POV-Ray : Newsgroups : povray.off-topic : Low-level fun Server Time
28 Sep 2024 21:18:00 EDT (-0400)
  Low-level fun (Message 1 to 10 of 47)
Subject: Low-level fun
Date: 19 Sep 2009 04:50:55
Message: <4ab49b6f$1@news.povray.org>
So now I'm wondering if Windows provides any easy way to load and save
bitmapped images. GDI appears to allow you to load and save in Windows
Bitmap format - arguably amoung the worst file formats *ever*. But what
about something more sane?
Well, DirectX doesn't seem to have anything useful. (Gotta love the way
half the stuff on MSDN turns out only to be applicable to Windows 7.
Yeah, like I really care about that...) I did eventually find something
that appears to do exactly what I want. Not quite sure which versions of
Windows support it, but it looks interesting.
Reading further, it seems you have to link this special file into your
application. (That can't be good...) And then it starts talking about
something called COM, and I got *completely* lost.
...so now I'm trying to figure out what the hell COM is. :-/
http://blog.orphi.me.uk/
Subject: Re: Low-level fun
Date: 19 Sep 2009 14:15:55
Message: <4ab51fdb$1@news.povray.org>
Orchid XP v8 wrote:
> (Gotta love the way
That is the one problem with Microsoft's online documentation. They don't
put the old stuff online in a way that's easy to find. If you don't stay on
the upgrade treadmill, you need to buy copies of the documentation if you
want to keep working.
What kind of file? Probably a COM stub.
Object-oriented remote procedure calls. You know what object-oriented is?
You know what remote procedure calls are? Slap the two together. That's COM.
It's typed and reflexive. It's basically one step up from DLL, in that it
can be a DLL running in a separate process or even a separate machine (via
"DCOM"). You're probably linking in a file that takes your local procedure
calls, packages up (aka "marshalls") the arguments, and then sends them to
the COM subsystem which delivers them to the appropriate task for execution.
It's basically how all software talks to other software on Windows if you
don't want to be hard-coding stuff in at compile time like function offsets.
It's how Word talks to Excel, how the help subsystem talks to IE, how
ActiveX talks to IE, and how Windows Scripting Host talks to everything.
Pretty much every line using an "object" in WSH is talking to that object
via COM.
Date: 19 Sep 2009 14:52:22
Message: <4ab52866$1@news.povray.org>
>> (Gotta love the way half the stuff on MSDN turns out only to be
> don't put the old stuff online in a way that's easy to find. If you
> don't stay on the upgrade treadmill, you need to buy copies of the
> documentation if you want to keep working.
But of *course*, if you're writing new software, you will only be
interested in making it work for Windows 7 (which, I add, isn't even
available yet). Why would you want to target the OS that 99% of your
market is still using when you could target some brand new unreleased
one and thus force everybody to actually buy it?
> is? You know what remote procedure calls are? Slap the two together.
> That's COM. It's typed and reflexive. It's basically one step up from
> DLL, in that it can be a DLL running in a separate process or even a
> separate machine (via "DCOM"). You're probably linking in a file that
> takes your local procedure calls, packages up (aka "marshalls") the
> arguments, and then sends them to the COM subsystem which delivers them
> you don't want to be hard-coding stuff in at compile time like function
> offsets. It's how Word talks to Excel, how the help subsystem talks to
> IE, how ActiveX talks to IE, and how Windows Scripting Host talks to
> everything. Pretty much every line using an "object" in WSH is talking
> to that object via COM.
After spending a couple of hours on this, here's what I managed to
figure out:
- A DLL is a file containing a set of procedures. You can dynamically
load it into memory and call these procedures. (I'm not precisely sure
how...)
- RPC is both a network protocol and a system for calling procedures in
another running program. This program may or may not be running on the
same computer.
As best as I can tell, you write a list of procedures that you want to
be able to call remotely, and run this through the MIDL compiler. This
spits out two blobs of code. You link one into your client, and it
enables you to call these procedures just like any other procedure.
However, what the generated code actually does is scoop up the
parameters passed, serialise them somehow, and then presumably call some
secret undocumented Win32 function to actually send this data somewhere.
The data is then sent either via local IPC or network RPC packets to the
server side.
The code blob linked into the server then unserialises the data and
calls the actual procedure inside the server. Then the procedure's
return value (if any) goes through the same process in reverse, ending
up at the client end just like a normal procedure call.
Oh, and there's optional authentication, encryption, asynchronous
messaging, message queues (but only in Windows 2000, no other OS), and a
bunch of other stuff that didn't make sense.
- COM allows you to create objects, find out what interfaces they
support, and call the functions in those interfaces. These objects can
be provided by a DLL loaded into your program, an EXE running on the
same computer, or (hypothetically) a program running on some remote
computer. So it's like a system that can DLL procedure calls or RPC
calls - and you don't have to care which.
Again, I haven't actually figured out how to *call* a COM method. I have
however figured out how to create an object, find out what interfaces it
has, and get hold of the one you want. What I can't find anything about
is how you get from having the interface to calling one of the methods
it contains...
...it all seems like a hell of a lot of work just to write a PNG file.
Maybe it would be quicker (and more portable) to just read the PNG file
spec and write my own encoder? (Except that, well, have you *seen* the
algorithm?! Complicated, much??)
Date: 19 Sep 2009 15:09:23
Message: <4ab52c63@news.povray.org>
Incidentally, I found out why the registry is called... the registry.
It's where you *register* where the hell the code for all these objects
is actually stored. Who'd have thought?
Date: 19 Sep 2009 16:00:11
Message: <4ab5384b$1@news.povray.org>
> available yet).
Of course it's available. Not the release version, but the betas.
It's not *that* hard to figure out which 2% of the features in the OS are
new to Windows 7 and which are the same stuff that's been around for 5+ years.
> figure out:
> how...)
Yes. It's a dynamically-linked library. Says it right there in the name. :-)
In the beginning of the file is a table of names and pointers. You can look
up the name to get the pointer, or you can just branch indirectly thru the
pointer if you know at compile time its offset.
http://en.wikipedia.org/wiki/Dynamic-link_library
> same computer.
Well, RPC is a generic term, meaning to invoke a procedure in someone else's
address space. Sun took the term and used it to refer to their particular
implementation. Ever since, "RPC" has been like "PC" - do you mean Personal
Computer or an IBM compatible machine running MS-DOS?
Right. Actually, not quite right. What it spits out is a description of the
COM interface. Then your compiler takes that description and generates the
actual code to call it. It's not some secret code. It's a well-defined
interface that any compiler can implement. Heck, I can call it from Tcl.
Yes. Because the best way to promote everyone to use your technology is to
not document how to incorporate it into your code.
Sheesh.
Even *wikipedia* documents what the calls are. Why would you think it's secret?
> server side.
Yes.
Basically, yes.
Everything from Windows 2000 on, which I believe is where they introduced
DCOM.  Regular COM, where you're calling a different process on the same
machine, obviously doesn't need authentication, encryption, etc.
Exactly. Plus, it's an active object, i.e., what people call an "Actor". A
process running Excel is basically one big COM object, with methods like
"open a spreadsheet" and "return the value of column B row 27." That's how
people do these automation tasks.
You can use IDispatch::Invoke for dynamically linked stuff.
http://msdn.microsoft.com/en-us/library/ms690156(VS.85).aspx
http://en.wikipedia.org/wiki/IDispatch
http://msdn.microsoft.com/en-us/library/ms221479.aspx
I'll grant you, that one was a bit ugly. :-)
Only because your language doesn't already have COM in it. Once you get the
basics worked out, then you can say "How do I convert an Excel spreadsheet
to a pie chart as a GIF file" and do it with the same code.
Most programming languages have the COM stuff already built for them (which
is kind of the poing of making it standard, see) so it's just a matter of
invoking the component.
Date: 20 Sep 2009 07:51:50
Message: <4ab61756$1@news.povray.org>
Why not just go grab libpng? That's how POV-Ray does it.
Date: 20 Sep 2009 09:25:14
Message: <4ab62d3a$1@news.povray.org>
Look for GDI+ It's applicable to Windows XP and higher. It's
object-oriented, and designed to work with C++, iirc, so will need C++
in order to use it, though I think they have C wrappers.
Component Object Model ;)
Essentially it was supposed to be a cross-language way of dealing with
things in an object-oriented manner. It looks very intimidating at
first, but once you get the hang of it, it's really not too bad.
Building the C/C++ headers from the IDL files is rather easy using the
#import directive, though some have dependencies you'll have to import
as well.
Have fun ;) I did this sort of programming for quite a long time, both
on the component side, and the application side.
Date: 20 Sep 2009 10:18:51
Message: <4ab639cb$1@news.povray.org>
Isn't that a DLL?
So... I'd *still* need to figure out how DLLs work. ;-)
Date: 20 Sep 2009 10:24:55
Message: <4ab63b37$1@news.povray.org>
>> available yet).
They have a beta already? Damn, that was fast...
>> Why would you want to target the OS that 99% of your market is still
>> using when you could target some brand new unreleased one and thus
> are new to Windows 7 and which are the same stuff that's been around for
> 5+ years.
Actually, MSDN does a surprisingly good job of documenting this
information, yes.
>> how...)
In other words, it's a shared library. I more or less knew they before. ;-)
> look up the name to get the pointer, or you can just branch indirectly
> thru the pointer if you know at compile time its offset.
I just meant I haven't found the actual function call for getting access
to the exposed symbols yet.
(According to Wikipedia, seems to be GetProcAddress()...)
>> in another running program. This program may or may not be running on
>> the same computer.
> else's address space. Sun took the term and used it to refer to their
> particular implementation. Ever since, "RPC" has been like "PC" - do you
> mean Personal Computer or an IBM compatible machine running MS-DOS?
Sure. But in this case, I'm talking about Microsoft RPC. As in, that
service that if it stops running, your entire PC shuts down for some
reason... (MS Blaster, anyone?)
> the COM interface. Then your compiler takes that description and
> generates the actual code to call it. It's not some secret code. It's a
> well-defined interface that any compiler can implement. Heck, I can call
> it from Tcl.
I'm not quite following.
According to the documentation, you write an MIDL file, and the compiler
generates a header file and two C source code files. You link one into
the client, and one into the server. (I haven't tried it, so I don't
know what's actually *in* these C files, mind you...)
>> some secret undocumented Win32 function to actually send this data
>> somewhere.
> to not document how to incorporate it into your code.
> Sheesh.
> secret?
Because the MIDL compiler generates this code, so technically you don't
need to know how it actually works. (Also, I couldn't find any functions
anywhere which looked likely.)
>> the server side.
> Yes.
> Basically, yes.
>> a bunch of other stuff that didn't make sense.
> introduced DCOM.  Regular COM, where you're calling a different process
> on the same machine, obviously doesn't need authentication, encryption,
> etc.
I'm reasonably sure NT 4 has DCOM, but possibly with NTLM authentication
only. Windows 2000 is where they added Kerberos, for sure.
...you mean the object can be doing other stuff by itself before you
specifically ask it to do something?
> A process running Excel is basically one big COM object, with methods
> like "open a spreadsheet" and "return the value of column B row 27."
> That's how people do these automation tasks.
Heh. I had always assumed that such tasks are simply impossible, because
I've never come across a programming language that can do them. (Well,
except VB. And who the hell understands that?)
But, uh, isn't IDispatch::Invoke *itself* a COM method??
Seriously, I see CoInitialise() and CoUninitialise() to start/stop the
COM library. I see CoGetClassObject() and CoCreateInstanceEx(), but I
can't see a CoCallMethod() or similar anywhere.
> the basics worked out, then you can say "How do I convert an Excel
> spreadsheet to a pie chart as a GIF file" and do it with the same code.
> (which is kind of the poing of making it standard, see) so it's just a
> matter of invoking the component.
Well, maybe I need to sit down and spend some time creating "COM
support" for Haskell, and then everything will become trivial. :-P
Date: 20 Sep 2009 10:47:04
Message: <4ab64068$1@news.povray.org>
Well well, it appears there's already a library on Hackage that's
supposed to provide COM support.
Oh, would you look at that? It won't compile. What a *big* surprise...
They really, really need to make it so that packages that call C will
actually compile on Windoze. :-P
