POV-Ray : Newsgroups : povray.newusers : Fog and media containers problem Server Time
26 Jul 2025 12:34:51 EDT (-0400)
  Fog and media containers problem (Message 1 to 4 of 4)
Subject: Fog and media containers problem
Date: 31 Jul 2003 14:47:09
Message: <Xns93C9D3238417Enospam0546179student@204.213.191.226>
Hi, I'm new to PovRay and raytracing, since I downloaded it I love it.
I'm trying to make a outdoor scene with a "flame" (sphere with some media
in it). Without using fog the scene looks ok, but when using fog, the
sphere which contains the media becomes visible. Changing the fog distance
helps, but ruins the rest of the scene.
The sphere is declared like this:
#declare flame = sphere{
 <0,0,0>,2
 pigment { color transmit 1.0 }
 hollow
 interior {
  media {
   absorption 50
   emission 28
   scattering {1, 1}
   density {fire}
   translate wind*clock
I also tried
pigment { rgbf <1,1,1,1> }
but nothing seems to work. Is there a way to make the sphere invisible so
that even the fog continues inside it, or at least not "condense" around
it's boundarys? Any suggestions would be welcome.
Cheers,
Louis
Subject: Re: Fog and media containers problem
Date: 1 Aug 2003 03:11:33
Message: <3f2a12a5$1@news.povray.org>
Louis Somers <nos### [at] studenthronl> wrote in message
Sounds like the same problem I had...
http://news.povray.org/povray.general/31751/
Make sure there's no filter component in your fog.
RG
Date: 1 Aug 2003 06:47:05
Message: <Xns93CA81BEA9581nospam0546179student@204.213.191.226>
"gonzo" <rgo### [at] lansetcom> wrote in news:3f2a12a5$1@news.povray.org:
> RG
Thanks, that works. Unfortunately transmit also causes the effect. But at
least I know it's not the container I should be looking at.
I'm using the fog just to fade the horizon a bit, without filter or
transmit it's too bright.
I now have it set to this:
fog{fog_type 2
    rgb <0.9, 0.9, 0.9>
    transmit 0.5
    fog_offset 20
    fog_alt    7
    distance   70}
It does help if I change the distance to 250 (the effect is still there,
but so dim that no one will notice unless they are really looking for it).
but then there is a visible borderline in the plane before the horizon
where the fog starts.
Any ideas maybe how to fade that borderline out or something? That would be
a good workaround.
Thanks again,
Louis
Date: 1 Aug 2003 14:55:01
Message: <web.3f2ab6a8d74e9d4ca0c272b50@news.povray.org>
>fog{fog_type 2
>    rgb <0.9, 0.9, 0.9>
>    transmit 0.5
>    fog_offset 20
>    fog_alt    7
>    distance   70}
Well, bright is pretty easy to deal with, just make it darker.
    rgb <0.5,0.5,0.5> (or whatever value works...)
You can also have multiple fogs, so maybe one set waaaay back with a higher
alt value, and another in front close to the ground and darker...
RG
