yes it's great isn't it? :-)
To be fair, you can just pretty much just use all the defaults (ie use none
of those flags) and you'll get something resembling a "normal" window.  I
guess they designed it that way.
Date: 9 Oct 2009 09:53:15
Message: <4acf404b@news.povray.org>
>> *hell* of a lot of switches and options in there...
It'd be greater if the documentation were a little more illunimating -
although it's not too bad.
> none of those flags) and you'll get something resembling a "normal"
> window.  I guess they designed it that way.
Yeah, to some extent.
To another extent, there's a fair few layers of backwards compatibility
in there to wade through.
Also, the Win32 concept of a "window" is not the same thing as what you
or I would consider a "window". (E.g., a checkbox is a "window".) Makes
things interesting...
Date: 9 Oct 2009 10:13:15
Message: <4acf44fb@news.povray.org>
> Also, the Win32 concept of a "window" is not the same thing as what you or
Yes, you need to get your head around that otherwise you're going to be
*very* confused when it comes to adding icons and stuff to your "window"...
Date: 9 Oct 2009 10:22:43
Message: <4acf4733@news.povray.org>
>> you or I would consider a "window". (E.g., a checkbox is a "window".)
>> Makes things interesting...
The fun thing is, half the stuff is talking about *actual* windows.
(E.g., only an actual window has a title bar and a menu.) And half of
the stuff is talking about widgets. (E.g., would you like a drop shadow
around that?) And it's not always clear which is which.
Date: 9 Oct 2009 12:15:30
Message: <4acf61a2$1@news.povray.org>
Qt did better. Everything is a widget, and windows (main window, toolbar
window, dock window) are kinds of widgets.
Maybe Win32 inherited the terminology from X10/X11?
Of course, when you get actual OO with actual inheritance and such, it
becomes a lot easier.
w = new Window();
w.hasTitlebar(true);
w.canTakeFocus(false);
w.hasHelpIconThingie(true);
w.backgroundColor(white);
w.open();
Date: 9 Oct 2009 14:21:11
Message: <4acf7f17@news.povray.org>
Yeah. AWT did this. Smalltalk did this. Most people did this, actually.
(Except Tk. :-P )
Yeah, perhaps.
For sure. ;-)
http://blog.orphi.me.uk/
Date: 9 Oct 2009 15:47:04
Message: <4acf9338@news.povray.org>
Orchid XP v8 wrote:
> (Except Tk. :-P )
Well, Tk called it a toplevel, and called the things inside a toplevel
widgets, so it wasn't too confusing. I.e., Tk didn't call anything just a
"window".
Date: 11 Oct 2009 00:18:12
Message: <4ad15c84@news.povray.org>
*Everything* is a window.  That is, if it's somehow graphical and
something you might normally stick on a window, it's a subclass of "Window."
--SKS
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
Date: 11 Oct 2009 05:47:09
Message: <4ad1a99d@news.povray.org>
> "Window."
The usual term is "widget". That way, if you mean "any component", you
say widget, and if you mean "thing that looks like a window", you say
"window".
Under the Win32 terminology, there's no way to talk about real windows
specifically.
