POV-Ray : Newsgroups : povray.off-topic : Woo, GPU! Server Time
22 Jun 2026 02:37:44 EDT (-0400)
  Woo, GPU! (Message 42 to 51 of 71)
Subject: Re: Woo, GPU!
Date: 29 Jan 2009 11:54:17
Message: <4981df39$1@news.povray.org>
Invisible wrote:
>> Crysis, OTOH...
> ...will cost me money, whereas FarCry 2 I already have. ;-) I might as
> well at least see what it's like...
Sure, check it out since it's *ahem* free.  How much did you pay for
that video card?
Also, I thought you were going to buy Crysis anyway.
> Hmm, although... if it's any harder than FarCry 1, I guess there really
> *is* no point. o_O
I don't think it's harder.  Don't expect the same game as FarCry 1,
though.  It's quite different.  Crysis is much more similar to FarCry 1
than FarCry 2 is.
Date: 29 Jan 2009 15:27:23
Message: <4982112b$1@news.povray.org>
> that video card?
compute-bounded mentalness on? ;-)
Er, yeah. But probably not "soon"...
> than FarCry 2 is.
OK then.
http://blog.orphi.me.uk/
Date: 29 Jan 2009 17:02:59
Message: <498227F7.9060509@hotmail.com>
On 28-Jan-09 22:46, Orchid XP v8 wrote:
> Darren New wrote:
>> When did it get common to tack a "U" on the end of "Power Supply"?
>> Nobody calls it a Power Supply Unit. :-)
> Er... I do?
> I've always seen it referred to as PSU.
Would you pronounce that as P.S.U. and if not would you pronounce the
the P as in pseudo?
Date: 30 Jan 2009 04:00:32
Message: <4982c1b0$1@news.povray.org>
Yes.
Subject: Re: Woo, mass breakage
Date: 30 Jan 2009 04:41:32
Message: <4982cb4c$1@news.povray.org>
OK, so last night I embarked on an epic HD moving process.
Suffice it to say, I removed the 80GB HD that I don't really use much. I
took the two remaining HDs and moved them to the bottom of the drive
rack. There is now space for the giant graphics card to slot into the PC
without purchasing a larger case.
It sounds like a trivial operation, but it wasn't. I only just have
enough power connectors, and various cables weren't really long enough, etc.
There is one small problem: the drive I removed was the one with the
working boot sector on it. I did try plugging the drives into the other
SATA sockets, but the Windows XP install CD apparently lacks the drivers
necessary to access the secondary SATA controller, so it couldn't "find"
the drives in that configuration. (KNOPPIX found them just fine, but not
Windows XP.)
Actually, it turns out the new graphics card will only block *two* of
the primary SATA sockets, so I can in fact still plug my drives in in
the usual way. I have now done this, and Windows XP can "see" them again.
Now *all* I have to do is figure out how to put NTLDR and friends back
onto the drive using the recovery console and my PC will be usable
again... o_O
Date: 30 Jan 2009 05:37:12
Message: <4982d858$1@news.povray.org>
Cool.
> again... o_O
Then you should be able to try the latest ones from here:
http://www.nzone.com/object/nzone_downloads_nvidia.html
Date: 30 Jan 2009 05:49:01
Message: <4982db1d$1@news.povray.org>
>> again... o_O
One time, I actually sat down and tried every demo on nVidia's website.
(Up until the point where the higher ones wouldn't run, anyway.)
Some of the demos are just rubbish, but a few of them are really awesom.
Most especially this one:
http://www.nzone.com/object/nzone_luna_home.html
OK, technologically it's probably not that special. But seriously...
WOW! o_O This is some SERIOUSLY WEIRD CRAP! How the **** did they come
up with this stuff?! ._.
Unfortunately, I rapidly discovered that many of the demos will not
cleanly uninstall afterwards. (!!)
Date: 30 Jan 2009 05:59:44
Message: <4982dda0$1@news.povray.org>
> again... o_O
Under Windows NT, there was a feature where you could boot from the
install CD, select "repair", and it would scan your HDs, try to find an
installed copy of Windows NT, and if it found one, attempt to make it
bootable. (E.g., check the boot sector, add the various executables and
configuration files required for a successful boot, and even replace
missing or corrupted DLLs and so on.)
Apparently this feature does not exist in Windows XP. (One presumes it
was found to be too useful, and its removal allows M$ consultants to
charge you money to fix your PC for you...)
Anyway, after consulting not less than 7 different KB articles, it
appears that I can use the Recovery Console to manually copy the two
boot files from the CD to the HD and semi-automatically rebuild the boot
configuration menu.
In case anybody wants to know, the procedure appears to be this:
- Start the Recovery Console. (I.e., boot the install CD and press "R"
when prompted.)
- Type "map" and observe the drive letter for the CD drive.
- Copy NTLDR to the harddrive: copy O:\i386\ntldr C:\
- Copy NTDETECT.COM too: copy O:\i386\ntdetect.com C:\
- Build a new BOOT.INI file: bootcfg /all
- This last command spends a few hours scanning all your HDs looking for
anything that looks like a Windows installation. It then gives you an
interactive prompt asking which ones to add to the boot menu.
Hopefully at this point the system should become bootable again. (And if
not, I'll just reinstall Windows. That should get rid of those old
nVidia demos that wouldn't uninstall...)
Date: 30 Jan 2009 06:00:12
Message: <4982ddbc@news.povray.org>
I just realised... I can't even run them in a VM! They need the GPU. ;-)
Date: 30 Jan 2009 06:09:34
Message: <4982dfee@news.povray.org>
>> again... o_O
How did you manage to mess that up by simply replacing a graphics card?!?!
