POV-Ray : Newsgroups : povray.newusers : transforming vectors Server Time
2 Aug 2025 08:30:03 EDT (-0400)
  transforming vectors (Message 1 to 10 of 15)
Subject: transforming vectors
Date: 20 Oct 1999 03:00:53
Message: <380d68a5@news.povray.org>
Is it possible to apply a transformation to a single vector? (for instance
if my vector is <1,0,0> and my transformation is transformation is
transform{translate <2,0,0> rotate 90*z}, I want to get <0,3,0>)
Daniel Pirch
dpi### [at] gmxnet
Subject: Re: transforming vectors
Date: 20 Oct 1999 03:07:40
Message: <380D6A78.FDCC4FBD@geocities.com>
Yes.
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
Date: 20 Oct 1999 03:12:34
Message: <380D6B9F.E15489ED@geocities.com>
> Yes.
Now, to start guessing what you need, instead of just what you asked.  :-)
RT_M  ( http://wombat.doc.ic.ac.uk/foldoc/foldoc.cgi?query=RTM )
Check the docs (be sure to check the language help, not the Windows help) for
vector functions.
Date: 20 Oct 1999 05:10:28
Message: <380d8704@news.povray.org>
instance
for
> vector functions.
Of course I've checked the docs before I posted my Question. I would never
ask before doing that :-)
But as vector functions, there are only vaxis_rotate, vcross, vnormalize and
vrotate. I asked if it's possible (and HOW) to transform a vector by an
already declared transformation. I can do this with an object:
#declare MyTrans = transform{translate ... rotate ... scale ... ...}
sphere{0,1 transform MyTrans}
But how can I do this with vector coordinates?
Thanks
Daniel Pirch
dpi### [at] gmxnet
Date: 20 Oct 1999 07:43:42
Message: <380daaee@news.povray.org>
Daniel Pirch <dpi### [at] gmxnet> wrote:
: I asked if it's possible (and HOW) to transform a vector by an
: already declared transformation.
  It's not possible.
Date: 20 Oct 1999 10:47:39
Message: <380DD608.72926FC4@spiritone.com>
Check out http://users.erols.com/vansickl/macs.htm on that page there is a
vmatrix macro that applies  matrix tranformations to vectors, which will
accomplish what you want to do. His explanaion of how the Matrix command works
will help out, too.
> instance
> for
> > vector functions.
> Thanks
> Daniel Pirch
> dpi### [at] gmxnet
Josh English
eng### [at] spiritonecom
icq 1946299
"Stress is when you wake up screaming and realize you haven't fallen asleep
yet."
Date: 20 Oct 1999 10:57:28
Message: <380DD822.24D08595@peak.edu.ee>
It is not possible directly. You can facilitate the process by predeclarin
transformation vectors. Keep in mind the following:
object                 vector
scale <x,y,z>          vector * <x,y,z>
rotate <x,y,z>         vrotate(vector, <x,y,z>)
translate <x,y,z>      vector + <x,y,z>
Now declare, for example, a rotation vector, and use it both after the 'rotate'
keyword and in the 'vrotate' function.
Margus
> Thanks
> Daniel Pirch
> dpi### [at] gmxnet
Date: 20 Oct 1999 17:11:32
Message: <380E308B.72F15F42@yahoo.com>
This is why I made a patch which added a vtransform() function. :-)
vtransform(TRANSFORM, VECTOR)
Returns a vector which is the result of applying transformation
TRANSFORM to the vector VECTOR.
Date: 20 Oct 1999 21:04:56
Message: <380E673F.ACE177DD@yahoo.com>
Forgot to add this:
I will be posting the source for this in povray.programming sometime
soon, and I have sent it to Ron Parker. The disadvantage is that you
will either have to use an unofficial version, or wait until it gets
into the official POV-Ray(if it ever does...maybe POV-Ray 3.5?).
Date: 20 Oct 1999 21:08:02
Message: <380E6706.7BC65228@pacbell.net>
Chris Huff wrote:
> Forgot to add this:
  It almost seems to be a race now if there will be an updated version
of the SuperPatch before the official Pov v3.5 will become available.
 Any comments Ron ?
Ken Tyler -  1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
