POV-Ray : Newsgroups : povray.newusers : Creating moss or ivy? Server Time
3 May 2026 11:44:06 EDT (-0400)
  Creating moss or ivy? (Message 1 to 9 of 9)
Subject: Creating moss or ivy?
Date: 17 Sep 2004 10:10:00
Message: <web.414aef8b6c26479b1fc26f130@news.povray.org>
Hi!
How would you create some moss on a not-too-far-away wall? Would you do it
with an imagemap? Or better with an object looking somehow like moss and
then texture it? Or would you take some small spheres or anything like this
and then use an macro to "attach" them to the wall?
How about ivy? I guess, this should be an object, but I don't know how to do
something like this.
Maybe I should replace the walls with some bushes? ;-)
Last night I rendered a small "preview" (512*384 pixel) of the whole
picture. If someone wants it, to be able to see where the moss or ivy would
be visible, please tell me.
Thanks,
frozen
Subject: Re: Creating moss or ivy?
Date: 17 Sep 2004 10:50:01
Message: <web.414af982e1bf613a1fc26f130@news.povray.org>
I posted the picture in povray.binaries.images with the subject "Another
first post".
Date: 18 Sep 2004 03:12:32
Message: <414bdfe0$1@news.povray.org>
frozen wrote:
> Hi!
> Thanks,
> frozen
I'm not sure if it is what you want but have you checked out the demos
in scenes\language? Notably the tracevines.pov might give you some ideas?
Date: 18 Sep 2004 03:24:30
Message: <414be2ae$1@news.povray.org>
frozen wrote:
> Hi!
> Thanks,
> frozen
Moss is like grass scaled down and a bit more specular
Date: 18 Sep 2004 09:55:01
Message: <web.414c3d11e1bf613a37b975670@news.povray.org>
>in sceneslanguage? Notably the tracevines.pov might give you some ideas?
Thanks a lot! I already had the trace function in my mind. But I didn't
think about using grass scaled down! I ain't sure right now, whether I
should add some moss, because I started a 800*600 rendering with radiosity
15:45 hours ago and it reached only 37%! Using some scaled down grass on
the wall would make it even slower..
But thanks for the tip! I will have a look at the trace examples after that
rendering and might add some moss and let it render a small portion of the
picture. If it looks like I want it, I might render a complete image with
moss..
frozen
Date: 19 Sep 2004 14:51:56
Message: <414dd54c@news.povray.org>
Hi frozen ;)
I'd use a texture for the moss. If you're not doing some really close-up
shots, you can certainly achieve a pretty realistic moss with a
procedural texture (no need for an image map).
For the ivy - I've been playing around with some tree-generating
algorithms limited to a plane (your wall). Although my results are not
good enough (yet ;), I'd go and try that way.
HTH,
Florian
If a train station is a place where a train stops, what's a workstation?
[------------ http://www.torfbold.com - POV-Ray gallery ------------]
Date: 19 Sep 2004 15:30:00
Message: <web.414ddd74e1bf613a8d45c69f0@news.povray.org>
Florian Brucker <tor### [at] torfboldcom> wrote:
> Hi frozen ;)
> HTH,
> Florian
Hi Florian!
Thank you! I think I will try this soon! Although I'm afraid, that my skills
aren't good enough for changing a tree algorithm right now..
frozen
Date: 20 Sep 2004 09:35:57
Message: <414edcbd$1@news.povray.org>
I'd go the other way round: Don't try to change a tree algorithm, but
write one from scratch.
Here's a start-off:
<POV>
#declare SEED = seed(8390);
#declare MAX_LEVEL = 5;
#declare MAX_ANGLE = 35;
#macro Ivy(Level)
	union {
		cylinder { 0,y*2,0.1 }
		#if (Level<MAX_LEVEL)
			union {
				object { Ivy(Level+1) rotate z*(-MAX_ANGLE+2*rand(SEED)*MAX_ANGLE) }
				translate y*2
union {
	Ivy(0)
	pigment { rgb <1,0,0> }
</POV>
Things you could add are:
- random branch length
- random branch depth level
- leaves
- random amount of child-branches
- etc.
HTH,
Florian
Optimum Requirement #4: You virtualized yourself and want to rent a
room on one of our servers (WEB.DE help-wanted ad: Linux Guru)
Date: 20 Sep 2004 10:20:01
Message: <web.414ee6fee1bf613a102354040@news.povray.org>
> - leaves
> - etc.
Ouch... ;-) Thanks for the code! As soon as the actual rendering is done, I
will try it! I hope, I am able to add some useful code!
frozen
