POV-Ray : Newsgroups : povray.general : L-Systems in Povray Server Time
15 Mar 2026 17:51:03 EDT (-0400)
  L-Systems in Povray (Message 45 to 54 of 64)
Subject: Re: L-Systems in Povray
Date: 12 Jul 2023 13:00:00
Message: <web.64aedbb5453cebfc763e4a273b2af915@news.povray.org>
"Droj" <803### [at] drojde> wrote:
> "Bald Eagle" <cre### [at] netscapenet> wrote:
> > "jr" <cre### [at] gmailcom> wrote:
> > > hi,
> > > > I have NO idea what I'm doing, but that gets me a completed render and no
> > > > crashing.
> > > _neat_.  (and thanks, that'll give me .. encouragement to play a little more
> > > regards, jr.
> > Other changes:
> > #declare BuildRules["X"] = asc("X"); // 88
> > #debug concat( "X = ", str(asc("X"), 0, 0), "\n")
> > #macro MoveRight (T_Pos)
> >  <T_Pos.x + 1, T_Pos.y, T_Pos.z>
> >  //#local T_Pos = <T_Pos.x + 1, T_Pos.y, T_Pos.z>;
> >  //#declare VXY_Arr[Curr_Items] = T_Pos;
> >  //#declare AZZ_Arr[Curr_Items] = AngleZZ;
> >  //#declare Curr_Items = Curr_Items + 1;
> > #end
> >     #case (88)
> >     #local T_Pos = MoveRight (T_Pos);
> >     #break
> >     #else
> >     #break
> >    #end // end switch
> > #declare Axiom = "FFFFX";
> > #declare Rules = dictionary {
> >   ["X"] : "F[-X|][+F|]",
> >  // ["Y"] : "FX-Y"
> > #declare Iterations = 50;
> > Doesn't get me much, except a few line segments.  Once I have more time to
> > decipher the Big Picture, then it will be easier to make things work.
> Hi,
> first of all thanks to all of you for your engagement to solve this 'mystery'.
> Just one remark: please do not use 'Iterations = 50;'. If the coding works
> properly Povray will produce an amount of data to choke a horse with.
> As far as using "X" or "Y" without declaring it is concerned: I used Ingo's
> original code - means vector and angle are not separated - with
> #declare Axiom = "X";
> #declare Rules = dictionary{
>   ["X"] : "XFYFX+F+YFXFY-F-XFYFX",
>   ["Y"] : "YFXFY-F-XFYFX+F+YFXFY"
> and it works like a charm (see attachment).
> Furthermore I used Ingo's original and added Push and Pop stacks and...
> Povray again complained about (vertices).
> Could it be that Povray hates LIFO arrays <grin>.
> Can't wait until Ingo's 'muse with the glass eye' is kissing me - I AM cleanly
> shaven.
> Time to investigate further.
> Regards
> Droj
Just in case you are curious how lsys3.pov looks like.
Download 'lsys3.png' (149 KB)
Preview of image 'lsys3.png'
Date: 12 Jul 2023 13:05:00
Message: <web.64aedcd4453cebfc17bac71e8ffb8ce3@news.povray.org>
worked a bit on you lsys7. Simplified a few minor things. Changed a bit in
LVertices and added debugging.
We're at "Parse Error: Expected 'RValue to declare', End of File found instead"
now.
ingo
/*Pov-Ray    : 3.8
Scene File : lsys.pov
Author     : Ingo Janssen
Date       : 2023-06-04
#version 3.8;
global_settings{ assumed_gamma 1.0 }
#default{ finish{ ambient 0.1 diffuse 0.9 }}
#declare T_Pos = <0, 0, 0>;
#declare A_F = 14; // Angle increment
#declare Max_Items = 200;
#declare Curr_Items = 0;
#declare VXY_Arr = array[Max_Items]; // Pos stack for xy-plane
#declare AZZ_Arr = array[Max_Items]; // Angle stack for xy-plane
//build rules
#declare BuildRules = dictionary;
#macro F(T_Pos, AngleZZ)
 #local T_Pos = <0, 0, 0>;
    <T_Pos.x + cos(AngleZZ), T_Pos.y + sin(AngleZZ), T_Pos.z> // <x, y, 0>
#declare BuildRules["F"] = 70; //chr(70) = F
#macro YawR(AngleZZ)
 #local AngleZZ = 0;
  AngleZZ + (tau/A_F)
#declare BuildRules["+"] = 43;
#macro YawL(AngleZZ)
 #local AngleZZ = 0;
  AngleZZ - (tau/A_F)
#declare BuildRules["-"] = 45;
#macro Turn(AngleZZ)
 #local AngleZZ = 0;
   AngleZZ - (tau/2)
#declare BuildRules["|"] = 124;
// the following macros are needed for branching
#macro Push(T_Pos, AngleZZ)
#declare BuildRules["["] = 91;
#macro Pop(T_Pos, AngleZZ)
  #declare Curr_Items = Curr_Items - 1;
  #declare T_Pos = VXY_Arr[Curr_Items];
  #declare AngleZZ = AZZ_Arr[Curr_Items];
#declare BuildRules["]"] = 93;
// I left Ingo's brilliant rewrite macro untouched
#macro Ltransform(Axiom, Rules, Iterations)
  #local Result = Axiom;
  #for (i, 1, Iterations)
      #local NewResult = "";
      #local N = strlen(Result);
      #local j = 1;
      #while (j <= N)
        #local CurrentSymbol = substr(Result, j, 1);
        #ifdef(Rules[CurrentSymbol])
          #local NewResult = concat(NewResult, Rules[CurrentSymbol]);
        #else
          #local NewResult = concat(NewResult, CurrentSymbol);
        #local j = j + 1;
      #local Result = NewResult;
      #debug concat(Result, "\n")
  Result
#macro Lvertices(Lstr)
  #local T_Pos = <0, 0, 0>; // <x, y, z>
  #local AngleZZ = 0;
  //#local Curr_Item = 0;
  #declare Return = array; //{<T_Pos.x, T_Pos.y, T_Pos.z>};
 #declare Return[0] = <T_Pos.x, T_Pos.y, T_Pos.z>;
  #for (i, 0, strlen(Lstr)-1)
    #local CurrentSymbol = substr(Lstr, i, 1);
    #ifdef (BuildRules[CurrentSymbol])
      #switch (BuildRules[CurrentSymbol])
        #case(70)
          #debug "70 F \n"
          #local T_Pos = F(T_Pos, AngleZZ);
        #break
        #case(43)
          #debug "43 + \n"
          #local AngleZZ = YawR(AngleZZ);
        #break
        #case(45)
          #debug "45 - \n"
          #local AngleZZ = YawL(AngleZZ);
        #break
        #case(124)
          #debug "124 | \n"
          #local AngleZZ = Turn(AngleZZ);
        #break
        #case(91)
          #debug "91 [ \n"
          #local Curr_Item = Push(T_Pos, AngleZZ);
        #break
        #case(93)
          #debug "93 ] \n"
          #local Curr_Item = Pop(T_Pos, AngleZZ);
        #break
      #local InArr = Return[dimension_size(Return,1)-1];
      #if (T_Pos.x != InArr.x | T_Pos.y != InArr.y | T_Pos.z != InArr.z)
        #declare Return[dimension_size(Return,1)] = <T_Pos.x, T_Pos.y, T_Pos.z>;
  #declare Vertices = Return;
  Vertices
  ["X"] : "F[-FX][+FX]",
  ["Y"] : "FX-Y"
#declare Iterations = 1;
#declare Lstr = Ltransform(Axiom, Rules, Iterations);
#declare Vertices = Lvertices(Lstr);
#ifdef (Vertices)
 #debug "OK \n"
#else
 #debug "Undefined! \n"
/*#for(i, 0, dimension_size(Vertices,1)-2) // <== here Povray complains
  cylinder{
    Vertices[i],Vertices[i+1],0.1
    texture{pigment{rgb 1}}
    translate <-25, -5, 0>
    rotate <0, 0, 0>
#end*/
camera{
  location <0,0,-30>
  look_at <0,0,0>
  angle 120
light_source{
  <3000,3000,-3000>
  color rgb 1
Date: 12 Jul 2023 13:15:00
Message: <web.64aedf3b453cebfc17bac71e8ffb8ce3@news.povray.org>
>   #local AngleZZ = 0;
>   #for (i, 0, strlen(Lstr)-1) !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
>         #case(70)
>           #debug "70 F \n"
>         #break
>         #case(43)
>           #debug "43 + \n"
>         #break
>         #case(45)
>           #debug "45 - \n"
>         #break
>         #case(124)
>           #debug "124 | \n"
>         #break
>         #case(91)
>           #debug "91 [ \n"
>         #break
>         #case(93)
>           #debug "93 ] \n"
>         #break
>       #end
>       #end
>     #end
>   #end
>   Vertices
> #end
  try: #for (i, 0, strlen(Lstr)) in the macro. The it runs and renders a small
white stick? But with Iterations = 2 it fails.
ingo
Date: 12 Jul 2023 14:15:00
Message: <web.64aeeca8453cebfc17bac71e8ffb8ce3@news.povray.org>
Try this.
Your pop and push macros didn't return anything.
image looks strange.
ingo
/*Pov-Ray    : 3.8
Date       : 2023-06-04
#version 3.8;
//#declare Curr_Items = 0;
//build rules
 #local AngleZZ = 0;
  AngleZZ + (tau/A_F)
 #local AngleZZ = 0;
  AngleZZ - (tau/A_F)
 #local AngleZZ = 0;
   AngleZZ - (tau/2)
#macro Push(Curr_Item, T_Pos, AngleZZ)
  #debug "push macro runs\n"
  #declare VXY_Arr[Curr_Item] = T_Pos;
  #declare AZZ_Arr[Curr_Item] = AngleZZ;
  #local Curr_Item = Curr_Item + 1;
  Curr_Item
#macro Pop(Curr_Item, T_Pos, AngleZZ)
  #debug "pop macro runs\n"
  #local Curr_Item = Curr_Item - 1;
  #declare T_Pos = VXY_Arr[Curr_Item];
  #declare AngleZZ = AZZ_Arr[Curr_Item];
  Curr_Item
      #local j = 1;
      #while (j <= N)
        #else
        #local j = j + 1;
  Result
  #local AngleZZ = 0;
        #case(70)
          #debug "70 F \n"
        #break
        #case(43)
          #debug "43 + \n"
        #break
        #case(45)
          #debug "45 - \n"
        #break
        #case(124)
          #debug "124 | \n"
        #break
        #case(91)
          #debug "91 [ \n"
          #local Curr_Item = Push(Curr_Item, T_Pos, AngleZZ);
        #break
        #case(93)
          #debug "93 ] \n"
          #local Curr_Item = Pop(Curr_Item, T_Pos, AngleZZ);
        #break
  Vertices
  ["Y"] : "FX-Y"
#declare Iterations = 6;
#ifdef (Vertices)
 #debug "OK \n"
#else
  cylinder{
    rotate <0, 0, 0>
camera{
  location <0,0,-30>
  look_at <0,0,0>
  angle 120
light_source{
  <3000,3000,-3000>
  color rgb 1
Date: 12 Jul 2023 16:10:00
Message: <web.64af07a7453cebfc763e4a273b2af915@news.povray.org>
> Try this.
> ingo
Gee, I didn't want to open a new rabbit hole for you.
I tried your code and yes: the image DOES look strange.
It seems like the whole thing stops after 1 iteration not knowing where to go
next or what to do next.
But at least Povray does not complain anymore.
I suppose you cannot borrow me your 'muse with the glass eye' for a moment or
two just to find out what's wrong with my push and pop macros.
I promise I'm shaven and like to photograph.
See how this thing we are talking about should look like.
Thanks for your patience
Droj
Download 'ls_plants01.png' (363 KB)
Preview of image 'ls_plants01.png'
Date: 13 Jul 2023 00:50:00
Message: <web.64af815b453cebfc17bac71e8ffb8ce3@news.povray.org>
Next thing to do is to debug the stack content and the vertices content.
Where it probably goes wrong:
The first point is added to the array and from then on only the "end points"
(last endpoint is next start point). But when branching you need a new start
point. That gets confusing. It is probably better to write [startpoint,
endpoint] to the array. The loop it with a stride of 2.
ingo
Date: 16 Jul 2023 16:45:00
Message: <web.64b455ce453cebfc80c03e9d6cde94f1@news.povray.org>
hi,
see attached for 'Vertices' content.  something's amiss :-)
regards, jr.
Download 'droj_ingo.png' (13 KB)
Preview of image 'droj_ingo.png'
Message: <web.64b4563c453cebfc80c03e9d6cde94f1@news.povray.org>
hi,
fwiw, I really like(d) 'lsys3'.  made me think that it is v close to a Hilbert
Curve, and it'd be interesting to find the right "production rules" for that.
regards, jr.
Date: 17 Jul 2023 12:15:00
Message: <web.64b566de453cebfcdec7f1e73b2af915@news.povray.org>
> hi,
> regards, jr.
yes indeed looks similar to Hilbert curve. If I remember correctly it's called
Peano curve and here is Hilbert curve.
I saw your screenshot of debugging the stack/vertices content and it looks like
the whole thing loops in itself.
Axiom and production rule(s) look okay but the 'turtle' seems to be stuck in a
tar pit.
At the moment I have no idea how to get rid of the glitch. I tried using a
vector expression for the angles but Povray simply shut down.
regards, Droj
PS: Could you let me know how you debugged the stack getting a list of contents?
Download 'lsys9.pov.txt' (3 KB)
Date: 17 Jul 2023 12:50:00
Message: <web.64b5711c453cebfc80c03e9d6cde94f1@news.povray.org>
hi,
thank you, very much.  (for later tonight :-))
attached the "playing around" copy.  :-)  hth.
regards, jr.
Download 'droj_dbg.pov.txt' (5 KB)
