POV-Ray : Newsgroups : povray.off-topic : Liquid Physics Server Time
28 Jul 2026 09:11:17 EDT (-0400)
  Liquid Physics (Message 8 to 17 of 37)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Liquid Physics
Date: 31 Mar 2008 10:38:17
Message: <47f10569$1@news.povray.org>
> Ah, right, so it's overloaded but that's not shown in the article?
Yup, it is in the source code however.
> (BTW, I thought printf() was only for C, not C++?)
Well it is for C, but anything you can do in C you can do in C++.  Not that
it's a good idea though...
> Did the Haskell version look "readable"?
Not really, I tried to add some to your code to show what I meant with the
other evaluate function, but I couldn't work out what was going on!
> One of the nice things about Haskell is that you can't make that mistake.
> Since you never update anything in-place, you can't accidentally destroy a
> result you need to use again later, and by left wondering where this
> "wrong" data is coming from.
Seems logical, but without thinking about it too much, how would you keep
track of the state of the system while it's running?  Are you basically
saying that variables are write-once in Haskell?  SO I couldn't do something
like:
currentState = Integrate(currentState);
I would need to instead do:
frame++
state[frame] = Integrate( state[frame-1] )
Date: 31 Mar 2008 10:56:14
Message: <47f1099e@news.povray.org>
Ah, OK. I thought it was just a typo or something...
> that it's a good idea though...
Ah yes, C++ is a superset of C. But I was thinking (hoping?) that in C++
you have something less hellish than prinf() to play with...
> the other evaluate function, but I couldn't work out what was going on!
No, Haskell doesn't support overloaded functions, so you'd have to make
some moderately radical (oxymoron?!) alterations to make it work.
> keep track of the state of the system while it's running?
Ah, grasshopper, you are still thinking in imperative terms. ;-)
A true Haskeller would define a notionally infinite list which
notionally contains the entire state of the system at every future point
in time. Examining the elements of this list causes the integration to
actually be performed, and assuming you let go of the start of the list,
the GC will delete each state after it has been calculated.
In other words, define an infinite list, and then map some monadic
function over it which displays the state of the screen or dumps it to a
file or otherwise "does" something with it. And the result will be more
or less like this C++ example.
Now, if you want to use *user input* to alter the integration as it
proceeds, then you must take an somewhat different approach. (See below.)
> Are you
> basically saying that variables are write-once in Haskell?
You *could* put it that way. It would be more correct to say that a
variable is *defined* as having a specific value in Haskell. Consider this:
   let node1 = Node {next = node2, prev = node4}
       node2 = Node {next = node3, prev = node1}
       node3 = Node {next = node4, prev = node2}
       node4 = Node {next = node1, prev = node3}
   in ...
As you can see, it's not so much that you can only assign once to a
variable, it's that you are *defining* what a variable's value *is*. The
compiler will chase dependencies - even circular ones - and resolve them
for you, figuring out what order to initialise everything and so forth.
(You can't really speak of assigning several values to the same variable
"one after the other" because [pure] Haskell function don't have any
notion of "time".)
> So I couldn't do something like:
No, you couldn't.
You could, however, write
   animate state = do
     dispaly state
     let new_state = integrate state
     animate new_state
which will display the initial state, call your integrate function to
compute the next state, display that state, and so forth. (This method
*does* allow you to accept user input and do something different based
on what the user input is.)
A third way would be to use explicitly mutable state - something like this:
   state <- takeMVar my_state
   writeMVar (integrate state)
But there's no particular advantage in doing that here, and it just
takes more typing to write out.
http://blog.orphi.me.uk/
Date: 31 Mar 2008 11:13:14
Message: <47f10d9a$1@news.povray.org>
You do.
C:
printf("Number is: %d\n", somenumber);
...and be careful types match between format string and arguments
passed, and particularly that you passed *enough* arguments
C++:
cout << "Number is: " << somenumber << "\n";
...and there is no duplicated information that could get out-of-sync
(format and arguments).
It's just you can still use the C way if you want to.
Date: 31 Mar 2008 14:41:30
Message: <47f13e6a@news.povray.org>
>> C++ you have something less hellish than prinf() to play with...
> You do.
> C:
> C++:
That does indeed seem like at least *some* improvement...
(In C, almost every single time anybody touched printf(), the compiler
would utter something about "suspicious pointer conversion". To this day
nobody knows what that actually means... Even the tutors didn't seem to
know.)
Date: 31 Mar 2008 15:46:34
Message: <47f14daa$1@news.povray.org>
Assuming that you're writing this simulation for graphics purposes
rather than physical simulation where accuracy is a major concern
there's some other methods that you might consider.
First, a bit of terminology.  There's two main paradigms I'm aware of
which are used to simulate fluids: Eulerian and Lagrangian.  In the
Eulerian approach you consider what's happening in a small fixed piece
of space and look at how that changes based on the pieces of space
around it.  In the Lagrangian approach, on the other hand, you consider
what happens to pieces of the fluid as they move around.  The approach
you describe is then a Lagrangian approach.
As you've noticed, stability can be a problem when you integrate out
these sorts of equations to determine how the fluid should move over
time.  Changing the integration mechanism (such as to a Runge-Kutta
integrator) or decreasing the time-step can help this to a degree, but
there exist fluid simulation methods which are unconditionally stable.
That is, the simulation will never `blow up' no matter what you do, even
with very large time steps in the simulation.
Probably the simplest such technique is the "Stable Fluids" algorithm
invented by Jos Stam.  It uses some concepts from both the Eulerian and
Lagrangian viewpoints, and is this referred to as a "semi-Lagrangian"
method.  There's a very easy to ready paper on the algorithm that even
gives some code for how to implement it:
http://www.dgp.toronto.edu/people/stam/reality/Research/pdf/GDC03.pdf
The algorithm itself should be also pretty easy to implement, and is
also useful in a educational sense as it uses some interesting
techniques (such as, iirc, explicitly projecting the flow onto a
divergence-free space to achieve an incompressible flow).
There are also some fully particle based fluid simulation methods which
are more similar to yours in their apploach, but I'm not aware of any
which are as simple to implement as the stable fluids algorithm.  You
can check out some early examples:
http://graphics.ethz.ch/Downloads/Publications/Papers/2003/mue03b/p_Mue03b.pdf
http://www.cs.utah.edu/vissim/papers/ParticleFluid/ParticleFluidsLowRes.pdf
Or see a more recent paper on such a method at:
http://graphics.stanford.edu/~barta/research/adams-sig07.pdf
I suspect implementing one of these methods (or one of the newer
Eulerian / semi-Lagrangian ones) would be more work than you care to
spend, but I think stable fluids should be pretty reasonable to do
without a crazy amount of work.
Note, however, that all the stuff I mentioned is based on simulating the
Navier-Stokes equations.  If you're only looking for something that
looks sortof-kinda like a fluid rather than behaving as a proper fluid
then there's probably all sorts of shortcuts and hacks you can do, and
in this case I agree with scott's suggestions so I'd start playing
around with using a better integrator and/or adding some sort of
artificial dampening.
Chambers wrote:
> So, just for fun I'm writing a quick liquid simulation.  Because I like
> liquids, and I'm learning C#, that's why :)
> Anyway, I'm running into some problems with the simulation.  Namely, a
> certain instability.  Here's what I'm doing:
> For each particle, I loop through all the other particles (i=0..count-1,
> j=i+1..count), and check the distance between them (I use some
> additional bounding to speed things up, but that's not important to my
> problem here).  I compute the forces the two particles place on each
> other, and then add them to each particles' total "force" value.
> Once I'm done computing interactions, I loop through all the particles,
> add the force to the velocity, and reset the force to zero.
> The way I see it (and granted, I've never written a liquid sim before),
> there are two forces I need to deal with, pertaining to two stages that
> occur when liquid particles collide:
> 1) When the particles are farther apart, they attract each other.  This
> weak attraction would be the driving force behind surface tension.
> 2) When the particles are closer together, they push against each other.
>  This force must be much stronger than the first in order to maintain
> some volume.
> Now, so far I'm only actually implementing the second force above.
> However, what I see is that the particles tend to settle pretty quickly
> to the floor, and then they clump together.  Apparently, the particles
> on the outside "force" the particles in the middle of the clump closer
> and closer, until they suddenly explode and things go flying everywhere.
> I *think* the problem has to do with conservation of momentum.  I
> naively dealt with that by halving the force applied to each particle in
> a pair (one half of the force gets applied to each), but that's not
> quite right, is it?  The momentum of each particle shouldn't simply be
> split evenly with every individual particle it collides with... rather,
> I'll need to collect a list of interactions, and split this particle's
> momentum between *all* of those other particles...
> If anyone else here has dealt with similar issues, I'd appreciate
> knowing if I'm on the right track...
Date: 1 Apr 2008 00:27:05
Message: <47f1c7a9@news.povray.org>
scott wrote:
> The only difference is that in the evaluate function without the
> supplied derivative, you don't need to update the state, simply return
> the derivative at time t using the initial state.
>>       b = evaluate (v,p) t (dt/2) a
>>       c = evaluate (v,p) t (dt/2) b
>>       d = evaluate (v,p) t dt     c
>>       dv = (fst a + 2 * (fst b + fst c) + fst d) / 6
>>       dp = (snd a + 2 * (snd b + snd c) + snd d) / 6
>>     in (v + dt*dv, p + dt*dp)
> 5) Take a weighted average of all the derivatives you just caluclated,
> a-d, this gives the most accurate derivative.
> 6) Use this weighted average to actually advance your state by dt using
> normal Euler integration.
Here's a question: The derivative is based on the forces applied to the
current particle.  The only way these forces change is when a particle
collides with other particles (or ceases to collide).
So, for each of the above, am I to run a full collision detection?
...Ben Chambers
www.pacificwebguy.com
Date: 1 Apr 2008 00:32:47
Message: <47f1c8ff@news.povray.org>
BTW, that grasshopper thing... does that come from the old TV show "Kung
Fu"?  I could have sworn I saw it in a movie, though.  In fact, I asked
at a couple local video stores what movie it was, and nobody knew... :(
...Ben Chambers
Date: 1 Apr 2008 01:04:59
Message: <47f1d08b@news.povray.org>
> keep track of the state of the system while it's running?  Are you
AFAIK, yes, since they're defined as immutable.
In other words, Haskell doesn't have variables, only constants.
...Ben Chambers
Date: 1 Apr 2008 01:50:08
Message: <47f1db20$1@news.povray.org>
> A true Haskeller would define a notionally infinite list which notionally
> contains the entire state of the system at every future point in time.
> Examining the elements of this list causes the integration to actually be
> performed, and assuming you let go of the start of the list, the GC will
What's that like on performance though?  What would it be like if your state
block consisted of hundreds of 4D vectors, and the system was being updated
at 1000 Hz?  Would the GC be noticeable?
> notion of "time".)
Ah ok I see, so it's like you every variable is defined as "const" in the
C++ sense, you can't modify it.
>   animate state = do
>     dispaly state
>     animate new_state
I assume that the compiler is clever enough to not keep on the stack any
data that is not needed, ie old versions of state that are no longer needed.
If you attempted that method in C++ you would fill up the RAM very quickly
Date: 1 Apr 2008 01:57:49
Message: <47f1dced$1@news.povray.org>
Yes, inside the "acceleration" function, which is called from each
"evaluate" you put your code for calculating the acceleration.  This, in
your case, would presumably call the routine to check for collisions and
work out the forces for all the particles.
Note that you need to put all the positions and velocities for every
particle inside some state block and evaluate them in parallel using this
algorithm - you can't do one at a time it doesn't work like that.
You may say that this is 4x as much work per integration step, but it will
allow your time-step to be far more than 4x bigger and still be completely
stable.
