POV-Ray : Newsgroups : povray.newusers : a simple surface Server Time
22 Jul 2025 15:58:47 EDT (-0400)
  a simple surface (Message 1 to 10 of 16)
Subject: a simple surface
Date: 23 Jun 2004 22:00:00
Message: <web.40da34dda19413b38bf678880@news.povray.org>
Hi!
I am trying to use povray to generate a 3d surface from a big matrix of real
numbers, which are the output of my program. I read a lot of things about
povray, the documentation, etc, but i really don't know how i can do it.
Everthing i need is a light_source, a camera and this surface. Nothing more.
Somebody may help me to make a simple .pov file, which my program will
generate, only changing the parameters?
(ps: if i did any mistake in my english, i'm sorry in advance!)
Thanks
ps:
Examples:
matrix file:
http://www.ic.unicamp.br/~ra015988/lis/artigos/novo/superficie.dat
(the sintax of this file may change as need)
the target file, i made it in 3dmax
http://www.ic.unicamp.br/~ra015988/lis/artigos/novo/superficie_saltoe.png
Subject: Re: a simple surface
Date: 24 Jun 2004 10:46:32
Message: <opr93snpswefp2ch@news.povray.org>
<fab### [at] icunicampbr> did spake, saying:
> Hi!
> real
> more.
> Thanks
> ps:
> Examples:
> matrix file:
To get povray to read your superficie.dat file you need to add commas
instead of spaces like:
0,0,1,
0,1,3,
0,2,0,
0,3,0,
Then try:
//start code
Assume first value read is row(Z)
second value column (X)
third value height {Y)
#fopen MyFile "superficie.dat" read
#while (defined(MyFile))
#read (MyFile,LastZ, LastX, DitchY)
The last values read should be the highest needed
DitchY is not needed to be kept
Remember to count the 0
#declare LastZ=LastZ+1;
#declare LastX=LastX+1;
camera{
location <LastX/2,100,-100>
look_at  <LastX/2,0,LastZ/2>
light_source{<LastX/2,50,LastZ/2> rgb 1}
#declare MyArray= array[LastZ][LastX];
Read the file again and put the values into an array
#read (MyFile,MyZ, MyX, MyY)
#declare MyArray[MyZ][MyX]=MyY;
#declare i=0;
#declare j=0;
Draw a box of correct height and move it to the correct place
as the column(X) and row(Z) are the same as i and j use these to
translate the box
#while(i<LastZ)
#while(j<LastX)
box{0,<1,MyArray[i][j],1> translate <j,0,i> pigment{rgb 1}}
#declare j=j+1;
#declare i=i+1;
#declare j=0;
//end code
Uses boxes rather than points and might be slow with a *lot* of data (this
took 26 sec on my computer, 76800 objects) but I hope it helps.
Phil Cook
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
Date: 24 Jun 2004 11:05:48
Message: <opr93tjutgefp2ch@news.povray.org>
And lo on Thu, 24 Jun 2004 15:46:27 +0100, Phil Cook
<phi### [at] nospamdeckingdealscouk> did spake, saying:
Checking against the picture you linked to, my code seems to produce a
upside-down mirror of your image. Use this instead:
//start code
#read (MyFile,LastX, LastZ, DitchY)
camera{
location <-LastX/2,300,-300>
look_at  <-LastX/2,0,-LastZ/2>
light_source{<-LastX/2,50,-LastZ/2> rgb 1 shadowless}
#declare MyArray= array[LastX][LastZ];
#read (MyFile,MyX, MyZ, MyY)
#declare MyArray[MyX][MyZ]=MyY;
#declare i=0;
#declare j=0;
#while(i<LastX)
#while(j<LastZ)
box{0,<-1,MyArray[i][j],-1> translate <-i,0,-j> pigment{green 1}
finish{ambient 0.5}}
#declare j=j+1;
#declare i=i+1;
#declare j=0;
//end code
I'm not sure why you appear to have a negative X & Z compared to the data
but this should match your image.
Use whichever you want, switch the MyX, MyY, MyZ variables to suit.
Phil Cook
Date: 24 Jun 2004 13:08:17
Message: <$O7jtAAKDo2AFws$@econym.demon.co.uk>
Wasn't it F?bio Dias who wrote:
>Hi!
I don't think that there's anything like that which POV supports
directly. One thing you could do is to generate an image where the
brightness of the points corresponds to the heights, then use that image
as a Height_Field.
I did it by using a perl script to read your data file and write out an
image in PPM format. The little-known PPM format is useful for such
tasks because the data is represented by ascii strings rather than
binary values.
A PPM file looks a bit like this
P3
240 240
255
1 1 1 3 3 3 0 0 0 0 0 0 0 0 0 0 0 0 3 3 3 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 20 20 20 0 0 0 0 0 0 0 0
0 0 0 0 20 20 20 1 1 1 1 1 1 5 5 5 5 5 5 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0
0 0 3 3 3 0 0 0 0 0 0 1 1 1 3 3 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3
3 3 0 0 0 0 0 0 0 0 0 0 0 0 3 3 3 0 0 0 0 0 0 0 0 0 0 0 0 3 3 3 3 3 3 0
0 0 0 0 0 3 3 3 3 3 3 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5
5 5 5 5 5 5 5 5 3 3 3 3 3 3 0 0 0 3 ...
The first line is "P3"
The second line is the numbers of pixels in the X and Y directions. Set
it to the dimensions of your matrix.
The third line is the number of shades per colour. Leave this as 255.
The remainder of the file is a sequence of R G B values. Use your data
to generate these entries. I suggest setting the three RGB values all
equal to the "height" value from your matrix. E.g.
Your data       PPM entry
  0 0 1         1 1 1
  0 1 3         3 3 3
  0 2 0         0 0 0
  0 3 0         0 0 0
  0 4 0         0 0 0
  0 5 0         0 0 0
  0 6 3         3 3 3
  0 7 1         1 1 1
Then, in POV you can do something like
height_field {ppm "superficie.ppm"
  pigment {rgb <0,0.5,0>}
  translate <-0.5,0,-0.5>
  scale 2
Mike Williams
Gentleman of Leisure
Date: 24 Jun 2004 14:32:59
Message: <40db1e5b$1@news.povray.org>
"Phil Cook" <phi### [at] nospamdeckingdealscouk> wrote in message
news:opr93snpswefp2ch@news.povray.org...
:snip:
> Phil Cook
couldn't you use a bicubic_patch object, assuming each line in the data file
is a point in 3d space?
Date: 24 Jun 2004 14:36:51
Message: <40db1f43$1@news.povray.org>
Mike Williams nous apporta ses lumieres ainsi en ce 24/06/2004 03:20... :
>P3
>240 240
>255
Looking at this, I think that you could generate that PPM file directly,
as you said that you can adjust the format/syntax as needed.
When reading RGB values for a hight_field, POV Ray use the red and green
chanels to determine a 16 bits value for the hight of each elements. Low
values under 256 use only the red, values greater than 255 start using
the green chanel, the blue chanel is ignored. Unscaled hight_field are
1*1*1 arbitrary unit and must be scaled to the size you want.
Date: 25 Jun 2004 07:28:08
Message: <opr95d41q8efp2ch@news.povray.org>
And lo on Thu, 24 Jun 2004 14:32:50 -0400, Ross <rli### [at] everestkcnet>
did spake, saying:
> :snip:
>> (this
>> Phil Cook
> file
I wasn't keen on the fact that the control-point doesn't necessarily
represent the actual point co-ords and that as a bicubic patch it only
allows 16 vector points which means dividing the data file into 4x4 'sets'
<0,0,Y>,<4,0,Y> to <4,0,Y,>, <4,4,Y> etc. and then recreating the patch
with the correct data 'set' each time. Of course you have to assume the
data is divisible by 16 or pad it. I must admit with the code here I
assumed it was square, but that's easily changed.
It seemed to fiddly to do with a bicubic patch, though of course if you
care to try I'd be interested in seeing your code :)
Phil Cook
Date: 25 Jun 2004 09:52:12
Message: <cjameshuff-62E655.08521225062004@news.povray.org>
In article <opr93snpswefp2ch@news.povray.org>,
It would be far faster, more space efficient, and probably better
looking to use a mesh instead.
http://tag.povray.org/
Date: 25 Jun 2004 10:00:54
Message: <cjameshuff-84A9C4.09005425062004@news.povray.org>
In article <$O7jtAAKDo2AFws$@econym.demon.co.uk>,
> binary values.
The PGM variant would be more useful for this purpose. Just use P2
instead of P3, and include each value only once. However, I don't know
if POV will read this...I think it should, it's not exactly a difficult
format.
Date: 25 Jun 2004 10:18:44
Message: <40dc3444$1@news.povray.org>
news:opr95d41q8efp2ch@news.povray.org...
> did spake, saying:
> > :snip:
> >> (this
> >> Phil Cook
> > file
> Phil Cook
i was mostly just curious, as i tend to not use bicubic patches. Ah well.
