POV-Ray : Newsgroups : povray.off-topic : Curiosity Server Time
22 Jun 2026 05:42:31 EDT (-0400)
  Curiosity (Message 9 to 18 of 28)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Curiosity
Date: 15 Dec 2008 07:38:42
Message: <49464fd2@news.povray.org>
> I'm presuming a mould with a fake-leather texture to it has gotta be
> pretty expensive to make...
You mean like the one you have on the dashboard in your car?  The texture on
the plastics on your car dashboard is both to give it a "quality" feel but
also to avoid specular reflections from sunlight etc.
> Yeah, I guess if you want to check the bits fit together, a 3D model is
> fine, but if you want to see how strong it is, you need to use the real
> material that the final product will use.
Or if you want to check it will last OK continually in temperatures of -30
degrees or +40 degrees (other countries outside of England have much more
extreme temperatures, and things must still work ok).  Or if you want to
check it still works after you drop it on the floor etc, that sort of thing.
> Reading Wikipedia, it appears that "most" plastic items are thermoplastics
> rather than thermosetting. Is that true? Does that mean there's a
> possibility of reusing your prototypes once you're done with them?
I don't think so, the cost of reprocessing the parts into something the
plastics maker could use would be too high.
>> +/- 0.1 mm is pretty easy to achieve in a single shot plastic injection,
>> that sounds about right for a CD hinge to work.
> That sounds really damned tiny! o_O
But think about it, if the hinge on one side was just 1mm off, it's not
going to work at all.
>> A quick google reveals that chapter 6 of the USB spec specifies that :-)
>> The outline dimensions of the plug are +/-0.1mm, but some of the pin
>> spacings and inner dimensions are down to +/- 0.05
> Wow. OK, that's pretty small...
But again, think about what your USB plug would feel like if it was just
0.5mm too wide, it wouldn't feel like it should and the plug would come off
too easily.  That's why a smaller tolerance is necessary for some parts.
> Suddenly I'm wondering what the tolerances are for those *tiny* little
> screws they have on things like spectacles. ;-) Man, the thread on those
> is tiny!
Yeh, imagine the tolerance on the thread pitch of those :-)  Something
insane like 0.02 +/- 0.005 mm !
> You might even know this one... What is the total travel on the buttons of
> a mobile phone? I mean, you can "feel" them click, but visibly they hardly
> seem to move at all! (But then, I hypothesize that the inside of a mobile
> phone is a very cramped place.)
Don't know, but usually there are just tiny rubber "poppers" underneath, a
bit like those toys you used to have as a kid that were like a thick
hemisphere shell of rubber, you turned them inside out and set them down,
then after a few seconds they jumped up in the air.  The click you feel on
the keys is when the rubber "snaps" in and out of shape.
> Damn. So after some guy designs what the final thing is even meant to look
> like, some other dude has to figure out what seperate bits to make and how
> to slot them together, and then yet another guy has to figure out how the
> **** to build something to make stuff that shape! o_O
Exactly - and you begin to realise how expensive, how many people, and how
much time it takes to design something apparently simple like a mobile
phone.  Then imagine designing something like a car, or a plane! It's just
not possible to imagine how much work goes into such a product.
> Heh. Damn... I wonder how they cut the mould to exactly the right shape?
You can get milling machines that are controlled by very accurate stepper
motors, a computer sends a list of commands to the machine and it moves the
cutting bit around.
Date: 15 Dec 2008 08:04:26
Message: <494655da$1@news.povray.org>
Yeah, like that.
Or in fact, just now I was looking at a cheap knife. The blade is a lump
of metal that's just about sharp enough to cut bread, and the handle is
a blob of black plastic that looks like it's injection-moulded. (It has
a fetling line on it.) But then I noticed, the plastic has a rough
texture to it. (To enhance grip?) How do they do that?
I wonder if they use something like the acid on "frosted" glass...
>> Yeah, I guess if you want to see how strong it is, you need to use the
>> real material that the final product will use.
> Or if you
> want to check it still works after you drop it on the floor etc, that
> sort of thing.
Yeah, well, that's a function of far more than the plastic shell. Gotta
assemble the whole thing for that! ;-)
>> thermoplastics rather than thermosetting. Is that true? Does that mean
>> there's a possibility of reusing your prototypes once you're done with
>> them?
Apparently by dad spent some time working in a plast where they do
"vacuum forming", and each time you do that, you have to cut a bunch of
wasted plastic off the edges. He says they sent it back to the suppliers
and they got a discount. (But then, how hard can reprocessing a flat
sheet of plastic be?)
>> those is tiny!
Hee... must be expensive! ;-)
>> buttons of a mobile phone?
> a bit like those toys you used to have as a kid that were like a thick
> down, then after a few seconds they jumped up in the air.  The click you
> feel on the keys is when the rubber "snaps" in and out of shape.
Right.
And that brings us back to my question about components which are
supposed to "snap together". I guess it depends on how deformable the
plastic is? (And that surely must depend on shape...)
>> look like, some other dude has to figure out what seperate bits to
>> make and how to slot them together, and then yet another guy has to
>> figure out how the **** to build something to make stuff that shape! o_O
> how much time it takes to design something apparently simple like a
> mobile phone.  Then imagine designing something like a car, or a plane!
> It's just not possible to imagine how much work goes into such a product.
I wouldn't have called a mobile phone "simple", but yeah. I was thinking
more something like a pen. (They usually have that click-action that
allows you to retract the tip. And a lid that needs to fit properly. And
the tip is usually metal, not plastic. And you need to fill it with ink
somehow...)
It kinda makes you wonder how anything ever gets made in the first place!
> stepper motors, a computer sends a list of commands to the machine and
> it moves the cutting bit around.
Heh, and I bet that's even *more* damed expensive again... not to
mention the quality hardened steel you need for it to mill...
I wonder... do companies buy all this stuff themselves? Or just
subcontract it out?
I also wonder... Today we have machines that make components of machines
that are used to make machines for making machines. Some of this stuff
is made to absurd tolerances - stuff no human could ever make by hand.
So... how the **** did we make it in the first place?!
Dude, HOW DO YOU BOOTSTRAP CIVILISATION?! O_O
Date: 15 Dec 2008 08:31:47
Message: <49465c43$1@news.povray.org>
Now, see, this is what I love about off-topic... There's so many people
here who know interesting stuff! :-D
Date: 15 Dec 2008 09:03:28
Message: <494663b0$1@news.povray.org>
There are both mechanical methods and chemical etching methods to make the
patterns.  Basically you are just making a pattern on the surface of the
metal in the mould.  For one of our plastic products (which is an optical
component so is transparent plastic) they make "fine adjustments" to the
surface texture by some dude manually "roughening up" the surface in certain
positions :-)
Usually you don't do any testing on individual parts, only on the assembled
product.
> Apparently by dad spent some time working in a plast where they do "vacuum
> forming", and each time you do that, you have to cut a bunch of wasted
> plastic off the edges. He says they sent it back to the suppliers and they
> got a discount. (But then, how hard can reprocessing a flat sheet of
> plastic be?)
Well yeh, if from every single shot you have some waste then it makes sense
to work out how to reuse that.  But working out how to reuse 5000 samples is
a bit pointless if you are planning to make 2 million every month later.
> And that brings us back to my question about components which are supposed
> to "snap together". I guess it depends on how deformable the plastic is?
Yep, or technically "stiffness", which is how much something deforms for a
given force (units DISTANCE/FORCE).  You can of course design the shape so
that things deform easily for clips, or make springs to hold things in place
etc.
Yeh I often wonder that too...
> Heh, and I bet that's even *more* damed expensive again... not to mention
And then the actual milling bit, which presumably must be harder than the
hardened steel :-)
> subcontract it out?
Well you get quite long supply chains sometimes, like take for example car
company 1.  They will have supplier 2 that makes some big chunk of the
dashboard.  Supplier 2 will have a supplier 3 that provides one part (eg the
radio).  Supplier 3 will then use supplier 4 to make the plastic part to go
on the front of the radio.  Supplier 4 will own the injection moulding
machine, but could well use a supplier 5 to actually manufacturer the tools
to go in the injection molding machine.  And of course there will be another
supplier 5 that supplies the raw plastic to supplier 4.
Companies like Nokia and Ford don't actually make much, they just design
things and get other people to make them, then assemble bits together :-)  I
once saw a Nokia factory, each production line was about 50 metres long,
they simply screwed some components together, did some electrical and
optical testing, clipped the plastic parts on and packaged it into several
layers of cardboard boxes.  Very low tech and very simple.
> that are used to make machines for making machines. Some of this stuff is
> made to absurd tolerances - stuff no human could ever make by hand. So...
Well just because you only have equipment to design and make stuff to
tolerance X, it doesn't mean that you can't make a machine that can make
stuff to a tolerance lower than X.  eg you could just build a motor and then
gear it down a lot so that the movements are very small and accurate, or use
optical lens to shrink your design, or use a lever so that a larger
tolerance on one end corresponds to a smaller tolerance at the other end.
Date: 15 Dec 2008 09:15:20
Message: <49466678$1@news.povray.org>
> the patterns.  Basically you are just making a pattern on the surface of
> the metal in the mould.  For one of our plastic products (which is an
> optical component so is transparent plastic) they make "fine
> adjustments" to the surface texture by some dude manually "roughening
> up" the surface in certain positions :-)
Yay for manual roughening up dude! :-D
>> Gotta assemble the whole thing for that! ;-)
> assembled product.
Not even to test that they actually fit together properly? Or is that
more or less guaranteed before the parts leave the design stage?
(OTOH, I guess that assembling the final item *is* checking that the
parts fit! :-D )
> sense to work out how to reuse that.  But working out how to reuse 5000
> samples is a bit pointless if you are planning to make 2 million every
> month later.
OK, fair enough.
> a given force (units DISTANCE/FORCE).  You can of course design the
> shape so that things deform easily for clips, or make springs to hold
> things in place etc.
IIRC, if you bend plastics they return to their original shape, until
you bend them past a certain point, at which they deform permanently.
(They also change colour for no adaquately-explored reason...)
> the hardened steel :-)
HOW THE HELL DO THEY CUT DIAMONDS?!
>> subcontract it out?
> car company 1.  They will have supplier 2 that makes some big chunk of
> the dashboard.  Supplier 2 will have a supplier 3 that provides one part
> (eg the radio).  Supplier 3 will then use supplier 4 to make the plastic
> part to go on the front of the radio.  Supplier 4 will own the injection
> moulding machine, but could well use a supplier 5 to actually
> manufacturer the tools to go in the injection molding machine.  And of
> course there will be another supplier 5 that supplies the raw plastic to
> supplier 4.
> :-)  I once saw a Nokia factory, each production line was about 50
> metres long, they simply screwed some components together, did some
> electrical and optical testing, clipped the plastic parts on and
> packaged it into several layers of cardboard boxes.  Very low tech and
> very simple.
Heh. That explains why if you drive round any small industrial estate,
you'll find some nobody company that's never been heard of called
"Lanstead Way Plastics Ltd" or something. They all mould plastics! :-D
>> machines that are used to make machines for making machines. Some of
>> this stuff is made to absurd tolerances - stuff no human could ever
>> make by hand. So... how the **** did we make it in the first place?!
> then gear it down a lot so that the movements are very small and
> accurate, or use optical lens to shrink your design, or use a lever so
> that a larger tolerance on one end corresponds to a smaller tolerance at
> the other end.
Yeah, but without precisely machined gears, wouldn't there be too much
play between the teeth for the position to hold accurately?
Date: 15 Dec 2008 09:15:54
Message: <4946669a$1@news.povray.org>
Invisible wrote:
>> A typical hard-tool for a simple plastic part (eg the front cover of
>> your CD drive or half of a simple keyboard shell) will cost of the
>> order of 10-40k pounds.
> o_O
> Ouch...
Pff.. That's nothing :) The jigging system I worked on cost about US$1M
for a decently sized system. ~US$100K per 4 axis table. Our saws ran
about US$100K-250K
I'm guessing Injection molding machines don't have computer controls.
I'd imagine the engineering costs are pretty high, though ... getting
all of the pathways right so the part fills the mold properly, and cures
properly.
> Perhaps I should clarify: I'm talking about a "keyboard" of the musical
> kind. Somebody might attempt to put it on a stand that only supports the
> ends of the unit, and it's over a meter wide. (Even so, all it contains
> inside is a circuit board. No batteries or power supply or anything
> heavy, just the key action.)
My el-cheapo Casio has a metal chassis. Ask me how I know ... I had to
pull it apart to fix the MIDI out port ... stupid thing came un-soldiered.
~Mike
Date: 15 Dec 2008 09:25:59
Message: <494668f7$1@news.povray.org>
>> o_O
>> Ouch...
> about US$100K-250K
Jig system?
What are you trying to cut? Kryptonite??
> properly.
More to the point, apparently IM machines are rated on the amount of
pressure they can clamp the mould down with - measured in tonnes. (!)
Apparently the cheap ones manage 3-4 tonnes, and the best reach 6,000
tonnes or more. O_O
You as well?
(Actually, you should be glad it even *has* a MIDI port in the first
place! Most cheap keyboards don't.)
We had to take my old ghettoblaster apart after the line in became
loose. After we soldered it back down and reassembled it, we found one
small metal part left over. We still don't know what that was!
Ah, that was a *quality* piece of equipment though. The box boasts 200W
of power, but the actual speakers inside had figures of fractional Watts
crudely printed on them. (2x speakers at 0.5W, 2x woofers at 0.25W.) And
the manual described the line-in sockets as having "> 14% THD". :-D
Date: 15 Dec 2008 09:26:30
Message: <49466916$1@news.povray.org>
Mmm, tasty...
http://en.wikipedia.org/wiki/Injection_molding
http://en.wikipedia.org/wiki/Electrical_discharge_machining
http://en.wikipedia.org/wiki/Electro_chemical_machining
Date: 15 Dec 2008 09:45:12
Message: <49466d78$1@news.povray.org>
Invisible wrote:
> Jig system?
Jigging -- A means of holding something together while you work on it.
Tack on another 10K for the rolling press... btw. (You have to press the
plates into the truss.)
The saws cut ordinary wood, but they're robotic. Lots of engineering and
programming time goes into them.
> tonnes or more. O_O
If you can find it in your country, check out the show "How Its Made"
Here it appears on the Discovery Science network. They detail many
industrial processes. It blows my mind how these huge presses seem to
stamp out such things as screwdrivers with nearly no effort.
The U.S. mint apparently uses 84 tons of pressure to press a coin. All
applied in an instant! Hundreds of times a minute.
> You as well?
Well, I had aspirations of creating music on the computer a long time
ago, and decided a MIDI keyboard was the appropriate input device. That
didn't work out... :)
~Mike
Date: 15 Dec 2008 09:47:27
Message: <49466dff$1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:494655da$1@news.povray.org...
    Yes, you need a lathe to make a lathe.
     ~Steve~
