POV-Ray : Newsgroups : povray.newusers : textures and blocks/tiles Server Time
3 May 2026 20:11:42 EDT (-0400)
  textures and blocks/tiles (Message 1 to 6 of 6)
Subject: textures and blocks/tiles
Date: 12 Nov 2003 19:30:01
Message: <web.3fb2d0638187e1a07a0e9df90@news.povray.org>
I am a new user, and I have been experimenting with building a stone wall.
The problem that I have is that when I construct it out of blocks, I get
the same stone pattern (using T_Stone24) over and over again.  Is there a
quick and easy way to have the stone pattern (or any pattern for that
matter!) randomly change?  Thank you very much.  Take care and have a great
day....
ciao,
john.
Subject: Re: textures and blocks/tiles
Date: 12 Nov 2003 19:59:03
Message: <3fb2d757@news.povray.org>
You can either apply the texture only once to the whole wall of stones
so that each stone will have its unique texture (the problem being that
sometimes it's too clear that there's a single texture applied to the
whole wall, which looks bad), or you can create a set of eg. 20 different
stones with different textures and then create the wall by randomly
selecting different stones and rotating/reversing them randomly.
Date: 12 Nov 2003 22:46:34
Message: <matt-pace-F9D890.19463212112003@netplex.aussie.org>
In article <web.3fb2d0638187e1a07a0e9df90@news.povray.org>,
> day....
> ciao,
> john.
If they are using the same texture, you can translate teh texture
randomly with each block, but then I think lines would appear where the
textures dont align...
Somebody correct me if im wrong on that
Date: 13 Nov 2003 01:11:50
Message: <3fb320a6$1@news.povray.org>
Add a random translation to each texture :
#local MySeed=seed(0)
#while (whatever)
   object {
     Stone
       T_Stone
       <rand(MySeed), rand(MySeed), rand(MySeed)>*1000
> day....
> ciao,
> john.
Date: 13 Nov 2003 06:45:13
Message: <3fb36ec9@news.povray.org>
"JC (Exether)" <no### [at] spamfr> wrote:
>      texture {
>        T_Stone
  That probably lacks something... :)
Date: 13 Nov 2003 07:53:56
Message: <3fb37ee4@news.povray.org>
>>     texture {
>>       T_Stone
Errr ... It might work better with a translate ...  :-)
        T_Stone
        translate <rand(MySeed), rand(MySeed), rand(MySeed)>*1000
