POV-Ray : Newsgroups : povray.off-topic : Who was looking for message-passing OS examples? : Re: OS what-ifs Server Time
8 Oct 2026 19:23:05 EDT (-0400)
  Re: OS what-ifs
Date: 13 Aug 2008 13:01:34
Message: <48a3136e@news.povray.org>
Invisible wrote:
> I don't know about Singularity and it's particular design goals, but the
> other day I was thinking: What would happen if you set out to design a
> new OS completely from scratch? What would that look like?
Dude? That's Singularity. :-)
Download the release and read the design notes, too.
http://codeplex.com/singularity
> What if we wanted to shake that up a litle? What might we decide to do
> differently?
Read the Singularity papers. This is exactly the premise they started with.
> How about if, say, the program could somehow "tell" the OS what
> arguments it actually accepts?
Yep! And what if, when you installed the program, it said "Sorry, but
this program requires the ability to connect to the USB printer, and you
don't have the right USB driver installed"?  Or "I can't let you install
telnet[1] until you have some sort of TCP/IP stack installed."
[1] Note that "install" means "make available for running." Of course
the uninstalled code can sit out there.
> Hey, let's go one better. The majority of CLI arguments are either
> on/off switches or filenames, right?
Only in a UNIX-like OS. The majority of arguments are instructions on
how to treat the other arguments, or references to something in the file
system namespace, there.
Once you can specify as arguments things beyond stuff represented as
strings, you get a whole nuther ball of wax. You're not stuck with
stdin, stdout, and stderr, for example. You can say "Hey, this program
needs an interrupt and two DMA channels to serve as a driver" for example.
> Once you start thinking this way, you start to see that actually, if we
> get the OS to interpret the arguments and pass *structured* data to the
> program [rather than just a blob of textual data], suddenly all sorts of
> interesting ideas become possible.
Read the bits about "compile-time reflection".  You really don't even
need to "tell" the OS this info, if it's reflected in the types your
system supports.
> If nothing else, it means that CLI arguments now have a standardised
> format, enforced by the OS, which makes it easier to learn how to
> operate each new program. Maybe all the program does is somehow list a
> bunch of settings it requires? Maybe then you can specify those either
> by CLI arguments, or a per-user or per-machine set of defaults? Maybe
> the OS has a database of these default settings somewhere? All kinds of
> interesting ideas to throw around.
Yep. Singularity calls it the "application manifest".  An application is
a first-class object, rather than being "a pile of files full of code".
> Maybe we can do something more interesting here? Maybe we can pass
> *structured* data around instead of just plain character streams?
Yes. Structured and typed, including a finite state machine to say when
it's OK to send and what you need to be ready to receive, checked at
compile time to ensure your code actually obeys the protocol, then
compiled down to native code and never checked again.
> Maybe we can do something better here too? Maybe we could have a small
> set of standard categories like "program bug", "resource exhaustion",
> "the network won't answer me", and provide a set of application-specific
> codes for the actual failures that a particular program can have?
Nah. You just answer back on the stream that goes to whoever invoked
you. :-)  Why would only the parent want to know how you exited?
> OS how to invoke different levels of logging? Just some ideas.
SDN 14 Tracing.pdf
> I suppose you could go down the route of having files contain structured
> data - but again you're going to get people arguing over the best way of
> structuring things.
Not any more than saying "you'll have people arguing about the best way
to represent structures".
You're still thinking UNIXy.  Get rid of the mindset that you have to
agree on data formats and embrace the mindset that you only have to
agree on APIs. You don't need to stick some Perl script in the middle of
a pipeline to transform your data. You present the data in a
semantically-meaningful way.
I.e., your directory isn't a file with 16-byte entries, the first two
bytes of which is a i-node number, and if non-zero, is followed by up to
14 bytes nul-terminated file name.
Your directory, instead, is a set of function calls like "read first",
"read next", "provide details". You don't have to come up with some
on-disk format to define.
> I've often thought about what would happen if, say, Smalltalk was the
> entire OS. Then the OS would "know about" the internal workings of each
> program to a large degree, and that opens up some rather interesting
> possibilities. Things like highly structured IPC and so forth. Trouble
> is, now you can only run stuff implemented in Smalltalk...
Yep. That's traditionally been the problem. Singularity does this, but
makes MSIL the bottom level for applications and such. So anything you
can compile into structured typed assembler language you can use. This
includes C#, F#, Iron Python, etc.
> In short, once you sit down and start to question the way OSes work
> today, you start to see that there are actually many things we could be
> doing differently - ranging from the conservative to the highly radical.
> (To me, really radical ideas are interesting to think about but probably
> wouldn't work too well in practice.)
It seems to be working well in practice. For example, one radical idea
(which I always thought would be a good idea) is to use safe languages
for everything. Singularity does this, and in so doing, can run
everything in Ring 0 and with no hardware memory protection. It actually
runs faster, because it takes less time to enforce array bound checks
(for example) than it does to go thru the memory mapping hardware on
every access to memory. Turning off memory protection more than makes up
for doing it in software. And then, doing things like scheduling
threads, adding space to the thread stack, allocating and freeing memory
blocks ... all that is in user space, because the compiler can inline
the kernelesque instructions.
> Heh, if *I* had 3 years to sit and write an OS, maybe I could experiment
> with a few of these ideas? ;-)
Read the papers first. It's exactly what I've been wanting to do myself,
except they figured out what seems a really good way of doing it.
I like the stuff on permissions, too. Stuff like "setuid" not being a
privileged operation is kind of funky. :-)
Really, all the stuff you're speculating about, they've written about in
detail and implemented. It's very cool.  I highly suggest if the idea
"what if we started over in *this* millenium?" interests you, you read
the literature they've published. :)
  Ever notice how people in a zombie movie never already know how to
  kill zombies? Ask 100 random people in America how to kill someone
  who has reanimated from the dead in a secret viral weapons lab,
  and how many do you think already know you need a head-shot?
