POV-Ray : Newsgroups : povray.newusers : how assumed_gamma works Server Time
6 May 2026 16:15:00 EDT (-0400)
  how assumed_gamma works (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: how assumed_gamma works
Date: 19 Nov 2001 05:23:29
Message: <nbnhvtsras4g4jefsvr25rnr3b0hntgfmd@4ax.com>
On 19 Nov 2001 05:15:30 -0500, Warp <war### [at] tagpovrayorg> wrote:
>  There's a bug in the current 3.5 beta. When writing to a PNG file, the wrong
>gamma correction value is written. AFAIK this has been fixed for the next beta.
Thanks for clarification. I wait.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 19 Nov 2001 05:29:26
Message: <3BF8DF0F.F3E76564@engineer.com>
> On Mon, 19 Nov 2001 12:14:11 +0200, Kari Kivisalo <ray### [at] engineercom> wrote:
> > Render the sky map image without assumed_gamma (linear).
> > Then in the scene where the image map is used put
> > assumed_gamma 1.
> And this not work
I just tested it and it works.
_____________
Kari Kivisalo
Date: 19 Nov 2001 05:41:55
Message: <v3ohvtsj617mg1h50ijp9n4qmng4ltkuko@4ax.com>
On Mon, 19 Nov 2001 12:29:35 +0200, Kari Kivisalo <ray### [at] engineercom> wrote:
> > And this not work
In my case
I compare image when POV-Ray displays it. Not with other software.
ABX
Date: 19 Nov 2001 05:59:41
Message: <3BF8E623.F7169240@engineer.com>
It's supposed to go like this:
If you wan't the final image gamma corrected you must design also
the sky as gamma corrected.
_____________
Kari Kivisalo
Date: 19 Nov 2001 06:14:25
Message: <tvphvto3srhhv3qmh5f78cot60ti4pclm6@4ax.com>
On Mon, 19 Nov 2001 12:59:47 +0200, Kari Kivisalo <ray### [at] engineercom> wrote:
That's what I don't understand. If I don't specify assumed_gamma I expect some
default value of it. And documentation says (6.11) it has default value equal to
display_gamma which is default equal 2.2 on windows platform. So I expect no
assumed gamma is equvalent for assumed_gamma 2.2 (eventually 1.0 as linear
copying of sky).
ABX
Date: 19 Nov 2001 06:27:15
Message: <3BF8EC9C.9A87E482@engineer.com>
This is how gamma in povray works.
no assumed_gamma in scene
  No gamma correction is applied to output file.
assumed_gamma 1
  Gamma Display_Gamma is applied to output file.
  If Display_Gamma is not specified, 2.2 is used.
assumed_gamma G
  Gamma Display_Gamma/G is applied to output file.
  If Display_Gamma is not specified, 2.2/G is used.
Recommended value for assumed_gamma is 1.
_____________
Kari Kivisalo
Date: 19 Nov 2001 06:37:29
Message: <ebrhvtked9sr7hs098f06dnq3fun6mlqe3@4ax.com>
On Mon, 19 Nov 2001 13:27:24 +0200, Kari Kivisalo <ray### [at] engineercom> wrote:
Thanks, if it is all true it is best ascetic tutorial about it :-)
Why it can't be described within documentation this short way ?
ABX
Date: 19 Nov 2001 06:46:31
Message: <3bf8f117@news.povray.org>
Try using another image format (eg. tga) and see if the problem still happens
there. If it doesn't happen, then the problem is simply the wrong PNG gamma
correction value. If it does, then the problem is somewhere else.
Date: 19 Nov 2001 07:02:45
Message: <Xns915E84B52D17seed7@povray.org>
It will be.
Ingo
Date: 19 Nov 2001 07:57:48
Message: <7c0ivtggtgm49457c94bsru870gd2mg0da@4ax.com>
But there is another question: what is the fastest way of adjusting designed
enviroment_map to be rerendered with assumed_gamma 1? Adjusting could be started
from calculated factor for color values? How calculate this ?
ABX
