POV-Ray : Newsgroups : povray.general : Povray Mandelbulbs - Isosurface and max_gradient Server Time
22 Sep 2025 21:39:41 EDT (-0400)
  Povray Mandelbulbs - Isosurface and max_gradient (Message 2 to 11 of 21)
<<< Previous 1 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Povray Mandelbulbs - Isosurface and max_gradient
Date: 7 May 2024 18:18:49
Message: <663aa8c9@news.povray.org>
On 07/05/2024 23:41, Droj wrote:
> // Adapted from original function for power 8 by Paul Nylander at
> http://www.bugman123.com;
> // Trace time on an AMD Ryzen7 Eight Core using 16 threads: 7 h 54 min with
> max_gradient 1000
> // Trace time on an AMD Ryzen7 Eight Core using 16 threads: 2 h 34 min with
> max_gradient 200
Hi, Droj !
Very interesting - thanks for sharing.
I've rendered this 800x600 image with max_gradient=1000 (No other
parameters was changed) on Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz
(40 cores) for 2 min 19 sec and can't figure out how to get make it more
detailed.
Any suggestions, please !
YB
Download 'fract_01.png' (288 KB)
Preview of image 'fract_01.png'
Date: 7 May 2024 18:25:21
Message: <663aaa51@news.povray.org>
> max_gradient 1000
> max_gradient 200
Hi, Droj !
(40 cores) for 2 min 19 sec and can't figure out how to make it more
detailed.
YB
Date: 7 May 2024 19:35:07
Message: <663abaab@news.povray.org>
> // Mandelbulb - power 4 - Believe me the power 6 is a vision of hell!
Agree with you - sometimes it looks horrible ...
camera{location <-2.5,5,5> look_at <-0.5,0,0.3> up z sky z angle 25}
light_source{20*z,1}
#declare f=function(i,x,y,z,xc,yc,zc) {select(i>0 & x*x+y*y+z*z<4, 0,
sqrt(x*x+y*y+z*z),
f(i-1,(x*x-y*y)*(1-z*z/(x*x+y*y))+xc,2*x*y*(1-z*z/(x*x+y*y))+yc,-2*z*sqrt(x*x+y*y)+zc,xc,yc,zc))};
isosurface{function{f(24,x,y,z,x,y,z)} threshold 0.5 max_gradient 1000
contained_by{sphere{<-0.5,0,0>,2}} pigment{rgb 1}}
YB.
Download 'fract_02.png' (163 KB) Download 'fract_02_1.png' (117 KB)
Preview of image 'fract_02.png'
Preview of image 'fract_02_1.png'
Date: 9 May 2024 09:25:00
Message: <web.663cce5da9c49b654e7519d73b2af915@news.povray.org>
> detailed.
> YB
Hi yesbird
as I can see you have no problem with the rendering time as I have.
You can increase max_gradient.
When I rendered it the max_gradient Povray found was 33566.
So give it a go.
Droj
Date: 9 May 2024 09:40:41
Message: <663cd259$1@news.povray.org>
On 09/05/2024 16:23, Droj wrote:
> So give it a go.
Hi, Droj.
Thank you, I will try.
YB
Date: 9 May 2024 11:44:09
Message: <663cef49@news.povray.org>
It took 15m59,185s for rendering with max_gradient=33566, and n=6,
but I see, that your image looks more smooth and pretty.
What's the secret ? Antialiasing, maybe ... Could you please post
all rendering parameters ?
This teddy bear don't looks like real daemon, but some sort of inferno
is present, no doubt ...
YB
Download 'mand_pow_6_1600x1200.png' (1117 KB)
Preview of image 'mand_pow_6_1600x1200.png'
Date: 9 May 2024 18:10:00
Message: <web.663d4867a9c49b65e85adf843b2af915@news.povray.org>
Hi YB
Oh man you make me weep! 16 min with max_gradient=33566 ... if I try my image
will be finished next week.
Here are the settings of the ini-file I use:
Width = 1600
Height = 1200
Antialias = On
Sampling_Method = 1
Antialias_Threshold = 0.0010
Jitter = Off
Antialias_Depth = 9
Output_To_File = On
Output_File_Type = N
Display = On
Verbose = Off
Quality = 11
Input_File_Name =
Output_File_Name =
Initial_Frame = 0
Final_Frame = 0
Subset_Start_Frame = 0
Subset_End_Frame = 0
Test_Abort = On
Test_Abort_Count = 100
Have you ever seen Edvard Munk's painting 'The Scream'? It's disturbing but
Mandelbulb power 6 is worse.
Hope the ini settings will help.
Droj
Date: 9 May 2024 19:37:06
Message: <663d5e22@news.povray.org>
On 10/05/2024 01:04, Droj wrote:> Oh man you make me weep! 16 min with
Hi, Droj.
Please, don't cry: I noticed, that your setting are too 'aggressive':
; Antialias_Depth = 9
; Antialias_Threshold = 0.0010
See: https://www.povray.org/documentation/view/3.6.1/223/
making less depth and threshold can seriously improve performance with
almost the same quality.
Thanks for setting, you've saved a lot of time for me.
> Have you ever seen Edvard Munk's painting 'The Scream'?Yes, sure, this is a famous
painting, but I see something close to
Francisco Goya. :)
Happy poving,
YB
Download 'fract_03_800x600.png' (95 KB)
Preview of image 'fract_03_800x600.png'
Date: 9 May 2024 19:40:22
Message: <663d5ee6$1@news.povray.org>
Hi, Droj.
Yes, sure, this is a famous painting, but I see something close to
Francisco Goya. 🙂
Happy poving,
YB
Date: 9 May 2024 20:10:53
Message: <663d660d@news.povray.org>
Hi, Droj.
Thanks, you've saved a lot of time for me.
Francisco Goya. 🙂
Happy poving,
YB
Download 'fract_03_1024x768.png' (192 KB)
Preview of image 'fract_03_1024x768.png'
