![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
One of the problems I've noticed with object downloads is that, for
simple objects, its often easier to make it myself using CSG while, for
complex objects, the object doesn't quite fit my needs.
Really, what I would like are collections of themed objects, each of
which is non-trivial (ie, it would take more than half an hour of coding
to create), and with enough variety that I could find something in there
to fit my needs.
Naturally, I have no time to create such collections. I'm fairly
certain that most people on this NG don't have the time to create a
complete collection, either.
So, I would like to try an experiment: A group collaboration. We'll
pick a topic (probably something like "tables" or "chairs" or even
"writing utensils"), and several people will each contribute one or two
items to it. The result will be published on the library site under a
group credit. If we like the results, we can continue to do such
collections to help beef up our library.
But before I run off all gung-ho, is anyone else interested in trying
this with me?
...Ben Chambers
www.pacificwebguy.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> items to it.
IMO those objects should also be parametrized so that you can change
their geometry with identifiers (or macro parameters).
For example, you might find a table model which is just perfect, except
that its legs are too tall. There should be an identifier you can declare
before the #include (or before calling the macro) which changes the length
of the legs.
In the #include file this can be implemented eg. like this:
#ifndef SOMEID_TABLE_LEG_LENGTH
#declare SOMEID_TABLE_LEG_LENGTH = 5;
or, alternatively:
#local SOMEID_TABLE_LEG_LENGTH = 5;
#ifdef SOMEID_TABLE_LEG_FACTOR
SOMEID_TABLE_LEG_LENGTH * SOMEID_TABLE_LEG_FACTOR;
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> this with me?
this sounds a lot of fun! A contest with no winners, really. It could
definitely boost the povray object collection. I'm in!
To make it more interesting, how about adding the objects to a scene? We begin
with a basic scene with no objects -- say, a restroom -- and people begin
adding chairs, tables, decorative stuff on tables put there by other users,
etc...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> this with me?
> etc...
Sure, but the point is really just to add more (and more useful) things
to the object collection.
We could do a variety of shoes, for instance - or anything that goes in
a bathroom. We could do types of trees, or plants from an herb garden.
As long as
a) the objects are varied enough that you'll (probably) find something
useful for your scene, and
b) the objects are detailed enough that it's not easier to just make
your own,
then we should be good.
...Ben Chambers
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> to fit my needs.
> this with me?
Not bad, not bad. Sounds like a good idea.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>items to it.
> of the legs.
> #end
> or, alternatively:
> #end
Can be, but do not have to be. Maybe just point out to contributors
that more flexibility = more popularity, and leave it at that.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> this with me?
>> We begin
>> users,
>> etc...
> As long as
> your own,
Yeah, both approaches have potential but I agree with you that a narrow
focus is the best place to start. Then see if the broad focus approach
would work.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> this with me?
Count me in, too.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
For some of my more recent prop items I have striven to make as many of
the parameters dependent on settings that can come from the calling code.
It's simple:
#ifndef(LegRadius)
#local LegRadius=1;
and then write the SDL for the object to use LegRadius instead of some
value written into every sphere, cylinder, and torus statement in the
Leg object.
The dimensions of objects like furniture, eating and drinking utensils,
and even many kinds of vehicles can be greatly expanded in this way.
Another .INC file I commonly use creates a picture that can be hung on a
wall. The corners of the frame, and the edges of the frame, are
specified by means of creating one object for each, which are then
scaled, rotated, and translated to create the frame; the content of the
picture is accomplished with a texture specification (so that the
picture can be a mirror with just one change to the calling code). The
width and height of the picture are also set by the calling code, as well.
The textures are the most easily changed setting. Every texture used in
an object should be controlled by code of this form:
#infdef(CasingTexture)
#local CasingTexture = texture { /* default texture code here */ }
The immediate effect of all this is that an object that is useful in the
early stage of scene layout can be specified with a minimum of parameter
settings, and then quickly refined later in the process.
John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If the topic is tables, I have over a dozen different ones to
contribute, all created for various IRTC entries over the years.
John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
