POV-Ray : Newsgroups : povray.general : I think I found the funky hieght field trouble! Server Time
29 Jun 2025 23:11:09 EDT (-0400)
  I think I found the funky hieght field trouble! (Message 1 to 10 of 10)
Subject: I think I found the funky hieght field trouble!
Date: 21 Mar 2023 15:05:00
Message: <web.6419fc41d69325abb201e5baf712fc00@news.povray.org>
You know the spotted base where the height=0.
I was going through the 3.6 source code and there is:
const DBL HFIELD_OFFSET = 0.001;
This was added and subtracted to the bounding box as well as other things I
haven't chased down.
The point is that if I use a water_line of .001 the spots goes away.
I don't know about other versions. I guess I need to chase them down.
Have Fun!
Subject: Re: I think I found the funky hieght field trouble!
Date: 22 Mar 2023 05:37:57
Message: <641acc75$1@news.povray.org>
> Have Fun!
Thanks for the information.
You're not the only one who's reported strangeness near 0.0 in the
height field. Now a few years back, I came across a blog where someone
was creating height_fields of her home terrain and using POV-Ray renders
to look around. She had trouble when the camera positions got near 0.0
which I'd bet was a near zero bug of some kind too.
I'm aware of that water_level setting, but I've never played with it.
All those buttons and not the time to push them all! :-)
The height_field code is old and due a refresh I expect. Someday...
Since we are talking height_fields! The upcoming version (R7 v0.6.1) of
my povr fork removes the special <=8 bit, red weighted color to grey
scale conversion. No matter the color image channel depth the internal
.grayscale() conversion will get used.
Plus I made indexed images illegal as input. The old code used the index
values in such images to create an equivalent gray level, but only with
256 index values. Further the height, for historical reasons, was muted
in that the max height returned was never more than 0.4% of the full
height_field height.
So! I think, I've eliminated the image based height_field flakiness in
the povr fork. I believe, too, this was the last of the special red
weighted, red+green to grayscale conversion code that was in use.
Bill P.
Date: 23 Mar 2023 17:15:00
Message: <web.641cc093c693303fc2a84cbff712fc00@news.povray.org>
I'm was the same way with function height fields, until lately.
So are we all!
I never use the special <8 bit any way!
 But I have over 400 of those tga palette height field images. When I first
started pov it was dos. And I learned how to make gif images for height fields.
Then I upgraded and made my own tga/ppm win program for 256 and 63556 level
height fields just for pov. I still use tga for quick HF images. Gifs have gone
the way of the dodo. My flavor of ppm is really only good for really short HFs.
 I guess it is time to think of rewriting some new code. Or I can always use
older pov versions.
Have Fun!
Date: 24 Mar 2023 10:03:16
Message: <641dada4$1@news.povray.org>
The odd color to grey code kicked in at <=8 bit image channel depths.
Would you be kind enough to post one example image here? I'm curious as
to the exact format of your tga's.
In any case, my povr fork certainly breaks backward compatibility with
POV-Ray in a great many ways. :-)
Bill P.
Date: 26 Mar 2023 15:40:00
Message: <web.64209ebec693303f125c0c45f712fc00@news.povray.org>
> Bill P.
What I'm kind of proud of is that the palette is special. The blue part of the
each palette element matches that element number. So a pigment function that
outputs blue matches the old standard Height field. I didn't plan on that. When
I set it up  all those years ago I did it that way because it was easier to
code.
Here One that shows the full 256 range
Download 'cratord.tga.tar' (158 KB)
Date: 26 Mar 2023 18:57:44
Message: <6420cde8$1@news.povray.org>
> code.
Thanks! Played with it a while and yep, these exactly the kind that do
work and I've dropped support for them in my povr code... There are many
format variations with tga and I thought you might be using something
else.
The tga indexed input POV-Ray allows, can be 8 bit (256 deep) or 16 bit
(65535 deep). The latter form won't work correctly with the index method
in existing POV-Ray versions. It'll do some sort of wrap.
I looked around quickly for a converter which would convert to another
image format directly from the index values, but had no luck. Something
must exist somewhere I'd guess.
In general our image support is decent, but we don't support everything,
every format can do by any stretch. With povr I don't want to burn my
limited time on this image support work and I have considered dropping
some formats completely. It's just a resource thing. But, I don't know,
maybe there is a way to make use of an external conversion library or
something.
Bill P.
Date: 27 Mar 2023 15:28:17
Message: <6421ee51$1@news.povray.org>
>> part of the
>> function that
>> that. When
>> easier to
>> code.
> format variations with tga and I thought you might be using something else.
> something.
> Bill P.
Remember that 8 bits and less are paletted formats and that 16 or more
are non-paletted.
IIRC, in hight fields, when the image is 24 bits, the red and green
channels are used to to represent the high (green) and low (red) bytes
of a 16 bits value and the blue channel is ignored.
16 bits is often called high colour and 24 and 32 bit are called true
colour.
Date: 27 Mar 2023 17:19:15
Message: <64220853$1@news.povray.org>
> are non-paletted.
This doesn't look to me to be strictly true. It might be 'typically
true' for height_field images in some formats with respect to
traditional POV-Ray usage.
In official POV-Ray releases: "when the color image is <=8 bits per RGB
channel"
And, I too flipped the importance of green and red in one of my earlier
descriptions - probably because green in typical color to gray
conversions matters most to luminosity / the gray level.
It's not how the special (<=8 bit a channel) color to gray conversion in
POV-Ray works where the most weight is in fact given to red.
> colour.
Ah yes! I remember being so excited to finally be working on a true
color display! :-)
My college terminals were teletypes.
I started work years on green and black IBM 3277s - and white and black,
vector displays, I think, IBM 2250s or 3250s. Those latter displays had
light pens you'd bang directly on a heavy glass screen for selection and
movement.
Once you got a lot of vectors up, the refresh rolled across the screen
at a few screen refreshes a second - and selection and movement got
really hard. The heat on our faces and the sound in the terminal rooms
was something else when folks were really cranking.
There were some black and green Tektronix displays in use too for our
graphics. They were nice because they didn't flicker at high densities.
The image was written on a screen sort of like an etch and sketch -
until you refreshed. I cannot, at the moment, remember the models.
My time on another planet...
Bill P.
Date: 12 Apr 2023 23:30:00
Message: <web.643775cec693303f59197626dabc9342@news.povray.org>
> > are non-paletted.
> channel"
> > colour.
> color display! :-)
> movement.
> Bill P.
Wait, are you older than me? ...haha.
I remember those days...out of college before there was computers. :)
But I did have an old vector image setter pre 8088 & post script that used an 8"
Winchester drive... first intro to burning film negatives with machine-coded
light.
Mike...from someone born in the 50's.uggg.
Date: 13 Apr 2023 08:55:21
Message: <6437fbb9$1@news.povray.org>
> I remember those days...out of college before there was computers. 😄
> light.
:-) Well, not if you were born in the 50s. Very early 60s for me.
8in Winchester drives...
Your post reminded me my 'very' first experience with a proper computer
came thanks to the electronics teacher at our High School. He personally
purchased a model 1 TRS 80 and was kind enough to bring it into school
for periods of time. He let some of us to play with it after hours or
during the odd teacher in service day. I remember working hard with a
friend to create our own version of the early mainframe, Dungeons and
Dragons game - all descriptive text. "You are standing in front of a
door..." Cassette tape drive for storage IIRC. Black and white TV for a
display.
Later, built a similar 'personal computer' as one of our class projects
in college. Wire wrapped components on a board with a z80 as the cpu -
power supply, tape interface and such from raw components. Switch
sequences to start the boot up. It also used cassette tapes for storage
and a small TV for the display. Basic as the inbuilt language, but
programmed quite a bit in assembly too - using the switches IIRC - no
assembler program...
Memory is well on foggy though - so might be some of the details are wrong.
Bill P.
