![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I can't get the example in the docs to work, or the candle flame example from F.
Lohmueller's site. I've probably tried 5 others.
I've been at this for hours, and I'm done searching and testing.
I'm clearly missing something.
[0 rgb 0] wipes out the sphere completely - no color, no "light"
THAT drove me crazy for most of the time.
Commenting that out finally gave me a semitransparent sphere of the next color
in the map. Adding absorbing media just makes it look more solid.
I don't get any sort of transparent glowing effect like shown in the examples
for this copy-and pasted code. The first is from the docs, the second is from
F. Lohmueller's candle flame example.
Why?
box {<-300, 0, 100>, <300, 400, 101> pigment {Gray50}}
//sphere {<0, 0, 0> 100 pigment {rgbf <0.6, 0, 0, 0.9>} translate y*270}
//light_source {<0, 270, 10> color rgb <1, 1, 1>}
sphere {<0, 270, 0>, 100
pigment {rgbt 1} hollow
interior {
media {
emission 1
//intervals 3
//samples 1, 1
density {spherical
density_map {
//[0 rgb 0]
[0.0 rgb <1,0,0>]
[0.8 rgb <1,1,0>]
[1 rgbf 1]
} // end density map
} // end density block
} // end media block
//media {absorption 0.2}
} // end interior
} // end sphere
sphere {<0, 270, 0>, 100 hollow
pigment {color rgbf <1, 1, 1, 1>}
finish { ambient 0 diffuse 0 }
interior {
media {
emission color rgb<1.0,0.75,0.1>*1.75
intervals 9
samples 1, 20
confidence 0.9999
variance 1/100
density {spherical
ramp_wave
turbulence 0.15
color_map {
//[0.0 color rgb <0.0,0.0,0.0>]
[0.6 color rgb <0.8,0.3,0.0>]
[0.9 color rgb <1.0,0.8,0.3>]
[1.0 color rgb <1.0,1.0,0.1>]
} // end color_map
scale <1,2.5,1>
} // end of density
} // end of media
} // end interior
} // end sphere
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
For media *always* use intervals 1 (default; like method 3) and *only*
one parameter for samples (second parameter ignored). Confidence and
variance are default values so you can comment them out.
Try this for the Lohmueller flame:
sphere {<0, 2.7, 0>, 1 hollow
interior {
media {
intervals 1
samples 100
//confidence 0.9999
//variance 1/100
density {spherical
ramp_wave
turbulence 0.15
color_map {
} // end color_map
scale <1,3.5,1>
} // end of density
} // end of media
} // end interior
} // end sphere
or this for the doc's flame:
interior {
media {
emission 1
intervals 1
samples 100
density {spherical
density_map {
[0 rgb 0]
[0.0 rgb <1,0,0>]
[0.8 rgb <1,1,0>]
[1 rgbf 1]
scale <1,3.5,1>
} // end interior
} // end sphere
Both work for me. Note that I scaled the spheres down! I also
uncommented the [0 rgb 0] lines of course.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks as always, Thomas - but I seem to be having some fundamental problem
that's preventing it from working. Your code gives me the same troublesome
behaviour when _I_ run it.
POV-Ray 3.7, WinXP, 2GB, 640x480 aa0.3, +q9
Full code below.
#version 3.7;
global_settings{ assumed_gamma 1.0 }
#include "debug.inc"
Set_Debug (true)
#include "textures.inc"
#include "glass.inc"
#include "metals.inc"
#include "golds.inc"
#include "stones.inc"
#include "woods.inc"
#include "shapes.inc"
#include "shapes2.inc"
#include "functions.inc"
#include "math.inc"
#include "transforms.inc"
#declare Feet = 12;
#declare Camera_Position = < 0, 150, -50*Feet> ; // front view
#declare Camera_Look_At = < 0, 150, 0.00> ;
#declare Camera_Angle = 65 ;
camera { location Camera_Position
angle Camera_Angle
look_at Camera_Look_At
light_source {<25*Feet, 100*Feet, -100*Feet> color rgb <1, 1, 1>*0.4}
sky_sphere{ pigment{ gradient <0,1,0>
color_map{ [0 color rgb <1, 1, 1> ]//White
[0.4 color rgb <0.14, 0.14, 0.56>]//~Navy
[0.6 color rgb <0.14, 0.14, 0.56>]//~Navy
[1.0 color rgb <1, 1, 1> ]//White
scale 2 }
} // end of sky_sphere
sphere {<0, 270, 0>, 10 hollow
interior {
media {
intervals 1
samples 100
//confidence 0.9999
//variance 1/100
density {spherical
ramp_wave
turbulence 0.15
color_map {
} // end color_map
scale <1,3.5,1>
} // end of density
} // end of media
} // end interior
} // end sphere
interior {
media {
emission 1
intervals 1
samples 100
density {spherical
density_map {
[0 rgb 0]
[0.0 rgb <1,0,0>]
[0.8 rgb <1,1,0>]
[1 rgbf 1]
} // end interior
} // end sphere
interior {
media {
intervals 9
samples 1, 20
confidence 0.9999
variance 1/100
density {spherical
ramp_wave
turbulence 0.15
color_map {
} // end color_map
scale <1,2.5,1>
} // end of density
} // end of media
} // end interior
} // end sphere
interior {
media {
emission <1,1,1>
intervals 3
samples 1, 1 //min,max
} // end of media ---
} // end of interior
//translate <0, 1.00, 0>
} //----- end of sphere
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I think that the main problem resides in the definition of the sphere.
Try this:
sphere {<0, 0, 0>, 100 hollow
interior {
media {
intervals 1
samples 100
//confidence 0.9999
//variance 1/100
density {spherical
ramp_wave
turbulence 0.15
color_map {
} // end color_map
scale <1,3.5,1>*10
} // end of density
} // end of media
} // end interior
translate <0,270,0>
} // end sphere
This initialises the sphere at the origin and only translates it to its
final position when everything is in place. Also increase the radius to
make the sphere visible at all. Somehow the scale of the density needs
to be scaled up too.
However, I am not too sure how the flame should look like in the end.
Something you can do also is change the turbulence value to <0.15, 1.0,
0.15>.
With all these settings I get the image I upload to p.b.i.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Try this:
Tried. Works. _Thank You_
I was losing my mind.
Right-o. I need to really discipline myself to do the Start-at-the-Origin
thing.
It avoids so many easily preventable problems.
> Also increase the radius to make the sphere visible at all. Somehow the scale
> of the density needs to be scaled up too.
The large scale is just a hold-over from the lathe / prism objects that I made
in EPspline, and finally got correctly oriented. THAT was educational.
Likely the radius will wind up being more like _4_ instead of 100.
I was really just trying to get _anything_ to show up, and figured that once it
was working, I could dabble with the details. Hopefully something decent will
come of all this to make it onto tc-rtc...
Thanks again for the expert assistance!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Additional afterthought:
I think that you will obtain the best results by always defining the
object at the origin and with unit scale. Only at the end of the built
do you scale the object and translate it to its correct position. This
is how it is done in the file candle_flame_4.pov .
Note: particularly when using scattering media, you need to divide the
scattering by the used scale for the object in order to keep the same
results. This is explained in the docs btw. For instance:
sphere {0, 1
pigment {rgbt 1}
hollow
interior {
media {
scattering {1, <0.5,0.4, 0.3>/MyScale}
scale MyScale
I am not sure, but I think this gives also better results with emission.
With density, it is more complicated and you have to experiment.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You're still using WinXP? Microsoft is no longer issuing updates for WinXP.
If^H^H When some hacker finds another security hole, it will not be fixed.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Considering my ex-wife stole or destroyed everything I had, I'm lucky I've even
got the little laptop that I have. You do what you can with what you've got.
I'll probably switch over to Linux or a dual-boot once things get more ...
stable.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
