POV-Ray : Newsgroups : povray.newusers : Very big time difference of a render Server Time
1 May 2026 15:47:12 EDT (-0400)
  Very big time difference of a render (Message 1 to 10 of 24)
Subject: Very big time difference of a render
Date: 17 Jun 2013 02:25:01
Message: <web.51beaaafb66eb0d77a3e03fe0@news.povray.org>
In documentation there is an example
 global_settings
 { photons
   { count 20000
     media 100
 camera { location <14.9, 1, -8> look_at -z angle 70 }
 light_source { <10,100,150>, 1 }
 background { rgb <0.3, 0.6, 0.9> }
 // A dim light source inside the room which does not
 // interact with media so that we can see the room:
 light_source { <14, -5, 2>, 0.5 media_interaction off }
 // Room
 union
 { difference
   { box { <-11, -7, -11>, <16, 7, 10.5> }
     box { <-10, -6, -10>, <15, 6, 10> }
     box { <-4, -2, 9.9>, <2, 3, 10.6> }
   box { <-1.25, -2, 10>, <-0.75, 3, 10.5> }
   box { <-4, 0.25, 10>, <2, 0.75, 10.5> }
   pigment { rgb 1 }
 // Reflective floor:
 box
 { <-10, -5.99, -10>, <15, -6, 10>
   pigment { rgb 1 }
   finish { reflection <0.5, 0.4, 0.2> }
   photons { target reflection on }
 // Scattering media box:
 box
 { <-5, -6.5, -10.5>, <3, 6.5, 10.25>
   pigment { rgbt 1 } hollow
    photons { pass_through }
    interior
    { media
       { scattering { 1, 0.07 extinction 0.01 }
       samples 30
Render time: 11 m
I created a similar scene in Blender, using mesh2
//--Export to Povray from Blender--
#version 3.7;
#include "functions.inc"
global_settings {
    photons {
        count 20000
        media 100
background {rgbt<0.0509, 0.0509, 0.0509, 0>}
//--Material Definitions--
#declare T_Map_Cube = pigment {color rgb<0,0,0>}
#declare Texture_2_Cube = pigment {color rgb<0,0,0>}
#declare T_Map_Cube_001 = pigment {color rgb<0,0,0>}
#declare Texture_2_Cube_001 = pigment {color rgb<0,0,0>}
#declare T_Map_Plane = pigment {color rgb<0,0,0>}
#declare Texture_2_Plane = pigment {color rgb<0,0,0>}
#declare T_Map_Plane_001 = pigment {color rgb<0,0,0>}
#declare Texture_2_Plane_001 = pigment {color rgb<0,0,0>}
#declare shader_Material = finish {  //translation of spec and mir levels for
when no map influences them
    brilliance 2
    specular 0
    roughness 0.0001
    diffuse 0.8 0
    ambient <0, 0, 0>
    emission 0
    conserve_energy
#declare Texture_1_Cube = texture {pigment {color rgbft<0.8,0.8,0.8,0,0>}
finish{shader_Material}}
#declare shader_Material_004 = finish {  //translation of spec and mir levels
for when no map influences them
    diffuse 0.8
    phong 70.0
#declare Texture_1_Cube_001 = texture {pigment {color rgbt 1}}
#declare shader_Material_002 = finish {  //translation of spec and mir levels
    brilliance 2
    specular 0.5
    roughness 0.01
    diffuse 0.8 0
    ambient <0, 0, 0>
    emission 0
    conserve_energy
    reflection {
        0.287        metallic 0    }
#declare Texture_1_Plane = texture {pigment {color rgbft<0.8,0.6416,0.1664,0,0>}
finish{shader_Material_002}}
#declare shader_Material_003 = finish {  //translation of spec and mir levels
    brilliance 2
    specular 0
    roughness 0.0001
    diffuse 1 0
    ambient <0, 0, 0>
    emission 1.76
    conserve_energy
#declare Texture_1_Plane_001 = texture {pigment {color rgbft<0.8,0.8,0.8,0,0>}
finish{shader_Material_003}}
#declare T_Mix_1_Cube = Texture_1_Cube
#declare T_Mix_2_Cube = Texture_2_Cube
#declare T_Mix_1_Cube_001 = Texture_1_Cube_001
#declare T_Mix_2_Cube_001 = Texture_2_Cube_001
#declare T_Mix_1_Plane = Texture_1_Plane
#declare T_Mix_2_Plane = Texture_2_Plane
#declare T_Mix_1_Plane_001 = Texture_1_Plane_001
#declare T_Mix_2_Plane_001 = Texture_2_Plane_001
//--Mesh objects--
#declare Cube_001 =
mesh2 {
    vertex_vectors {
        8,
        <0.958881, 1.522728, -0.958881>,
        <-0.958881, 1.522728, -0.958881>,
        <-0.958881, -2.315529, -0.958881>,
        <0.958881, -2.315529, -0.958881>,
        <0.958882, 1.522728, 0.958881>,
        <0.958881, -2.315530, 0.958881>,
        <-0.958882, -2.315529, 0.958881>,
        <-0.958881, 1.522728, 0.958881>
    normal_vectors {
        6,
        <0.000000, 0.000000, -1.000000>,
        <-0.000000, -1.000000, -0.000000>,
        <1.000000, -0.000000, 0.000000>,
        <-1.000000, 0.000000, -0.000000>,
        <0.000000, 1.000000, 0.000000>,
        <0.000000, -0.000000, 1.000000>
    texture_list{1, texture { pigment_pattern { T_Map_Cube_001 }
            texture_map {
                [0.0 T_Mix_1_Cube_001]
                [1.0 T_Mix_2_Cube_001]
    face_indices {
        12,
        <0,1,2>, 0,0,0,
        <0,2,3>, 0,0,0,
        <4,5,6>, 0,0,0,
        <4,6,7>, 0,0,0,
        <3,2,6>, 0,0,0,
        <3,6,5>, 0,0,0,
        <2,1,7>, 0,0,0,
        <2,7,6>, 0,0,0,
        <1,0,4>, 0,0,0,
        <1,4,7>, 0,0,0,
        <4,0,3>, 0,0,0,
        <4,3,5>, 0,0,0
    normal_indices {
        12,
        <5,5,5>,
        <5,5,5>,
        <0,0,0>,
        <0,0,0>,
        <4,4,4>,
        <4,4,4>,
        <2,2,2>,
        <2,2,2>,
        <1,1,1>,
        <1,1,1>,
        <3,3,3>,
        <3,3,3>
    hollow
    interior {
         media {
              scattering { 1,
                  <0.08353, 0.08353, 0.08353>
               extinction 4.871 }
              samples 256
    photons{ pass_through }
#declare Plane_001 =
mesh2 {
    vertex_vectors {
        4,
        <1.000000, -1.000000, 0.000000>,
        <-1.000000, -1.000000, 0.000000>,
        <1.000000, 1.000000, 0.000000>,
        <-1.000000, 1.000000, 0.000000>
    normal_vectors {
        1,
        <0.000000, 0.000000, 1.000000>
    texture_list{1, texture { pigment_pattern { T_Map_Plane_001 }
            texture_map {
                [0.0 T_Mix_1_Plane_001]
                [1.0 T_Mix_2_Plane_001]
    face_indices {
        2,
        <1,0,2>, 0,0,0,
        <1,2,3>, 0,0,0
    normal_indices {
        2,
        <0,0,0>,
        <0,0,0>
    interior {
        ior 1.000000
        caustics 0.1
    photons{    }
#declare Plane =
mesh2 {
    vertex_vectors {
        4,
    normal_vectors {
        1,
    texture_list{1, texture { pigment_pattern { T_Map_Plane }
            texture_map {
                [0.0 T_Mix_1_Plane]
                [1.0 T_Mix_2_Plane]
    face_indices {
        2,
        <1,0,2>, 0,0,0,
        <1,2,3>, 0,0,0
    normal_indices {
        2,
        <0,0,0>,
        <0,0,0>
    interior {
        ior 1.072000
    photons{
        target 1
        reflection on
#declare Cube =
mesh2 {
    vertex_vectors {
        24,
        <1.000000, 1.000000, -1.000000>,
        <1.000000, -2.356648, -1.000000>,
        <-1.000000, -2.356648, -1.000000>,
        <-1.000000, 1.000000, -1.000000>,
        <1.000000, 0.999999, 1.000000>,
        <0.999999, -2.356648, 1.000000>,
        <-1.000000, -2.356647, 1.000000>,
        <-1.000000, 1.000000, 1.000000>,
        <1.000000, 0.242933, -0.270760>,
        <1.000000, -0.242933, -0.270760>,
        <1.000000, 0.242933, 0.556969>,
        <1.000000, -0.242933, 0.556969>,
        <0.958881, 0.958881, -0.958881>,
        <-0.958881, 0.958882, -0.958881>,
        <0.958882, 0.958881, 0.958881>,
        <-0.958881, 0.958881, 0.958881>,
        <0.958881, 0.242933, -0.270760>,
        <0.958881, 0.242933, 0.556969>,
        <0.958881, -0.242933, -0.270760>,
        <0.958881, -0.242933, 0.556969>
    normal_vectors {
        20,
        <1.000000, -0.000000, -0.000000>,
        <-0.000000, -0.000000, 1.000000>,
        <0.000001, 0.000000, -1.000000>,
        <1.000000, 0.000000, 0.000000>,
        <0.000000, -0.000000, 1.000000>,
        <-1.000000, 0.000000, 0.000000>,
    texture_list{1, texture { pigment_pattern { T_Map_Cube }
            texture_map {
                [0.0 T_Mix_1_Cube]
                [1.0 T_Mix_2_Cube]
    face_indices {
        44,
        <0,1,2>, 0,0,0,
        <0,2,3>, 0,0,0,
        <4,7,6>, 0,0,0,
        <4,6,5>, 0,0,0,
        <0,4,10>, 0,0,0,
        <0,10,8>, 0,0,0,
        <1,5,6>, 0,0,0,
        <1,6,2>, 0,0,0,
        <2,6,7>, 0,0,0,
        <2,7,3>, 0,0,0,
        <4,0,3>, 0,0,0,
        <4,3,7>, 0,0,0,
        <1,0,8>, 0,0,0,
        <1,8,9>, 0,0,0,
        <5,1,9>, 0,0,0,
        <5,9,11>, 0,0,0,
        <4,5,11>, 0,0,0,
        <4,11,10>, 0,0,0,
        <12,13,14>, 0,0,0,
        <12,14,15>, 0,0,0,
        <16,17,18>, 0,0,0,
        <16,18,19>, 0,0,0,
        <12,20,21>, 0,0,0,
        <12,21,16>, 0,0,0,
        <15,14,18>, 0,0,0,
        <15,18,17>, 0,0,0,
        <14,13,19>, 0,0,0,
        <14,19,18>, 0,0,0,
        <16,19,13>, 0,0,0,
        <16,13,12>, 0,0,0,
        <15,22,20>, 0,0,0,
        <15,20,12>, 0,0,0,
        <17,23,22>, 0,0,0,
        <17,22,15>, 0,0,0,
        <16,21,23>, 0,0,0,
        <16,23,17>, 0,0,0,
        <8,10,21>, 0,0,0,
        <8,21,20>, 0,0,0,
        <11,9,22>, 0,0,0,
        <11,22,23>, 0,0,0,
        <10,11,23>, 0,0,0,
        <10,23,21>, 0,0,0,
        <9,8,20>, 0,0,0,
        <9,20,22>, 0,0,0
    normal_indices {
        44,
        <10,10,10>,
        <10,10,10>,
        <8,8,8>,
        <8,8,8>,
        <1,1,1>,
        <1,1,1>,
        <12,12,12>,
        <12,12,12>,
        <13,13,13>,
        <13,13,13>,
        <15,15,15>,
        <15,15,15>,
        <5,5,5>,
        <5,5,5>,
        <11,11,11>,
        <11,11,11>,
        <18,18,18>,
        <18,18,18>,
        <8,8,8>,
        <8,8,8>,
        <10,10,10>,
        <10,10,10>,
        <14,14,14>,
        <14,14,14>,
        <17,17,17>,
        <17,17,17>,
        <19,19,19>,
        <19,19,19>,
        <4,4,4>,
        <4,4,4>,
        <9,9,9>,
        <9,9,9>,
        <6,6,6>,
        <6,6,6>,
        <16,16,16>,
        <16,16,16>,
        <0,0,0>,
        <0,0,0>,
        <7,7,7>,
        <7,7,7>,
        <3,3,3>,
        <3,3,3>,
        <2,2,2>,
        <2,2,2>
    interior {
        ior 1.000000
//----Blender Object Name:Cube----
object {
    Cube
    matrix <3.000000, 0.000000, 0.000000,  0.000000, -0.000000, -3.000000,
0.000000, 1.868832, -0.000000,  0.000000, 0.000000, 0.000000>
//----Blender Object Name:Cube_001----
object {
    Cube_001
    matrix <3.000000, 0.000000, 0.000000,  0.000000, -0.000000, -1.949719,
0.000000, 1.868832, -0.000000,  0.000000, 0.000000, 0.098744>
//----Blender Object Name:Plane_001----
object {
    Plane_001
    matrix <5.338935, 0.000000, 0.000000,  0.000000, -0.000000, -5.338935,
0.000000, 5.338935, -0.000000,  -2.303558, 1.657419, 1.990753>
//----Blender Object Name:Plane----
object {
    Plane
    matrix <3.974819, 0.000000, 0.000000,  0.000000, -0.000000, -5.989536,
0.000000, 3.974819, -0.000000,  0.000000, -1.738466, 1.724134>
light_source {
    < 0,0,0 >
    color rgb<2, 2, 2>
    matrix <1.000000, 0.000000, 0.000000,  0.000000, -0.000000, -1.270558,
0.000000, 1.000000, -0.000000,  0.001291, 1.166238, -0.000001>
light_source {
    < 0,0,0 >
    color rgb<2.72, 2.72, 2.72>
    fade_distance 14.999991
    fade_power 2
    matrix <-0.290865, -0.055189, -0.955171,  -0.771101, 0.604525, 0.199883,
0.566393, 0.794672, -0.218391,  11.125839, 6.465459, -0.060348>
    perspective
    location  <0, 0, 0>
    look_at  <0, 0, -1>
    right <-1.7777777777777777, 0, 0>
    up <0, 1, 0>
    angle  65.920597
    rotate  <-1.953649, 0.934839, -0.000000>
    translate <0.023297, -0.464718, 5.683205>
Render time very long!!!! 10 hours
In what reason of such difference? 11 minutes against 10 hours
Subject: Re: Very big time difference of a render
Date: 17 Jun 2013 03:50:01
Message: <web.51bebec691e1715f520168c30@news.povray.org>
> Render time: 11 m
Maybe you look at this simple example:
background { rgb <0.3, 0.6, 0.9> } versus background {rgbt<0.0509, 0.0509,
0.0509, 0>}
I think that calculatin inside POV-Ray using a Integer is faster then a Float.
But i could be wrong
Date: 17 Jun 2013 10:35:00
Message: <web.51bf1d9b91e1715f7a3e03fe0@news.povray.org>
> 0.0509, 0>}
No! Povray bad work with mesh
All vertices coords - float. They can't be presented int
Date: 17 Jun 2013 17:20:57
Message: <51bf7db9@news.povray.org>
>> Render time: 11 m
mesh or mesh2 are realy the same, internaly, once parsed.
> 0.0509, 0>}
Both use floats. It don't mather how many decimal digits there are,
internaly, it's always a double precision float.
POV-Ray always use floats, never integers. Rendering rgb 1 and
rgb<1,13/47,0.013752168> take exactly the same time.
In the purely POV-Ray scene, you use simple pigments and textures.
The blender textures use pigment_pattern with a texture_map. Those take
longer to render.
Your light_source is a basic point_light, blender's light_source is a
fading one. The fading light_source is a little slower as the distance
must be calculated and the fading applied.
For your media, you use samples 30, and you use a very small extinction
value of 0.1.
For the blender's media, it's samples 256, and use a HUGE, I may say
insane, extinction value of 4.871 !
If your mesh contains long and narrow triangles, those can't be bounded
effeciently. Subdividing the mesh, or not decimating it, can make it
render faster.
Date: 18 Jun 2013 03:14:38
Message: <51c008de$1@news.povray.org>
On the contrary, POV-Ray works perfectly with meshes. It is the quality
of the meshes that may be a problem, for instance when triangle vertices
are not welded.
I recommend that - before rendering in POV-Ray - you pass your Blender
mesh through Poseray ( https://sites.google.com/site/poseray/ ). There,
you can weld the loose vertices, subdivide the mesh, etc. Then, you can
export in mesh2 format and render in POV-Ray.
Date: 18 Jun 2013 12:45:01
Message: <web.51c08cb791e1715f7a3e03fe0@news.povray.org>
> are not welded.
> Thomas
It is a bad way! If animation?
Povray reads simple text the file.
This file can be created in Poseray, and I can write just the same file hands.
It is necessary to know a mistake.
Mesh created in Blender, without problems is read by other renderer: Luxrender,
Yafaray. There are no problems as with export to OBJ.
You could find the wrong ranges in the example given by me?
Where there triangle vertices are not welded.
Date: 18 Jun 2013 14:45:01
Message: <web.51c0aa4191e1715f87d1a67e0@news.povray.org>
Yes in case of an animation this isn't a good idea. In case of a still it is the
way to go. As Alain mentioned your problem is with the media settings. The first
example uses an extinction value of 0.01 the second 4.871. The first scene has
30 samples within cube_001 the second 256 and there are some different settings
with the light_sources. These settings causes the prolonged rendering time.
Thomas mentioned problems with bad defined meshes which is true in general, but
not with your simple ones here. You have only a cube and such but not Lucy. I
think he only tried to give you an other hint, what could be got wrong from his
long time experience with POV.
But your problem comes from your settings for the scattering media. May be you
have misunderstood some parametrisations within Blender or there is a bug within
the exporter from Blender to POV. I propose to ask the Blender Community as
well.
Best regards,
Michael
BTW: Your first scene took 7 min 40 sec at my (new) system, the second is at 2%
after 20 min. So I can reproduce your problem. I used the scattering values from
the first scene for the second and yielded rendering times close to the first,
but unfortunatelly another lighting. Excuse me, that I cannot go further into
this issue, since I have my own renderings pending.
Date: 19 Jun 2013 08:43:03
Message: <51c1a757@news.povray.org>
> way to go.
I do not see the problem in the case of an animation, as Poseray is only
used once, before any animation is started...
But that leads us away from the thread's topic doesn't it?  ;-)
Media samples can certainly be brought down. Additionally, there seems
to be a /coincident surface/ problem with the wall at left, judging from
the artefacts there.
Just to say that POV-Ray and meshes (mesh2 in particular) work very well
together :-)
The meshes from Blender look OK but I am no expert on Blender and its
exporter to POV-Ray.
Date: 19 Jun 2013 09:00:01
Message: <web.51c1aaf291e1715fed29e82f0@news.povray.org>
I don't know how you managed to get this media sample count from the official
blender exporter since the media samples allowed by its interface are a maximum
number of 100.
About the pigment_pattern with image map slowdown, how much does it really slow
things down? Because that's really needed to get to more complex texture
influence export  corner cases like specular mapping with a texture. To
implement scripted conditions that detect more cleverly the complexity of the
scene in original file and export only with necessary features, I need to know
how much speed could be gained, and if it's really worth it.
Anyway, LanuHum, this is a very interesting type of comparison to improve the
exporter. there could be such tests for many other features with very simple
scenes also usefull to spot regressions of exporter versions. I think I did put
a few scenes on the exporter wiki for that already and I might have a few others
on my local drive at home. ask me by mail if you want them and please could you
also send me any updates to your version of the script when you manage to get it
closer to the official one so that I can try to merge the two versions.
Date: 19 Jun 2013 13:00:01
Message: <web.51c1e36d91e1715f7a3e03fe0@news.povray.org>
> number of 100.
I work over the exporter.
I don't hope that the official version will reach functionality.
I change limits, studying Povray documentation.
I have not enough time
In detail on Saturday or on Sunday, on days off
