POV-Ray : Newsgroups : povray.object-collection : Contribution Questions Server Time
7 Dec 2025 22:24:57 EST (-0500)
  Contribution Questions (Message 1 to 5 of 5)
Subject: Contribution Questions
Date: 1 Feb 2008 08:35:01
Message: <web.47a31ef65144cb2ce5ce3790@news.povray.org>
Hello,
  I was wondering if there was any guidance available on a couple points when
contributing to the object collection.  I've got a lot of things that I'd like
to potentially contribute.  However many of the include files I've created for
myself are interdependent.  I'm a big fan of modularity and reusability, so if
a piece of an object or macro can be generalized I'll usually split it out and
put it into a separate include file (generally organized by category).  So what
would be a suggested "best practice" for adapting these to the object
collection?  I don't think just bundling all the dependent files into a big
lump would be good, when they could easily each be their own submission.
However, the collection site makes it clear that prerequisites are undesirable,
so would it be best to duplicate the needed pieces of code for each object
submitted?  This would lead to much more redundancy, but perhaps that isn't the
end of the world.
  In a similar vein, is there a preference in groupings of objects vs single
objects?  For example I have (as I'm sure most POVers do) an include with a
number of basic shapes.  Would it be better to split out each shape into its
own include, or keep them together as a collection?
  Thanks for any input.
-The Mildly Infamous Blue Herring
Subject: Re: Contribution Questions
Date: 1 Feb 2008 10:47:26
Message: <47a33f0e$1@news.povray.org>
"Blue Herring" <bhe### [at] tinfoilcatcom> wrote in message
news:web.47a31ef65144cb2ce5ce3790@news.povray.org...
> Hello,
> when
> like
> for
> so if
> and
> what
> collection?
There are no hard and fast rules because, as you've identified, there are
natural conflicts that arise, so each case requires a degree of judgement.
Also, as the collection grows, I expect thinking on this subject to evolve.
My current thoughts are as follows:
1. You can submit a set of objects that are usually used together as a
single bundle. If you do you should add keywords for all the objects and
summarise that fact in the description. I don't think that downloading a
bundle of 10 objects to use only 3 of them is so bad. If you wish you can
also submit an HTML page with images to describe how the objects are grouped
and used.
2. If objects can readily be split out and used completely independently
then it probably makes sense to make separate submissions. You can add notes
to the description or to an accompanying HTML page to describe how to use
the objects in combination with other objects from the collection. e.g. I've
started referencing the ScaleConvert macro from my documentation rather than
incorporating anything fancy to handle different units.
3. It's also possible to do both and to live with a degree of duplication.
For example, I've recently been working on a bottle with a label. The label
turned out more complicated than the bottle, with multiple overlayed
pigments containing text and images, so I plan to work further on that and
to also submit a separate label generation macro.
The licensing enables anyone in the future to rearrange the grouping of
objects to meet the evolving needs of the community. It is possible that, as
the collection grows, people will combine existing objects into packages,
potentially with changes to make them work better together. Alternatively a
single part of a bundle of objects could be split out and developed
independently.
> undesirable,
> isn't the
> end of the world.
At this stage I'd argue that ease of use is more important than worrying
about a degree of redundancy. Although the site permits prereqs to be
listed, I believe that building lists of prereq chains is undesirable
because it makes it more complicated for people to use stuff.
> single
> a
> its
A smaller number of files is easier to submit and to maintain, though it's
logical to split out and group some things separately. If you've got
something that takes a long time or lots of memory to parse and that isn't
needed every time, then it's good to split that out. On the other hand, if
your basic shapes file only takes a tiny fraction of a second to parse then
it's probably better to include it in a single file rather than have POV-Ray
open a succession of files when you do want to use more than one shape.
You might also choose to split something out to make it easier to replace or
to support alternatives.
The main things to worry about when preparing objects are the naming
standards. These are intended to enable people to download different objects
and use them together without running into naming conflicts which can be a
devil to sort out in code you've not written.
That's been a bit of a wordy response I'm afraid. Has it been any help?
Chris B.
p.s. It is possible to use the file_exists function to check whether another
object has also been downloaded and to skip it, or incorporate a simplified
shape if it hasn't. This is a good way of removing hard-wired
interdependencies, while enabling people to use objects in combination if
they already have a copy.
Date: 3 Feb 2008 13:07:47
Message: <47a602f3$1@news.povray.org>
If one macro requires another macro that you wrote, put them both into
the same file.  That's as good a solution as we're going to see.
John
Date: 8 Feb 2008 08:20:01
Message: <web.47ac56b0a44846eace5ce3790@news.povray.org>
Yes, actually its quite helpful.  Thanks very much for the response.  I can see
also some advantages of making the objects self-contained, so they won't change
even if another package changes in the future.
Good thinking.  Not sure if I have anything that will make this necessary, but a
good idea if I run into it.
Hopefully I'll be able to get to submitting some things soon.
Date: 8 Feb 2008 08:27:27
Message: <47ac58bf$1@news.povray.org>
news:web.47ac56b0a44846eace5ce3790@news.povray.org...
I look forward to it. I've been keeping one eye on those candlesticks  --
:o)
Chris B.
