According to:
https://wiki.povray.org/content/Reference:Height_Field
(At the very bottom)
"The height field object also allows for substituting a user defined function
instead of specifying an image. That function can either be in it's literal
form, or it can be a call to a function that you have predeclared. The user
supplied parameters FieldResolution_X and FieldResolution_Y are integer values
that affect the resolution of the color/index values, not size of the unscaled
height field."
There is, of course, no code snippet supplied, so I'm just casting about trying
to get this to work.
Has anyone used this method before?
-BW
Got it to work.
Part of the issue was just the scale and the orthographic camera + camera
position.
Very nice and fast. Isosurface looks better and smoother, but I'm still
playing...
Very interesting !
Could you share the scene, please ? May be I will use this trick in my POV-Lab
"yesbird" <nomail@nomail> wrote:
> Very interesting !
#version 3.8;
global_settings {assumed_gamma 1}
#declare E = 0.00001;
orthographic
location <image_width/2, image_height/2, -image_width*2>
right x*image_width
up y*image_height
//sky y
look_at <image_width/2, image_height/2, 0>
rotate y*0
light_source {<image_width/2, image_height/2, -image_width*4> rgb 1 shadowless}
#declare BWCM = color_map {
[0 rgb 0]
[1 rgb 1]
#declare RGCM = color_map {
[0.0 rgb x]
[0.54 rgb x+y]
[0.54 rgb 0] // black elevation line
[0.55 rgb 0]
[0.55 rgb x+y]
[1.0 rgb y]
height_field {
function 500 500 {pigment {bozo scale 0.1 color_map {BWCM} }}
smooth
pigment {gradient y color_map {RGCM} scale 0.9}
scale image_height/2
translate <image_width/3, image_height/4, 0> rotate -x*80
Subject: Re: Using a function in a height_field declaration
Date: 13 Feb 2023 19:45:48
Message: <63ead9bc$1@news.povray.org>
On 2023-02-13 18:15 (-4), yesbird wrote:
> Very interesting !
Here is an example with a user-defined function:
---------[BEGIN CODE]----------
#version 3.7;
#declare MyFunction = function (x, y)
{ (2 - cos (x * 2*pi) - cos (y * 2*pi)) / 4
height_field
{ function 20, 20 { MyFunction (x, y) }
smooth
translate -<0.5, 0, 0.5>
scale <4, 2, 4>
pigment { green 0.5 }
camera
{ location <-2.913, 2.985, -10.873>
look_at y
angle 26.2648
#default { finish { diffuse 0.6 ambient rgb 0.15005 emission 0 } }
light_source
{ <-5.804, 12.609, -10.054>, rgb 1391125
fade_power 2 fade_distance 0.0098425
spotlight point_at y
radius 38.861 falloff 90 tightness 0.25
box { -1, 1 scale <13, 14, 13> pigment { rgb 1 } }
plane
{ y, 0
pigment { checker rgb 0.05 rgb 1 }
----------[END CODE]-----------
You can also define the function directly inside the height_field statement:
height_field
{ function 20, 20 { (2 - cos (x * 2*pi) - cos (y * 2*pi)) / 4 }
Date: 13 Feb 2023 19:50:01
Message: <63eadab9$1@news.povray.org>
Yes, for the hills in my prefab render rig:
https://github.com/CousinRicky/POV-ShapeOfTheDay
It's in file shapeoftheday.inc
Thanks a lot, very compact and fast method, I'll use it in my project.
Date: 14 Feb 2023 02:12:03
Message: <63eb3443$1@news.povray.org>
Op 13/02/2023 om 20:41 schreef Bald Eagle:
Sure thing. It is the method used in "Journey to an Unknown Region"
landscape. :-)
Date: 14 Feb 2023 05:25:57
Message: <63eb61b5$1@news.povray.org>
> height_field
> smooth
Good example. I always get tripped up when I come back to height_fields
because the function variables used are x and y (to match image based
height_fields I guess) while the generated height field sits atop the
x,z plane with y being the height. I too often first code my function
using x and z!
Bill P.
Another quick example.
#declare Fn02 = function { pattern { granite scale 0.5 } }
#declare Orange = srgb <1,0.50196,0>;
#declare HF00 = height_field {
function 800, 800 { Fn02(x,y,z) }
smooth
pigment { color Orange }
translate <-0.5,0,-0.5>
scale <2,0.05,2>
Do not see anything, except "Black Square" by kazimir Malevich:
#version 3.8;
smooth
scale <2,0.05,2>
camera
{ location <10,10,10>
look_at <0,0,0>
angle 90
light_source
{ <10,10,10>, rgb <1,1,1>
YB
