POV-Ray : Newsgroups : povray.newusers : rendering images in reverse Server Time
5 Feb 2025 05:43:59 EST (-0500)
  rendering images in reverse (Message 1 to 5 of 5)
Subject: rendering images in reverse
Date: 30 Mar 2022 00:15:00
Message: <web.6243d848b75db2b09cded0992eac0897@news.povray.org>
I want povray to produce images in both correct and reversed aspect(mirror).
I thought I saw the keyword "invert" somewhere in the documentation but maybe it
was a dream. how can I reverse my output images or get my camera to behave like
a  mirror?
Q) Why?
A) Because <REASONS>
Subject: Re: rendering images in reverse
Date: 30 Mar 2022 06:30:00
Message: <web.624430632398ca21f9dae3025979125@news.povray.org>
> a  mirror?
> Q) Why?
suppose you want to reverse everything left-right.
instead of "right x" use "right -x" to reverse the camera view frustrum vector.
https://wiki.povray.org/content/Reference:Camera
Date: 30 Mar 2022 07:02:10
Message: <624438b2$1@news.povray.org>
>> a  mirror?
>> Q) Why?
To mirror an object (with image map):  scale<1,1,-1>
m@
Date: 4 Apr 2022 18:50:00
Message: <web.624b750f2398ca24cef624e6e066e29@news.povray.org>
That is simple and elegant! And never occurred to me. It also works correctly
even if the camera has an added 'rotation', like...
  perspective
  location  <-.15, 1.48, -2>
  look_at   <.35, 1.48,  0>
  right     -x*image_width/image_height
  angle 29
  rotate 45*y
I'm thinking that it would be nice to be able to render *both* standard and
reversed views at the same time, side by side in the same image, but I have no
idea how it could be done. I seem to recall that such a dual-camera(?) render
may have been explained in an old newsgroup post... or maybe it's just my faulty
old memory playing tricks on me...
Date: 5 Apr 2022 07:05:00
Message: <web.624c21b42398ca21f9dae3025979125@news.povray.org>
> camera {
>   perspective
>   angle 29
>   rotate 45*y
Yeah, well, when I've screwed up the camera setup and/or position enough times,
I get to have a deeper appreciation of my little oopsies.  I've also had to
convert between the z-up and y-up vector spaces when modeling things, so that
"helped" too.  ;)
Playing with transforms and basis vectors let me sorta flesh all that out a bit.
Try:
up <1, 1, 0>
That might have been a feature in Uberpov or Megapov ...
What I guess you could do is create a whole scene inside of a union:
#declare Scene = union {...}
And then do:
#declare Left  = object {Scene translate -x*VALUE}
#declare Right = object {Left scale <-1, 1, 1>}
object {Left}
object {Right}
To get both "views" in the same render.
