POV-Ray : Newsgroups : povray.newusers : Re: How do I make a torch shine? Server Time
21 Jan 2025 23:48:01 EST (-0500)
  Re: How do I make a torch shine? (Message 1 to 5 of 5)
Subject: Re: How do I make a torch shine?
Date: 5 Oct 2013 15:55:36
Message: <52506eb8$1@news.povray.org>
Note this newsgroup is for Windows-specific questions
(e.g. GUI, installation, command line parameters), you
might find more help in povray.newusers
> The only problem is: How can I make a torch shine or how should I define the
> light source?
some pointers:
to make an object glow by itself in 3.6: Increase ambient in texture
to make an object glow by itself in 3.7 RC: Increase emission in texture
In both cases this will make the object appear bright. However,
it will not only illuminate its surroundings unless "radiosity" is
activated.  An alternative is to define a "light_source" at the position
where the torch should emit light. If the light source is within the
object you need to add "no_shadow" to the object so the light
can actually get out.
Date: 5 Oct 2013 16:31:46
Message: <52507732$1@news.povray.org>
On 05/10/2013 8:55 PM, Christian Froeschlin wrote:
> some pointers:
You forgot to mention looks_like.
3.4.4.1.7 Looks_like
Normally the light source itself has no visible shape. The light simply
radiates from an invisible point or area. You may give a light source
any shape by adding a looks_like { OBJECT } statement
Regards
Date: 6 Oct 2013 14:52:12
Message: <5251b15c@news.povray.org>
>> some pointers:
looks_like is great unless part of the object is suposed to cast a shadow.
In this case, use an union with the flame set as no_shadow and the body
of the torch been a normal object able to cast some shadow.
Date: 6 Oct 2013 16:18:35
Message: <5251c59b$1@news.povray.org>
>>> some pointers:
I did not think of that, it would not work as required.
Regards
Date: 7 Oct 2013 20:57:26
Message: <52535876@news.povray.org>
>>>> some pointers:
>> shadow.
The looks_like can be seen as a special case of an union.
There is nothing to prevent you to include a light_source within an union.
After looking at your code, I noticed that your torch is made of several
polygons rotated around the torch's axis.
If the body of the torch is to cast any shadow, you'd need to add a disk
or something just under the flame.
A disk is defined as follow:
disc{Center, Direction, Radius}
Where Center is where the disk is placed.
Direction is perpendicular to it's surface and define the orientation.
In your case, Direction can be defined a <0,1,0>.
If you use a disc in a scene having any fog or media, you should add
"hollow". Otherwise, it tend to interfer with the fog or media.
