POV-Ray : Newsgroups : povray.newusers : object media interaction Server Time
3 May 2026 20:11:52 EDT (-0400)
  object media interaction (Message 1 to 10 of 13)
Subject: object media interaction
Date: 7 Nov 2003 10:05:01
Message: <web.3fabb4055a367bd0d888c9910@news.povray.org>
I try usse search function using words "object media interaction" but found
no match
So can somebody please answer to me: Can POV-Ray render interactive media
sample from real life: smoke of cigaret is bend around finger
if can just point me to reference povray maunal chapter
Thanks alot!
I found alternative program called Lightflow and he is capable of producing
this effect but hard to work :(
Subject: Re: object media interaction
Date: 7 Nov 2003 11:41:13
Message: <3fabcb29@news.povray.org>
"pal### [at] yahoocom" <nomail@nomail> wrote in message
news:web.3fabb4055a367bd0d888c9910@news.povray.org...
> no match
> Thanks alot!
The relevant part of the documentation is 6.8...
As to your specific request, this would be object media (as opposed to, say, a
fog that covered your whole scene).
Basically, you need to make a shape that matches your desired media shape, then
make it transparent and hollow, and fill it with media.
For smoke you will want to use scattering media (as opposed to emitting or
absorbing media - although adding some absorbing media into the mix can prevent
media fading away against light backgrounds).
I would suggest that blobs are the best shape for smoke.
Here's a short example:
#version 3.5;
  location  z*-8
  look_at   0
light_source {
  <0, 0, 0>
  color rgb <1, 1, 1>
  translate <-30, 30, -30>
#declare RadiusVal   = 1.0;
#declare StrengthVal = 1.0;
blob {
  threshold 0.6
  sphere { < 0.75,   0,    0>, RadiusVal, StrengthVal }
  sphere { <-0.375,  0.65, 0>, RadiusVal, StrengthVal }
  sphere { <-0.375, -0.65, 0>, RadiusVal, StrengthVal }
  scale 2
  pigment{rgbt 1}
  hollow
  interior{
    media{
      scattering{1, <0.2,0.2,0.4>}
      density{wrinkles scale 0.1}
    media{
      absorption 1-<0.2,0.2,0.4>
plane{-z,-5 pigment{checker Black, White}}
Date: 7 Nov 2003 12:15:01
Message: <web.3fabd195c881e4ced888c9910@news.povray.org>
Thanks to reply but I still dont see how this example will make make effect!
You just make a scene with media, but what is with interactive media?
If I put for example small box in the blob filled with media will that box
make visible turbulence in the media "smoke"?
Date: 7 Nov 2003 12:31:25
Message: <3fabd6ed$1@news.povray.org>
news:web.3fabd195c881e4ced888c9910@news.povray.org...
Ah, sorry, I missed that part of your post (or rather, I misunderstood).
Okay, pov doesn't support such a thing natively - but help (I think) is at hand.
Try Rune's Particle System include: http://runevision.com/3d/include/particles/
Date: 7 Nov 2003 12:32:02
Message: <1f1t71-hna.ln1@triton.imagico.de>
That would require flow simulation - you can do this with external
programs or in a very much simplified way inside POV, see for example:
Concerning your original post - i don't think Lightflow can do anything
like that.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 7 Nov 2003 13:20:01
Message: <web.3fabe189c881e4ced888c9910@news.povray.org>
Maybee mine english is not good enough but Lightflow can do this effect.
Right now I found some sample and rendering it (in Lightflow).
Thanks for reply
Date: 7 Nov 2003 13:42:01
Message: <455t71-nch.ln1@triton.imagico.de>
Well, in that case please show the example.
Date: 7 Nov 2003 14:15:01
Message: <web.3fabef21c881e4ced888c9910@news.povray.org>
Now animation is near end: but it is not quite what I want :(
Yes it is "smoke like" animation but there is not object to intercept smoke
and made turbulence in smoke
I will you contac via e-mail if you dont mind!
Date: 7 Nov 2003 15:08:58
Message: <3fabfbda$1@news.povray.org>
news:1f1### [at] tritonimagicode...
Awww - you beat me by one minute. Now I've got to ritually disembowl myself
and everything.
Date: 7 Nov 2003 16:15:02
Message: <web.3fac0a66c881e4ced888c9910@news.povray.org>
http://graphics.stanford.edu/~henrik/papers/smoke/
That is html that explain exactly what I want!
And mine apologies to Mr Hormann : Lightflow cannot (at least I dont know
how) produce what I want.
