POV-Ray : Newsgroups : povray.newusers : Faster then f_heart Server Time
3 May 2026 21:42:58 EDT (-0400)
  Faster then f_heart (Message 1 to 5 of 5)
Subject: Faster then f_heart
Date: 22 Oct 2003 01:41:33
Message: <3f96188d$1@news.povray.org>
Is there anything faster, but similar to, the function f_heart? It
causes redicioulous (sp?) rendering times, current @ 7 hours for 7
frames of a VERY simple scene (The Heart, some Water, 1 small box, and a
text difference taken out of the box)
Subject: Re: Faster then f_heart
Date: 22 Oct 2003 03:02:13
Message: <QUGI7DAzsil$EwP+@econym.demon.co.uk>
There's a parametric heart shape at
<http://www.econym.demon.co.uk/isotut/real.htm#heart>
but it's not as pretty as f_heart.
As a parametric isosurface it renders a little slower than f_heart, but
it's possible to approximate it with Ingo Janssen's param.inc macro,
which runs very quickly. See "Ingoheart2.pov" in the zip file from that
page.
Alternatively you could try generating a mesh from the f_heart shape
using Kevin Loney's Approximation Macro. The first time you do it, it
will be very slow but you can save the resulting mesh to a file, and
when you read it back it will be really fast. Something like this:-
#include "functions.inc"
background {rgb 1}
camera { location  <0, 0, -6> look_at <0, 0, 0> angle 32}
light_source {<100,200,-200> colour rgb 1}
#declare f = function {f_heart(z,x,y,-1)}
// Set this to 1 the first time, to create the mesh file
// Set it to 0 for to read the mesh from the file
#declare isoFileOption = 1;
#declare isoMin = <-1.2,-1.2,-0.8>;
#declare isoMax = <1.2,1.2,0.8>;
#declare isoSmooth = yes;
#declare isoSegs = <40, 40, 40>;
#declare isoFile = "KLheart.iso";
#declare isoName = "Surface";
#include "isosurface.inc"
object { Surface
  pigment {rgb <0.9,0,0>}
  finish {phong 0.5 phong_size 10}
Date: 22 Oct 2003 03:54:24
Message: <3f9637b0$1@news.povray.org>
Sounds like exactly what I"m looking for! Thanks!
Date: 22 Oct 2003 13:03:41
Message: <6ejipCAnGol$Ewrp@econym.demon.co.uk>
Or you might consider building a heart shape from two half blobs. I'm no
blob expert, but I've managed to knock this together fairly quickly. It
could probably be considerably improved by adjusting some of the
numbers, particularly those defining the sphere components.
global_settings {assumed_gamma 1.0}
camera {location  <0,0,-3> look_at <0,0,0> angle 50}
background {rgb 1}
light_source {<-30, 100, -30> color rgb 1}
#declare Half = intersection {
  blob {
    threshold 0.9                       // tweak me
    sphere { < 0.3, 0.4, 0>, 1,1.2 }    // tweak me
    sphere { <-0.4,-0.4, 0>, 1.2,1.2 }  // tweak me
    //sturm
  plane {-x,0}
#declare Heart = union {
    object {Half}
    object {Half scale <-1,0,0>}
  scale <1,1.15,0.5>                    // tweak me
object {Heart
  pigment {rgb <0.9,0.1,0.1>}
  finish {phong 1 phong_size 10}
Mike Williams
Gentleman of Leisure
Date: 22 Oct 2003 23:43:51
Message: <3f974e77$1@news.povray.org>
"Brent G" <pov### [at] bc-hqcom> wrote in message
news:3f96188d$1@news.povray.org...
Try this:
#declare HEART=
#macro _(T,R,F)  sphere {0,.38,1
    scale <.1+7*N,.1+6*N,.1+pow(N,1.1)*3>
     rotate <0,-15*sin(N*pi)*R,0>
      translate <T*N*.7,2*N+3*pow(N,2),-.1*sin(pi*N)>
       rotate<0,0,N*-(14+8*sin(N*pi*1))*R>
        rotate y*F
         translate y*-5
     } #end
 blob{
#declare EndNr =20;
#while (Nr< EndNr)
#declare N=Nr/ EndNr;
_(1,1,0)
_(-1,-1,0)
_(1,1,180)
_(-1,-1,180)
#declare Nr = Nr + 1;
translate<0,2.5,0>
