POV-Ray : Newsgroups : povray.off-topic : Still random Server Time
31 Jul 2026 21:53:06 EDT (-0400)
  Still random (Message 31 to 40 of 50)
Subject: Re: Still random
Date: 8 May 2009 06:24:41
Message: <4a040869@news.povray.org>
> Well, I don't know about that, but physics is mostly about forces, and
> forces generate acceleration, and force is usually a function of position
> (or perhaps velocity). Hence differential equations seem to be kind of
> ubiquitous in physics.
> Interestingly, a trivial differential equation has exponential growth as
> its solution, but you never see this in mechanical systems.
Diesel engines would destroy themselves without a control system to keep the
speed down, that's the best I can come up with now of a mechanical system
with exponential growth.  I think the key point is that most things have a
force that acts in the opposite direction of the movement, which usually
keeps things stable and also produces the oscillations.
> I thought a Taylor series is just a way of constructing a polynomial
> approximation to a function that you don't have any better way to compute.
Indeed, so if we can estimate the derivatives by some numerical method, we
should be able to estimate how the actual function goes forwards, at least
for a little while.
> And taking 4 linear steps uses the result of the previous steps for the
> next one.
But it doesn't use the results to go back and work on the *same* part of the
function to improve the accuracy, it just blindly moves onto the next time
step ignoring whatever errors might have been present.
> I don't get why taking those steps, throwing the result away and just
> keeping the intermediate results, and then mixing that all together gives
> a better result. (Altough it clearly *does*.)
Another way to look at it I guess is that RK4 is effectively estimating
"deeper" derivatives, like x'' and x''' to better estimate how the function
goes.
>> I also find that keeping momentum as a state variable rather than
>> velocity (which would also work) avoids some of the confusion with the
>> differential of position in the algorithm.
> Perhaps.
It's also crucial when you come do doing rotations as well as linear
movements.  For linear movements you can simply add on the accerlation times
dt to the velocity, then the same for position.  But you cannot do this for
angular movements, you need to add on the torque to angluar momentum, use
that to calculate a thing called spin, then add that onto the angular
orientation.
> I don't follow. (I.e., I don't see how the final formula is remotely
> related to RK4.)
Try writing a function to estimate x' x'' and x''' of a function at a
certain time and position.  Then use it to predict what the value of x will
be at the next time step based on the Taylor Series expansion.  Then,
assuming you are estimating the derivatives in the "correct" way, you can
simplify your solution and you'll end up with the RK4 algorithm :-)  I have
no idea what mathematical jiggery pokery you'll need to do that, but that is
essentially what RK4 is doing.
Euler integration estimates the next value by assuming:
x = x + dt x'
ie it will perfectly match a function like x = 4 + 5t
RK4 estimates the next value by assuming:
x = x + dt x' + 1/2 x'' dt^2 + 1/6 x''' dt^3
ie it will perfectly match a function like x = 4 + 5t - 3t^2 + 45t^4
Date: 8 May 2009 07:09:59
Message: <4a041307$1@news.povray.org>
> things have a force that acts in the opposite direction of the movement,
> which usually keeps things stable and also produces the oscillations.
Yeah.
Of course, the fun part happens when objects hit each other. Then you
have a sudden and drastic change in the forces applied. Good luck
integrating that...
>> compute.
> we should be able to estimate how the actual function goes forwards, at
> least for a little while.
So... well, we don't need to "estimate" the acceleration at all. We can
compute it directly. (Assuming we have an exact position...) But you're
saying you compute the acceleration several different times in order to
estimate its integral or something?
> function goes.
...so you compute acceleration several times to try to estimate the
derivative of acceleration? (I think the term is "jerk".) That makes
slightly more sense.
> times dt to the velocity, then the same for position.  But you cannot do
> this for angular movements, you need to add on the torque to angluar
> momentum, use that to calculate a thing called spin, then add that onto
> the angular orientation.
o_O
Let us pray I never need to handle anything other than point masses...
>> related to RK4.)
Well, if you have a way to compute f(x), you could try using
   f'(x) ~= f(x + dx) - f(x)
By analogy you have
   f''(x) ~= f'(x + dx) - f'(x)
and substituting the previous you eventually arrive at
   f''(x) ~= f(x + 2 dx) - 2 f(x + dx) + f(x)
By a similar process you have
   f'''(x) ~= f(x + 3 dx) - 3 f(x + 2 dx) + 3 f(x + dx) - f(x)
Of course, none of this does you any good if you can't compute f in the
first place.
> will be at the next time step based on the Taylor Series expansion.
Ouch. That sounds like fun...
> Then, assuming you are estimating the derivatives in the "correct" way,
> you can simplify your solution and you'll end up with the RK4 algorithm
> :-)  I have no idea what mathematical jiggery pokery you'll need to do
> that, but that is essentially what RK4 is doing.
Mmm, right.
Of course, now I'm trying to comprehend how this *explicit* method
differs from the more accurate *implicit* method I keep hearing about...
Date: 8 May 2009 08:11:10
Message: <4a04215e$1@news.povray.org>
> Of course, the fun part happens when objects hit each other. Then you have
> a sudden and drastic change in the forces applied. Good luck integrating
> that...
Usually in real-time simulations you can just apply an impulse to the body
and bypass the integrator altogether.  Your collision response algorithm
will calculate exactly what impulse to apply to each body so that they
"bounce" realistically, you then directly modify the momentum values, and in
the next step RK4 doesn't know what happened :-)
A more accurate way is to actually simulate the contact deformation with
forces, but usually due to the big forces involved you need very small time
steps which is beyond real time simulation.
By computing x' several times (which you can exactly) you are in effect
estimating x'' and x''', which gives you a better estimate for x than just
using x' alone.  Remember that here "x" can be position or velocity as far
as RK4 is concerned.
Yes.
If you have set up your RK4 code nice and object orientatedly, it is really
very simple to add in.
You don't though, you are trying to find f(x+dt) given that you can easily
calculate f'(x).
f''(x)  ~= (f'(x+dt) - f'(x)) / dt
f'''(x) ~= (f''(x+dt) - f''(x)) / dt
f''''(x) ~= (f'''(x+dt) - f'''(x)) / dt
If you substitute those expressions into the Taylor series expansion and
write it in terms of just f'(x) then you will probably end up with something
similar to RK4.  Maybe :-)
f(x) = f(x) + f'(x)*dt + 1/2*f''(x)*dt^2 + ...
> Of course, now I'm trying to comprehend how this *explicit* method differs
You can usually rewrite your equations of motion for your whole simulation
as one big matrix equation, something like Ax + Bx' + Cx'' = D where A-D are
matrices and x is a vector of all your state variables.  C would typically
contain masses and inertias, A stiffnesses, B damping and D external forces.
An implicit integrator works on this entire formula in one stab, solving
usually by matrix inversion, iterative methods or whatever.  For big
interacting systems it is much better as the constraints (eg two masses
connected by a spring) are forced throughout the calculation, and not just
adjusted at the end of each time step.  This is how mechanical finite
element simulation software works, essentially solving a massive matrix
equation for each time step.
Subject: FIXED!
Date: 8 May 2009 08:59:27
Message: <4a042caf$1@news.povray.org>
Invisible wrote:
> PS. I still need to fix the rendering program. I wrote it while at work,
> and it worked OK, but was rather inflexible and brittle. So when I got
> home, I wrote it again. But for some reason, the version I wrote at home
> is about 10x slower - and I can't figure out why! o_O
I just spent about 2 hours peering over the source code for the two
programs, back to back, side by side. Considering that they were written
on different ways on different computers, it's remarkable how many of
the files are identical character-by-character. (Most of them differ by
variable names, function names, order of arguments, etc.)
I even tried replacing source files from the defective version with
files from the optimal version, but to no avail. The program is big, but
not *that* damned big! There's only so many places to look for bugs...
I tried everything I could think of to fix the problem. *Finally*, I
discovered that replacing one block of code with an apparently
equivilent block causes a 10x speedup. Whiskey Tango Foxtrot?
At least, I know the bug is inside one tiny function. But where?
Well, I just nailed it. It was in the adaptive subsampling code. When
computing the error in the current step, I wrote
   error = mag (position1 - position3) + mag (velocity1 - position3)
Looks fine, right?
...until you put it on consecutive lines:
   errorP = mag (position1 - position3)
   errorV = mag (velocity1 - position3)
PWN3D!
Change the second line to
   errorV = mag (velocity1 - velocity3)
and suddenly the program speeds up massively.
D'OH!! >_<
Subject: Faster...
Date: 8 May 2009 11:20:37
Message: <4a044dc5$1@news.povray.org>
And now for some speed tuning.
A simple way to measure the program's speed is to count how many frames
per minute it can render. So, set it to 320x480 so it's moderately fast
[on this ancient single-core 32-bit 1.5 GHz CPU] and count.
After fixing the stupid bug: ~24 frames/minute.
Changed array indexing from tuples to integers: ~24 frames/minute.
Merged the four arrays into one interleaved array: ~26 frames/minute.
[I'm thinking this might improve cache behaviour slightly... but
apparently not much. Or just the cache isn't the bottleneck.]
Removed array bounds checks: ~27 frames/minute.
Removed adaptive time step: ~80 frames/minute.
[Well there's a surprise. Pitty the frames look awful...]
Added adaptive time step within RK4 as per Scott's suggestion: ~1
frame/minute.
[Ah, but now the "error" is being calculated in a totally different way,
so the error tolerance required to get a good image may have changed.
What happens if I use a less strict tolerance?]
Turned down error bound: ~68 frames/minute.
[I made the maximum permissible error 10,000x larger, and the images
still come out looking flawless. But they render vastly faster...!]
Date: 8 May 2009 12:30:23
Message: <4a045e1f$1@news.povray.org>
I've always found this to be quite fascinating. Why should that be?
Why is back EMF always in the direction that reduces the EMF? Why does
friction work in a direction that reduces the effects of friction?
Almost everything one can think of works this way. I only remember
encountering two or three effects in the last few decades (other than
economics and some odd quantum stuff, IIRC) that don't damp themselves.
Unless you get something like thermal runaway, where you have two separate
effects reinforcing each other that would individually damp each other out.
Funkily enough, if you look at wikipedia under "Negative_mass", there's some
stuff in there about what happens if mass is negative, with fun observations
like "negative masses would produce an attractive force on one another, but
would be repelled because of their negative inertial masses". I.e., the two
minus signs on the mass cancel out, so two negative masses are attracted to
each other, *but* they'll move apart, because negative mass moves towards
the direction you push it from. :-)
</ramble>
   There's no CD like OCD, there's no CD I knoooow!
Subject: Re: FIXED!
Date: 8 May 2009 12:34:34
Message: <4a045f1a$1@news.povray.org>
Shouldn't velocity and position be incompatible types?
Subject: Re: FIXED!
Date: 8 May 2009 13:08:08
Message: <4a0466f8$1@news.povray.org>
Well, if you wanted to go that far you could. I just had them both as 2D
vectors...
http://blog.orphi.me.uk/
Subject: Re: FIXED!
Date: 8 May 2009 13:18:11
Message: <4a046953$1@news.povray.org>
Well, now you know why people do, when it's important to be correct. :-)
Isn't it pretty trivial to do that in Haskell, tho?
Subject: Re: Faster...
Date: 8 May 2009 13:26:30
Message: <4a046b45@news.povray.org>
> frame/minute.
A clearer (for a human) way to see the speed is to show the inverse of that:
seconds per frame.
