POV-Ray : Newsgroups : povray.off-topic : A simple question Server Time
3 Aug 2026 19:47:06 EDT (-0400)
  A simple question (Message 24 to 33 of 153)
Subject: Re: A simple question
Date: 31 Mar 2008 15:30:47
Message: <47f149f7$1@news.povray.org>
Darren New wrote:
> Orchid XP v8 wrote:
>> What physical basis there is for this hypothesis, I have no idea...
> You can, of course, move speakers as slowly as you like. The problem is,
> the slower you move the speakers, the less energy in the resulting wave.
> So to get loud bass, you need speakers big enough to generate enough
> energy even when the speaker cone is moving slowly. Or you need to put
> the speakers very close to your ears.
Right. So that's why the tiny drivers in my headphones seem to produce
enough bass to fell a tree - they're positioned a few mm from my
earholes! :-D
Date: 31 Mar 2008 15:31:55
Message: <47f14a3b@news.povray.org>
> Orchid XP v8 wrote:
>> Hell, for that price it should also make me a cup of tea when I wake
>> up in the morning! :-S
> http://www.boingboing.net/2002/12/08/coffeemaking-pc-case.html
Does it heat the water using your CPU?
Date: 31 Mar 2008 15:56:10
Message: <47f14fea$1@news.povray.org>
Jim Henderson wrote:
> My kid just picked up a used D610 and he seemed happy with the speakers
> so far.
My earlier work-laptop was D610 (now I have a D620, surprisingly) and I
mostly couldn't stand theier speakers. To be truthful, the "soundcard"
(Intel HD-Audio oslt) those Dell's have ain't actually helping in the
situation.
Same goes for my own HP (nc6320). The soundcard's problems can be heard
while listening with headphones. The Dells and the HP tend to have
twisted frequency response assigned with el-cheapo final amplifier with
ability to overrun the mixer *and* pre-amplifier easily. It's just hidious.
Basically it's impossible to have a decent sound out of very small
speakers, which just *can't* be designed and configured for each
using-environment independently. But if either HP or Dell D6xx are on
the top of what's possible, I'm surprised - it shouldn't be *that*
impossible.
And yes, I'm a kind of hifist, so 'bout every sound-quality rant I write
has the over-shooting part of it. But still... *brr*
Don't hook him up with eg. Sennheisers high-quality headphones :). It
might lead to an expensive path :P.
> Jim
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 31 Mar 2008 15:58:54
Message: <47f1508e@news.povray.org>
Well, I don't know. If you make the laptop's case into basically a
"picture speaker", it might work.
I rather suspect that might make the laptop rather fragile though...
Date: 31 Mar 2008 15:59:04
Message: <47f15098$1@news.povray.org>
Mike the Elder wrote:
> I believe the general approach taken by laptop designers is that since laptops
> are nearly always single-user personal machines, HQ audio will come through HQ
> headphones.
I wish this was the case. But at least consumer-priced business-line
HP's and Dell's don't seem to have a HQ output for headphones :( (check
my other message). I think I should loan a Mac someday to test one.
> Best Regards,
>  Mike C.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 31 Mar 2008 16:09:33
Message: <47f1530d$1@news.povray.org>
You mean like a panel speaker? Those are dipols (they emit the sound to
multiple directions and take good usage of the reflections. Therefore
they are extremely nift about how they are placed...
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 31 Mar 2008 18:18:04
Message: <47f1712c$1@news.povray.org>
On Mon, 31 Mar 2008 20:37:20 +0100, Orchid XP v8 wrote:
>>> My laptop has speakers that would compare poorly against almost any TV
>>> set imaginable. They're very quiet (you often can't hear them over the
>>> fan) and they rattle like hell at mid-range frequencies in a way that
>>> only the cheapest disposible radio sets can. So if your laptop sounds
>>> in any way comparable to a half-decent TV set, it's much better than
>>> what I have!
>> What type of laptop?  The Compaq Armada M700 that my wife uses sounds
>> like you describe here....
> Sharp GP1918 or something like that?
Never used Sharp PC equipment before....
Jim
Date: 31 Mar 2008 18:20:01
Message: <47f171a1$1@news.povray.org>
>> so far.
> situation.
> hidious.
> impossible.
Well, yeah - I'm a bit of an audiophile myself, having worked with pro
recording equipment in the past.  Nothing in a laptop comes close - most
frequently, it's low bass response that kills the sound.  But my T42p has
its speakers mounted on the front edge, and it does seem to do better
than most other laptops - but if I want really good sound, of course,
I'll hook it up to my stereo. ;-)
Well, it's his money. ;-)
Jim
Date: 31 Mar 2008 22:13:43
Message: <47f1a867@news.povray.org>
I believe the original page is gone, but no, it did not. :-) It used one
of those plug-in drop-in-your-mug coils.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 1 Apr 2008 02:25:31
Message: <47f1e36b$1@news.povray.org>
> Is it possible to buy a laptop that has built-in speakers which aren't a
> joke?
No.
> Is there some theoretical reason why the speakers in a laptop can't
> produce high-quality sound?
Yes, to produce hi-fi quality sound you need a speaker cone bigger than most
laptops and a very carefully designed enclosure to produce a nice response.
> Or is it merely that manufacturers are eager to fit the best, most
> powerful CPU and sell the unit for the lowest possible cost, and fitting a
> better set of speakers isn't a high priority?
Exactly - I suspect that most laptop design companies don't even employee a
single audio engineer to optimise these things.  Or maybe they do, but they
get given a space of 2cm3 and a budget of 25c per laptop.
