POV-Ray : Newsgroups : povray.off-topic : Code division multiplexing Server Time
22 Mar 2026 11:53:12 EDT (-0400)
  Code division multiplexing (Message 1 to 10 of 17)
Subject: Code division multiplexing
Date: 22 Apr 2009 11:26:47
Message: <49ef3737$1@news.povray.org>
I don't know why it works... but it does.
 >module CDM where
 >encode :: [Int] -> [Int] -> [Int]
 >encode cs xs = do
 >  x <- xs
 >  c <- cs
 >  let y = if x == 1 then 1 else -1
 >  return (c*y)
 >decode :: [Int] -> [Int] -> [Int]
 >decode cs [] = []
 >decode cs xs =
 >  let
 >    (xs0,xs1) = splitAt (length cs) xs
 >    y = sum (zipWith (*) cs xs0)
 >  in ((y `min` 1) `max` 0) : decode cs xs1
OK, so let's encode something:
   *CDM> encode [1,-1] [1, 0, 1]
   [1,-1,-1,1,1,-1]
   *CMD> decode [1,-1] [1,-1,-1,1,1,-1]
   [1,0,1]
Well that's nice. But now check this out:
   *CDM> let x1 = encode [1,1,1,1] [1,1,0,1]
   *CDM> let x2 = encode [1,-1,1,-1] [1,0,1,1]
   *CDM> let x3 = encode [1,1,-1,-1] [0,0,1,1]
   *CDM> let x4 = encode [1,-1,-1,1] [1,1,1,0]
   *CDM> x1
   [1,1,1,1,1,1,1,1,-1,-1,-1,-1,1,1,1,1]
   *CDM> x2
   [1,-1,1,-1,-1,1,-1,1,1,-1,1,-1,1,-1,1,-1]
   *CDM> x3
   [-1,-1,1,1,-1,-1,1,1,1,1,-1,-1,1,1,-1,-1]
   *CDM> x4
   [1,-1,-1,1,1,-1,-1,1,1,-1,-1,1,-1,1,1,-1]
   *CDM> let y = foldl1 (zipWith (+)) [x1,x2,x3,x4]
   *CDM> y
   [2,-2,2,2,0,0,0,4,2,-2,-2,-2,2,2,2,-2]
   *CDM> decode [1,1,1,1] y
   [1,1,0,1]
   *CDM> decode [1,-1,1,-1] y
   [1,0,1,1]
   *CDM> decode [1,1,-1,-1] y
   [0,0,1,1]
   *CDM> decode [1,-1,-1,1] y
   [1,1,1,0]
Magic!
Subject: Re: Code division multiplexing
Date: 22 Apr 2009 11:47:55
Message: <49ef3c2b$1@news.povray.org>
Invisible wrote:
> Magic!
http://denbeste.nu/cd_log_entries/2002/04/Howspreadingactuallyworks.shtml
http://denbeste.nu/special/cdma_spreading.html
Not magic, but certainly very difficult to understand intuitively.
   There's no CD like OCD, there's no CD I knoooow!
Date: 22 Apr 2009 13:29:19
Message: <49ef53ef@news.povray.org>
>  >module CDM where
>  >encode cs xs = do
>  >  x <- xs
>  >  c <- cs
>  >  return (c*y)
>  >decode cs [] = []
>  >decode cs xs =
>  >  let
>    [1,-1,-1,1,1,-1]
>    [1,0,1]
>    *CDM> x1
>    *CDM> x2
>    *CDM> x3
>    *CDM> x4
>    *CDM> y
>    [1,1,0,1]
>    [1,0,1,1]
>    [0,0,1,1]
>    [1,1,1,0]
> Magic!
  Are you seriously expecting people to understand what's going on there,
without any kind of explanation?
  I'm a programmer and I haven't the slightest idea.
Date: 22 Apr 2009 13:34:18
Message: <49ef551a$1@news.povray.org>
>>  >module CDM where
>>  >encode cs xs = do
>>  >  x <- xs
>>  >  c <- cs
>>  >  return (c*y)
>>  >decode cs [] = []
>>  >decode cs xs =
>>  >  let
>>    [1,-1,-1,1,1,-1]
>>    [1,0,1]
>>    *CDM> x1
>>    *CDM> x2
>>    *CDM> x3
>>    *CDM> x4
>>    *CDM> y
>>    [1,1,0,1]
>>    [1,0,1,1]
>>    [0,0,1,1]
>>    [1,1,1,0]
>> Magic!
encode <key> <data> gives you a bunch of stuff. decode <key> <stuff>
gives you back the original data.
Which isn't that surprising. What's surprising is that if you add
several of these together, the decode function still works. (Provided
each data stream has a different key - or, more exactly, an "orthoganol"
key.)
Apparently this is how mobile phones manage to all transmit at the same
time yet not screw up each other's transmissions.
This much I would have thought would be vaguely intuitive from the
program's output. Of course, to comprehend how I've implemented the
encode/decode functions, you'd need to understand Haskell...
http://blog.orphi.me.uk/
Date: 22 Apr 2009 15:59:09
Message: <49ef770d$1@news.povray.org>
>>>  >module CDM where
>>>  >encode cs xs = do
>>>  >  x <- xs
>>>  >  c <- cs
>>>  >  return (c*y)
>>>  >decode cs [] = []
>>>  >decode cs xs =
>>>  >  let
>>>    [1,-1,-1,1,1,-1]
>>>    [1,0,1]
>>>    *CDM> x1
>>>    *CDM> x2
>>>    *CDM> x3
>>>    *CDM> x4
>>>    *CDM> y
>>>    [1,1,0,1]
>>>    [1,0,1,1]
>>>    [0,0,1,1]
>>>    [1,1,1,0]
>>> Magic!
> encode <key> <data> gives you a bunch of stuff. decode <key> <stuff> gives
> Which isn't that surprising. What's surprising is that if you add several
> of these together, the decode function still works. (Provided each data
> stream has a different key - or, more exactly, an "orthoganol" key.)
No wonder cell phones keep cutting out.
All it takes for a bit to be lost is for one analog "chip" to be
a little outside of it's intended magnitude and then it misses
the whole bit.
Date: 22 Apr 2009 16:11:30
Message: <49ef79f2$1@news.povray.org>
>>> there,
>> "orthoganol" key.)
>> same time yet not screw up each other's transmissions.
> the whole bit.
No.
Each signal bit is encoded by several analog "chips". If one such chip
is lost (a very likely occurance, given that others are using the same
chip frequencies concurrently), the remaining chips still allow the
signal to be recovered. (This is precisely _why_ there are several chips
to each signal bit.)
Add error-detecting and correcting codes on top of that and you have...
well personally I find it fairly unusual for *my* phone to cut out. But
then, my network seems to have unusually good coverage.
Date: 22 Apr 2009 17:13:00
Message: <49ef885c$1@news.povray.org>
More specifically, how CDMA phones manage it. GSM phones and many others use
different techniques.
Date: 22 Apr 2009 17:15:04
Message: <49ef88d8$1@news.povray.org>
> the whole bit.
Actually, the whole point of the technology is that you *can't* jam it
without basically blanketing everything in the entire bandwidth (including
your own signals), and it's virtually impossible to detect because it all
sounds like noise unless the receiver has a key that matches the
transmitter.  It was originally developed for military radios, ya know.
Date: 23 Apr 2009 03:52:54
Message: <49f01e56$1@news.povray.org>
> use different techniques.
Really? That's interesting... I got to the CDMA article *from* the GSM
article. o_O
Date: 23 Apr 2009 05:15:27
Message: <49f031af$1@news.povray.org>
Hey, neat.
So it's kind-of like this?
http://en.wikipedia.org/wiki/Visual_cryptography
I'm still trying to figure out exactly how it works, but it's quite neat.
And now I'm wondering... can you implement this stuff using only
analogue electronics? My first instinct is "how the hell do you compute
signal correlation without a computer?" but now I'm thinking maybe you
can do it with some op-amps. The only real problem would be getting
sender and receiver to generate the same psuedo-random reference signal,
and keep it synchronised.
