POV-Ray : Newsgroups : povray.newusers : Blobs in 3.02 Server Time
7 May 2026 08:21:41 EDT (-0400)
  Blobs in 3.02 (Message 1 to 4 of 4)
Subject: Blobs in 3.02
Date: 25 Nov 1998 20:39:26
Message: <365CB150.7921D942@chop.swmed.edu>
Dear Colleagues,
  I am having trouble to get blob objects to work properly. I am using
blobs
to generate tube-like objects consisting of a great number of short
cylinders.
Povray 3.02 renders these blobs with lots of black dots on them. It
usually helps
to tweak blob_threshold a bit but so far these black dots never
disappear entirely.
I have tried may things which include using the keyword sturm, different
texture maps
at different positions i.e. individual and global but nothing seems to
help.
Does anyone have an idea why that might be (black dots) and possibly
know what to do about it ?
(The reason why I am using blobs is that I need to model transparent
tubes with round
ends. When I merge cylinders and spheres the whole thing gets terribly
slow -
so blobs are a lot faster but they don't seem to work.)
Any ideas ?
Thanks,
   Lothar Esser
Dr. Lothar Esser
Howard Hughes Medical Institute
5323 Harry Hines Blvd.
Dallas Texas 75235-9050
E-mail : ess### [at] chopswmededu
Subject: Re: Blobs in 3.02
Date: 25 Nov 1998 23:38:43
Message: <365CDACC.AD0A64B3@pacbell.net>
Just a guess but try adding a line to your scene that says:
#global_settings{max_trace_level 10}
Try different values (higher) for max trace level if 10 does not work.
Ken Tyler
Date: 26 Nov 1998 07:25:47
Message: <365d48cb.0@news.povray.org>
P-R 3.1 blob received a bit of a fix since 3.02, perhaps that makes a
difference. I wondered if you were using multiple blob statements or a single
one with multiple components? If more than one blob is being strung together
in a union or merge it could be same-surface problem.
Message <365CB150.7921D942@chop.swmed.edu>, Lothar Esser  typed...
>Dear Colleagues,
>blobs
>cylinders.
>usually helps
>disappear entirely.
>texture maps
>help.
>tubes with round
>slow -
>Any ideas ?
>Thanks,
>   Lothar Esser
>Dr. Lothar Esser
  http://members.aol.com/inversez/POVring.html
=Bob
Date: 26 Nov 1998 13:12:41
Message: <365E34B8.D45A03A2@aol.com>
Try this as a last resort, put hierarchy off inside the blob statement.
I've done animations where the internal bounding of blobs caused serious
problems.
Since you are using transparent blobs, you probably just need to raise
max_trace_level though.
-Mike
> usually helps
> disappear entirely.
> texture maps
> help.
> tubes with round
> slow -
> Any ideas ?
> Thanks,
