POV-Ray : Newsgroups : povray.newusers : funny media shadow Server Time
26 Jul 2025 03:36:14 EDT (-0400)
  funny media shadow (Message 1 to 5 of 5)
Subject: funny media shadow
Date: 16 Sep 2003 21:00:02
Message: <web.3f67b1d0f785c673c6890ca10@news.povray.org>
  I am rendering a scene with media in a transparent box a little above the
ground.  The media is defined by a density file.  I shoot photons at the
media-contained box.  I then want photons to be collected on the ground
(because I want to later modify POVRay to have the media emit photons of
different "colours" onto the ground), so I declare for the ground "collect
on" in the photon block.  But when the ground is allowed to collect photons
the shadow of the box is seen, versus the shadow of the shape of the
density in the box.  The shadow of the shape of the density can be seen
when I turn photon collection off for the ground.
  Does anyone know how I can collect photons on the ground, but still have
the correct shadow?
Thanks in advance.
Subject: Re: funny media shadow
Date: 17 Sep 2003 14:41:02
Message: <3f68aabe@news.povray.org>
  I don't think there's need. AFAIK "collect on" is the default setting
for all objects.
  Have you tried "pass_through" in the photons block of the box?
Date: 18 Sep 2003 15:00:01
Message: <web.3f69ffe410ffdad03f47d4fe0@news.povray.org>
Right, but doesn't pass_through also make the photons ignore the media
inside the box?  So no media photons will be placed, correct?
Date: 19 Sep 2003 07:50:27
Message: <3f6aed83@news.povray.org>
  You didn't answer my question... :)
Date: 19 Sep 2003 18:26:14
Message: <cjameshuff-910F43.18244619092003@netplex.aussie.org>
In article <web.3f67b1d0f785c673c6890ca10@news.povray.org>,
> the correct shadow?
I don't think this is possible. POV will light the area in shadow with
photons, but the rest will be lit directly. At the shadow border, there
will probably always be a visible transition between photons and direct
lighting. In theory, you could avoid this by lighting the entire scene
with photons, but it would take a huge amount of photons. You could also
minimize it by using more photons...again, a lot of photons.
Why are your photons interacting with a container shape anyway? Unless
it's refracting, it won't have a very interesting shadow, just a waste
of photons.
http://tag.povray.org/
