POV-Ray : Newsgroups : povray.newusers : Help with CGS Server Time
22 Mar 2026 13:19:27 EDT (-0400)
  Help with CGS (Message 11 to 14 of 14)
Subject: Re: Help with CGS
Date: 16 Apr 1999 06:09:21
Message: <3716FCE7.6C3C00D4@pacbell.net>
Kevork Abadjian wrote:
> I was looking at the two replies posted to my message and as far as I can see
> Ken explained the situation even better than I could; but he stopped just short
> of a suggestion to fix the problem.
> there is nothing special about the source, I am using the std seen file and
> just and std texture for glass and a switch to toggle on an off the photones.
Stripped down and rearranged for clarity and examples sake I offer the
following two examples of correct and incorrect behavior. Which is which
I leave to the person who renders it to decide but it should be as obvious
as obvious can be.
  camera{
  location  <0.0, 0, -5.0>
  look_at   <0.0, 0.0,  0.0>}
  light_source{<0,440,-300>rgb 1 }
 plane { y,-3 pigment{ rgb 1}}
 plane { z, 3 pigment{ rgb 1}}
 #declare Ball1 =
 sphere{0,0.4
  pigment{rgbf<1,1,1,0.97>}
   translate<-0.4,-0.2,0>
    interior {ior 1.99}
 #declare Ball2 =
 sphere{0,0.4
  pigment{rgbf<0,0,1,0.97>}
   translate<-0.4, 0.2,0>
    interior {ior 1.19}
#declare cnt=0
       merge {
#while (cnt < 4)
       object {Ball1 rotate z*90*cnt}
       object {Ball2 rotate z*90*cnt}
       #declare cnt=cnt+1
 translate x*1.25
#declare cnt=0
#while (cnt < 4)
     merge {
 translate x*-1.35 }
       #declare cnt=cnt+1
Ken Tyler
mailto://tylereng@pacbell.net
Date: 16 Apr 1999 08:21:54
Message: <37171E09.16D8FD7C@zess.uni-siegen.de>
Ken wrote:
> Markus Becker wrote:
> > What do you expect? If you have the "merge" _inside_ the #while
> > loop, POV creates a "merge"-object fo each pass through the
> > loop. That's the way things work. No need to ask "why?"
> Not altogether a programmer type and struggling to use what I can of these
> functions I expect no more or no less than what I can figure out myself
> of from what I can learn from the generous guidance of others. What is
> intuitively obvious to you is sometimes heap big juju magic to me.
That might be, myself being the programmer-type this has always been
obvious to me. Let me try to give you (or the original poster) a more
detailed explanation:
Case 1, "merge" _inside_ #while:
    #declare n = 0;
+-->  #while (n<10)
|       merge			// a new object is created
|          object {....}
|       }				// merge object is finished
|     #declare n = n+1;
+-- #end			// loop again and create a new object
Note that each time POV loops through the #while, it parses a
complete merge-object.
Case 2, "merge" _outside_ #while:
    #declare n = 0;
+-->  #while (n<10)
|        object {....}
|     #declare n = n+1;
Note here how the loop only adds new objects to the merge object.
Hope this makes it a little bit more clearer. Even if you're not at
all the programming type [tm], you should get one concept into
your head (no offense meant, it's just the lack of better english):
POV parses the file line by line and the #while only tells it
to parse some lines more often. It is just redirected to a new
position in the file.
The first case would "unroll" (common practice for the programmer
type ;-) to the following:
merge {object {...}}
merge{ object {...}}
anbd the second case unrolls to:
merge
  object {...}
  object {...}
  object {...}
  object {...}
This should make it clearer.
Markus
 Ich nicht eine Sekunde!!!" H. Heinol in Val Thorens
Date: 16 Apr 1999 10:34:06
Message: <37173c4e.0@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: Don't
: ask me why this is so but I found after many hair pulling sessions and
: then finaly by asking in these groups how to solve my problem.
  Markus explained it well. You can also think about it this way:
#declare i=0;
#while(i<4)  // Make 4 copies of this:
                 merge { sphere { ... } }
 #declare i=i+1;
  After parsing the result is:
  On the other hand:
merge {
#declare i=0;
                 sphere { ... }
 #declare i=i+1;
merge {
                 sphere { ... }
                 sphere { ... }
                 sphere { ... }
                 sphere { ... }
  Sometimes the first behaviour is the wanted behaviour. For example:
union {
#declare i=0;
                 merge { sphere { ... } sphere { ... } }
 #declare i=i+1;
  The result:
union {
Date: 17 Apr 1999 03:05:55
Message: <3718265D.1DADA59B@conted.lan.mcgill.ca>
Thanks to everyone for hempling me;  specially to Ken for the smaple code.  It solved
the problem.
Ken wrote:
> // This should now act correctly for a merge csg operation:
>  #declare cnt=0
>         merge {
>  #while (cnt < 5)
>         object {ball
>                 translate <cnt/2.5,0,0>
>         #declare cnt=cnt+1
>  #end
