POV-Ray : Newsgroups : povray.newusers : Prisms gone awry! Server Time
7 May 2026 04:22:52 EDT (-0400)
  Prisms gone awry! (Message 1 to 5 of 5)
Subject: Prisms gone awry!
Date: 11 Apr 1999 11:39:10
Message: <3710B4CE.62AB66A4@compass.com.ph>
HI,
    I really need your help, guys.. I have made this object using a
prism with a cubic spline but unfortunately for me, I can't seem to make
it go to wherever I want it to go.... I used translate<> but it doesn't
seem to work... and it seems to me that it is using its own set of
rules... Am I doing something wrong? (obviously)... or have I gone
mad!.... please help me figure out which one is which.... grr.... I'm
just a little confused... please help me if you can. Thanks!!!
Subject: Re: Prisms gone awry!
Date: 11 Apr 1999 12:30:42
Message: <3710BE66.7093EA3@pacbell.net>
Glenn Bautista wrote:
> HI,
Could you post an example of how you are creating the prism. Without
being to see the code it is really difficult to guess at what MIGHT
be wrong.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 11 Apr 1999 13:48:37
Message: <3710D317.E4388D4A@compass.com.ph>
> > HI,
> be wrong.
> -- Ken
Ok..... here it goes... well.... its got some comments 'cause I just cut and
paste from the tutorial... and I added my own values :)
prism {
cubic_spline
0, // sweep the following shape from here ...
1, // ... up through here
21, // the number of points making up the shape ...
< 2, 0>, // point#1 (control point... not on curve)
< 0, 0>, // point#2 ... THIS POINT ...
<1, 1>, // point#3
< 2, 0>, // point#4
< 1,-1>, // point#5 ... MUST MATCH THIS POINT
<0,0>,
<1,1>, // point#6 (control point... not on curve)
<1.75,0>,//Start of Second shape
<0.25,0>,
<1,0.75>,
<1.75,0>,
<1,-0.75>,
<0.25,0>,
<1,0.75>,
<1.5,0>,//Start of Third Shape
<0.5,0>,
<1,0.5>,
<1.5,0>,
<1,-0.5>,
<0.5,0>,
<1,0.5>
scale<0.25,0.125,0.125>
translate<0,-1,-1>
rotate<90,0,0>
Thanks !!!!!
Date: 11 Apr 1999 13:51:14
Message: <3710D3C4.9F719729@compass.com.ph>
> > > HI,
> > be wrong.
> > -- Ken
<snip>
Actually... I was making this eye (like Isis) . and was thinking of putting it
onto the head of a column that I made.( with union{} )  but it just wouldn't go
there... weird.
Date: 11 Apr 1999 18:02:36
Message: <37110D2B.A7D495DF@compuserve.com>
You've got a rotate after the translate, this will rotate the object around the
origin AFTER moving it, which will make it spin in a circle. Move the rotate to
before the translate, and you will be moving the rotated prism, which is
apparently what you want to do.
Remember that transforms (rotate, scale, translate, matrix) are always done in
the order they are given, and the object should be centered on the origin if
you don't want it to move when you scale or rotate it. It is usually a good
idea to make your object at the origin, rotate and/or scale it to however you
want it, and then translate it to position.
> > > HI,
> > be wrong.
> > -- Ken
> prism {
> cubic_spline
> <1, 1>, // point#3
> < 2, 0>, // point#4
> <0,0>,
> <0.25,0>,
> <1,0.75>,
> <1.75,0>,
> <1,-0.75>,
> <0.25,0>,
> <1,0.75>,
> <0.5,0>,
> <1,0.5>,
> <1.5,0>,
> <1,-0.5>,
> <0.5,0>,
> <1,0.5>
> translate<0,-1,-1>
> rotate<90,0,0>
> Thanks !!!!!
