POV-Ray : Newsgroups : povray.newusers : image map Server Time
29 Mar 2026 21:42:14 EDT (-0400)
  image map (Message 11 to 17 of 17)
Subject: Re: image map
Date: 15 Jun 2002 22:27:24
Message: <3d0bf78c@news.povray.org>
You know the idea then, I'm sure.
Say a 3.14*100 wide image (in pixels) is the pi, or cylinder circumference,
and the height is always 1 POV unit to start with; but you'd then want that
number to be a 3.14:0.5 (yeah, 0.5, not 1.0) ratio of width to height.
Voila! 314 wide by 50 height, or any rescale of that ratio, will fit
proportionally correct on a POV unit cylinder primitive because it is 2
units diameter, 1 unit tall, and pi*2 units in circumference.
I sort of misspoke before by not pointing out map_type 2 has such a "unit"
system to it. It's not 1 in diameter. I really shouldn't have ever said it
the way I did so haphazardly, pi * height is just plain wrong. It's actually
pi * (height/2). Sorry, I can confuse better than I can help  ;-)
Were the units done differently it would be simpler to think of it as 1 for
diameter, 1 for height, making it pi for circumference. So try to keep that
in mind, that it is 2 across instead yet only 1 unit tall.
Okay, I'm probably digging myself into a hole so I'll shut up now.
bob h
Subject: Re: image map (cylindrical warping?)
Date: 16 Jun 2002 00:26:05
Message: <3d0c135d@news.povray.org>
> This wraps around like map_type 2 in image_map but I couldn't get the
effect
> Warp mentioned. I scaled and changed dist_exp only to get a distorted
label,
> apparently similar to your outcome, ulli.
> Either I misunderstood or I didn't hit upon the correct transformation.
You need to scale before you apply the warp.
Date: 16 Jun 2002 10:26:13
Message: <3D0CA011.20907@gmx.de>
ive tried it, but the label only doesnt get distorted if i use the
initial translate and scale settings. but then its size isnt correct.
these are the settings:
             translate <-0.5,0.1,0>
           scale <4/10,6.2/10,4/10>
http://www.winter-privat.de/bottle3.jpg
and that is the bottle
Date: 16 Jun 2002 10:49:57
Message: <3d0ca595$1@news.povray.org>
Hmmm, remember this mantra 'scale, then translate, scale, then translate'
First of all, cylindrical image_maps are defined around the 'y' axis and
extends from y=0 to y=1 so your object needs to be centered on the y axis
before applying the image_map if you don't want weird results.
Likewise, scaling (also rotation) occurs around the origin. You should
always create your object at the origin and apply any scaling before
translating.
-tgq
Subject: Re: image map (cylindrical warping)
Date: 16 Jun 2002 12:07:20
Message: <3d0cb7b8@news.povray.org>
"Simon Adameit" <gom### [at] gmxde> wrote in message
news:3d0c135d@news.povray.org...
Thanks Simon, that sure seems to be the answer all right.
  location  <1,2,-4>
  look_at   <0,0,0>
  angle 50
light_source {
        <-30,30,-30>,
        1
plane {
  y, -0.001
    pigment { checker color rgb <1,1,0> color rgb <0,1,0> }
cylinder {
  0, y, 1
      image_map {
        png "testlabel2.png" // a 314 wide by 50 high image
        interpolate 2
        once
        filter 215, 2/3
        scale <.25,.25,1>
        translate y/2
      warp {
        cylindrical
        orientation z
        dist_exp 0
      rotate 120*y
Something strange happens with the cylinder here. Looks like coincident
surfaces to me except it also reverses the checker pattern of the floor
plane, as seen through that otherwise invisible cylinder. Only the label has
texture, no 'ior' in that.
bob h
Date: 16 Jun 2002 15:52:00
Message: <3d0cec60@news.povray.org>
  It doesn't seem to be related to the texture (if you apply any trasnparent
texture to the cylinder, the same artifact happens).
  I don't know why it happens, but if you make the plane y, -0.01 then
it fixes it.
Subject: Re: this plane under cylinder oddity
Date: 16 Jun 2002 22:02:29
Message: <3d0d4335$1@news.povray.org>
news:3d0cec60@news.povray.org...
has
trasnparent
> it fixes it.
Interesting. I checked that as you said and found now that if it's
at -0.00101 or -0.00099 there's no artifacting. Strange, huh...? I can't
figure any reasoning for this.
bob h
