POV-Ray : Newsgroups : povray.off-topic : My first C++ program Server Time
28 Jun 2026 10:42:20 EDT (-0400)
  My first C++ program (Message 90 to 99 of 149)
Subject: Re: A test
Date: 21 Sep 2008 04:41:06
Message: <48d608a2@news.povray.org>
Orchid XP v8 <voi### [at] devnull> wrote:
>      std::string  txt;
>      std::cin  >> txt;
>      std::istringstream iss(txt);
>      int number;
>      iss >> number;
  I think you misunderstood the reason to use stringstreams. Recycling the
user input through the stringstream above is basically a no-op (except that
it's needlessly inefficient). You could have read the value directly from
std::cin:
    int number
    std::cin >> number;
  Why I suggested using stringstreams in your original program was because
you wanted to read either a string or an integer. This can be done by
reading a string, and then trying to parse it as an integer with a
stringstream (which also allows you to check if the parsing succeeded).
  However, here you are simply always reading an integer. There's no need
>      if (number < target) {std::cout << "Too low."  << std::endl; continue;}
>      if (number > target) {std::cout << "Too high." << std::endl; continue;}
>      break;
  Wouldn't it be simpler to do it like:
    if(number == target) break;
    if(number < target) std::cout << "Too low.\n";
    else std::cout << "Too high.\n";
Subject: Re: A test
Date: 21 Sep 2008 04:43:06
Message: <48d6091a$1@news.povray.org>
>>      std::string  txt;
>>      std::cin  >> txt;
>>      int number;
>>      iss >> number;
Er, yeah, good point...
>>      break;
Mmm, I guess that would also work...
http://blog.orphi.me.uk/
Subject: Re: A test
Date: 21 Sep 2008 04:56:28
Message: <48d60c3c@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Warp wrote:
> >     case(compare(number, target)) of
> >   What would be wrong with a syntax like that?
> All the functions in Haskell are curried. So it's really
>    case (compare(number)(target)) of ...
  How does Haskell distinguish where a nested (possibly curried) function
call ends, and the outer one continues? Assume that you would want to
write (here in C++ style) something like:
    foo(a, bar(b, c), d, e)
  If you wrote that as a Haskell-style no-delimiters function call,
I suppose it would look like:
    foo a bar b c d e
  Exactly how does Haskell decide how many parameters 'bar' takes there
(and consequently how many of the rest of the parameters are for 'foo')?
  I can't even begin to imagine how you would write that using the
"point syntax", seen in many examples posted by Andrew. Perhaps you
use parentheses to enclose the 'bar' call?
  (Btw, I think this demonstrates one problem with Haskell. I'm an
experienced programmer, and I do have a moderate understanding of the
functional paradigm, and I have been seeing quite many example programs
posted by Andrew during the last years. Yet I'm still completely unable
to figure out or deduce how you could write that in Haskell. It must be
simple, but I just don't know, even though I have seen many examples of
small Haskell programs.
  There just is something about the Haskell paradigm and syntax that
makes it confusing and hard to assimilate.)
Subject: Re: A test
Date: 21 Sep 2008 05:29:04
Message: <48d613e0$1@news.povray.org>
>     foo a bar b c d e
You'd have to throw in some brackets to disambiguate.
If you change every "foo(x, y, z)" into "(foo x y z)", you'll get a
valid expression. In this case, we have
   foo a (bar b c) d e
If you wrap the whole thing in brackets, then the following rule
applies: the first token after each "(" is the function being called;
everything else is arguments.
What may be a little confusing is that a function's arguments may be
functions themselves - even standard library functions. This is very
useful from a programming perspective (indeed, the whole paradigm is
based on it), but perhaps rather unhelpful for anybody trying to read
the thing.
Where this starts to go wrong is where you start using operators.
Obviously "2 + 7" means... well... two plus seven. It would be tedious
(though perhaps more consistent) to write this as "(+) 2 7".
To understand how to parse an expression involving operators, you must
know (or take a reasonable stab at) operator precidences. For arithmetic
operators, it's the usual stuff. Function application has a higher
precidence than anything else in the language - so "foo x + bar y"
parses as "(foo x) + (bar y)" and not "foo (x + bar) y".
And that leads us neatly on to...
You can't. Because the nested expression isn't the final argument in the
argument list. (Haskell programmers are very fussy about what order to
put function arguments in for just this reason.)
The following are all equivilent:
   function1 (function2 (function3 (function4 (function5 x))))
   function1 $ function2 $ function3 $ function4 $ function5 $ x
   function1 $ function2 $ function3 $ function4 $ function5 x
   (function1 . function2 . function3 . function4 . function5) x
The last one creates a function by chaining several functions together,
and then passes x as the argument to that function. Normally you
wouldn't do that; you'd only use (.) if you wanted to pass a function as
an argument or something:
   map (reverse . toUpper)
(Takes a list of strings, converts each string to upper case, and then
reverses it.)
Where this starts to get crazy is if you have functions that take more
than one argument. Because functions are curried, you may write
   function2args x $ function4args a b c $ function1arg j
or something.
So, between recognising language keywords, bracketed expressions, ($)
and (.), and infix operators, I guess there *is* quite a bit to be
getting on with.
It's interesting to me that most people seem confused not by curried
functions or monads or high-order functions, but by the basics of
parsing Haskell's syntax. I guess I'm so used to it be now that I take
it for granted - but obviously, if you can't read the language syntax,
you don't stand much chance of getting very far. I'll go have a think
about that...
Subject: Re: My first C++ program
Date: 21 Sep 2008 07:21:26
Message: <48d62e33@news.povray.org>
>   What you can do is this:
>     std::string s;
>     while(true)
>         std::cin >> s;
>         if(!std::cin.good()) break;
>         int value;
>         std::istringstream iss(s);
>         iss >> value;
>         if(!iss.fail())
>             std::cout << "The input was an integer: " << value << "\n";
>         else
>             std::cout << "The input was something else: " << s << "\n";
  Actually there is a way to achieve the same thing with std::cin
directly, without having to use stringstreams.
  If an input stream fails to read data which fits the parameter type,
it will stop reading, so anything that was in the input (which was not
whitespace) will be left there. It's thus possible to check if reading
the integer filed, and if it did, read it as a string.
  The only catch is that you have to clear the error flags of std::cin
before you can continue reading properly.
  The above example code can thus be written as:
    while(true)
        int value;
        std::cin >> value; // Try to read an integer
        if(std::cin.fail()) // If there was no integer in the input
            std::cin.clear(); // Clear the error flags
            std::string s;
            std::cin >> s; // Read a string
        else
  Thus removing the need for stringstreams.
Date: 21 Sep 2008 07:32:00
Message: <48d630b0$1@news.povray.org>
Thanks for the tip.
By the way... what's the usual C++ idiom for handling failure?
In Haskell, if you have some function that could fail for some reason,
you have two options:
1. Throw an exception if there's a problem. (Only I/O code can catch and
handle exceptions.)
2. Use the "maybe" datatype, which contains either some data, or a
"there's nothing here" flag. (And because the type is different, the
caller *must* explicitly check which it is before using the result for
anything.)
Typically you throw an exception for something like "we ran out of
memory" or "you called with an invalid argument". But for something
like, say, looking up a key in a dictionary, it's a very predictable
thing that the key might not actually exist, so the "maybe" approach is
used there.
What is the "usual" C++ style for this kind of thing? (I'm asking a
question of style here; clearly there are several possible things you
*could* do in C++.)
Date: 21 Sep 2008 07:53:44
Message: <48d635c6@news.povray.org>
> *could* do in C++.)
  The standard data containers, as well as 'new', throw an exception by
default when they run out of memory. Also the at() member function of
some of the containers throws an exception if you try to index out of
boundaries.
  If you don't want to throw exceptions in your own code, then it depends
on what is it that you want to do to signal a condition.
  The usual way to catch programming errors at runtime is to use
assertions. For example:
void foo(int min, int max)
    assert(min <= max);
    // rest of the code here
  If the assertion fails, a message will be printed and the program is
immediately terminated at that point. Obviously this should only be
used in situations which are a symptom of a programming error and which
must be fixed.
  (The good thing about assert() is that you can freely use it as much
as you want. In fact, the more you use it, the better. You can compile
the program with a special precompiler parameter which will remove all
the asserts from the executable so that they will not add overhead to
a final version.)
Date: 21 Sep 2008 08:06:18
Message: <48d638ba$1@news.povray.org>
> boundaries.
>     assert(min <= max);
> must be fixed.
Right. So assert() is for stuff that should never happen if the
programmer is doing their job right. In other words, BUGS.
How about stuff that might ordinarily be expected to not work? E.g.,
parsing strings, looking up keys in dictionaries, etc.
It seems that streams at least signal errors by altering the stream
object and getting the programmer to call a member function to check
whether an error condition occurred. Is that a usual C++ idiom?
Date: 21 Sep 2008 08:18:51
Message: <48d63bab@news.povray.org>
  I'm not sure there *is* any "usual" C++ idiom for error handling
(other than throwing exceptions).
Subject: Re: (And in Haskell. Obviously.)
Date: 21 Sep 2008 10:09:31
Message: <48d6559b$1@news.povray.org>
Orchid XP v8 wrote:
> Both C and C++ are positively *bursting* with features that are subtle,
> counter-intuitive and cryptic.
No, actually, C is really, really straightforward. Almost moreso than
assembler. It's not subtle and complex and cryptic. It's just difficult
and tedious.
> This isn't exactly news. C++ at least
> appears to be something of an improvement in this regard...
I, personally, think C++ has many features that seem subtle and
counter-intuitive, as evidenced by the fact that it's really hard to
explain how some of the features work and when they come into play. Most
people seem to say "this is how you use them" without actually knowing
why using them that way actually works.  (Granted, I don't have a whole
lot of experience with C++, so I probably sound way off base to those
who know C++ well.)
