POV-Ray : Newsgroups : povray.general : Using a function in a height_field declaration Server Time
5 Mar 2026 23:29:12 EST (-0500)
  Using a function in a height_field declaration (Message 49 to 58 of 58)
Subject: Re: Using a function in a height_field declaration
Date: 16 Feb 2023 13:25:00
Message: <web.63ee742243a1dd881f9dae3025979125@news.povray.org>
"yesbird" <nomail@nomail> wrote:
> > I want to thank YOU for introducing a new pigment construction to me:
> >             pigment{red 1.0 green 0.6}
> Always welcome, I don't remember, where I saw it, but this notation is more
> 'human-readable', than others, IMHO. Anyway, we are here to exchange knowledge
> and ideas. Now I'm working on animation of this 'orange'.
> > It seems that even an old-timer like me needs to re-read POV-ray's *basic*
> > documentation, now and then ;-)
> Yes, we should learn onward :)
> YB
I always use x, y, and z for red, green, and blue.   Especially when coloring
axes.
Date: 17 Feb 2023 11:15:00
Message: <web.63efa6c243a1dd88364f434f10800fb2@news.povray.org>
> Looks delicious! I like the wild colors too.
Thanks to your ideas, I've rendered my first POV animation:
https://www.youtube.com/watch?v=i7kItZ6S6cM
Will be thankful for any critical notes and advises.
YB
Download 'fragile.zip' (15 KB)
Date: 18 Feb 2023 10:39:38
Message: <63f0f13a$1@news.povray.org>
On 13/02/2023 20:41, Bald Eagle wrote:
> According to:
> https://wiki.povray.org/content/Reference:Height_Field
> (At the very bottom)
> "The height field object also allows for substituting a user defined function
> instead of specifying an image. That function can either be in it's literal
> form, or it can be a call to a function that you have predeclared. The user
> supplied parameters FieldResolution_X and FieldResolution_Y are integer values
> that affect the resolution of the color/index values, not size of the unscaled
> height field."
> There is, of course, no code snippet supplied, so I'm just casting about trying
> to get this to work.
> Has anyone used this method before?
Yes, but this dates back to ... 2003
Gilles Tran used this in his macro examples of "Cloud Generator"
(<http://www.oyonale.com/modeles.php?lang=en&page=36>).
#declare SeaBase = height_field {
 function Resolution,Resolution {
  (sin(y*pi*5)+1)/3+f_ridged_mf(x*14, y*30,z, 1.2,3,6,1.18,5,1)*0.55/3
// (sin(y*pi*5)*0.5+sin(x*pi*4)*0.5+1)*0.4+f_ridged_mf(x*7, y*15,z,
1.2,3,6,1.18,5,1)*0.54*0.2
  #if (SeaSmoothOK = 1) smooth #end
#declare TerrainBase=height_field{
  f_ridged_mf( x*2, y*2, z,0.6, 3, 6, -1, 3,3 )*0.2
 #if (TerrainSmoothOK=1)
  smooth
 translate -x*0.5
old man's words ;)
Kurtz le pirate
Compagnie de la Banquise
Date: 18 Feb 2023 11:00:00
Message: <web.63f0f5e343a1dd88b3a8a2ec10800fb2@news.povray.org>
> old man's words ;)
Thanks for sharing the link - there are a lot of useful things there.
YB
Date: 19 Feb 2023 01:15:00
Message: <web.63f1bde443a1dd8817bac71e8ffb8ce3@news.povray.org>
at the end of
https://ingoogni.nl/povray/sounds-of-povray/the-sound-of-height-fields/
ingo
Date: 24 Feb 2023 14:25:00
Message: <web.63f90dfc43a1dd889b4924336e066e29@news.povray.org>
> > If you mean that the 'center' of the sine wave circle is
> > not 'at the origin' but at z=1 instead, that could be due to a long-standing
> > problem with how functions are kind of mirror-reversed when used in a
> > height_field...
> BTW: That old problem had strange effects: no only of the z effect of the
> function being reversed to '-z', but also x to -x. It was -- is? --a
> 'double-reversal' mirror effect...with the 'origin' of the function moved to
> z=1, not at <0,0,0>.
Now that I have been playing around again with this function-to-HF mess, I see
that the mirror-reversal flaw is only in z in the created HF, not both x and z
like I had thought for years. This why my 'brute-force' fix works successfully:
     height_field{
     function 500,500{somb(x,y,z)}
     scale <1,1,-1>
     translate <0,0,1>
...as does William P's trick:
            somb(x, (1-y), z)
These two methods seem to be the only *reliable* ways to fix it. I mention this
again because, for years, I had used an IMAGE_MAP-to-function as my 'standard
candle' tester-- and there is yet another way to fix *its* reversal:
#declare somb =
function{
pigment{image_map{--my image--}
scale <1,-1,1>}
So I thought that this 3rd method worked for ALL patterns-- but it does not.
Other pigment/pattern functions show...'varying' results:
ONION does not reverse.
GRADIENT X+Y does reverse, or so it seems.
GRANITE does reverse-- in some way-- but the visual result is not the same as
the two 'reliable' methods. The same goes for HEXAGON.
SPIRAL1/SPIRAL2 appears to reverse in *x*, not z (!)
I would assume that there is some logic to this mish-mash of results, but I
don't yet grasp it.
Date: 24 Feb 2023 14:55:00
Message: <web.63f9160143a1dd889b4924336e066e29@news.povray.org>
> don't yet grasp it.
Hmm. This *could* be due to the <0,0,0> default 'origin' of each pattern being
grossly moved to z=1 in the resulting height_field. In which case, at least
'onion' might BE successfully reversed...but still 'looks' the same there
because the pattern's center has not been moved back to z=0.
I haven't yet compared my other test results to see if this idea holds up re: my
3rd method, for all of the patterns...
Date: 24 Feb 2023 19:05:00
Message: <web.63f94fd243a1dd881f9dae3025979125@news.povray.org>
>      height_field{
>      scale <1,1,-1>
>      translate <0,0,1>
>             somb(x, (1-y), z)
So, as I understand it, your way fixes the problem after the function gets
integrated into the heightfield, and Bill's way reverses the data before it gets
integrated into the heightfield.
I would carefully compare these 2 methods using a non-symmetric function.
Now, considering that there may be other differences when using pigments and
image_maps, I'd again use a non-symmetric pattern or image.  I'd use something
that can easily show a mirroring or rotation around any axis.
Maybe find a pigment that is a nice mathematical function that we can use as
in-built pigment, as a function, using the same equation as in source, and as an
image map that we get by rendering a box with the pigment.   Then we can do more
apple-to-apple comparing.
After we establish a rock-solid starting point, we can further poke around and
see what's what.
> don't yet grasp it.
Yeah - that all does seem weird - I'd make sure you're not chasing ghosts, as
this seems easy enough to do here.
Date: 24 Feb 2023 19:35:00
Message: <web.63f9570d43a1dd889b4924336e066e29@news.povray.org>
Yep, I concur.
I actually used gradient x + .3*y, for the very reason you mention. I also
pre-shifted the hexagon pattern a little.
Yet, it's still difficult to correctly assess the visual results, especially
with patterns like granite and bumps which are kind of 'noisy/randomized' to
begin with.
But I now have a bunch of render tests to compare against each other-- which I
am *triple*-checking this time, ha ;-)  And I have a few more experiments to
run, re: the z 'origin' of the patterns shifting to z=1; I'm hoping that those
results will prove fruitful and perhaps indicate what might be the ONE(?) simple
underlying problem...
Date: 24 Feb 2023 21:10:00
Message: <web.63f96dd843a1dd881f9dae3025979125@news.povray.org>
Well, it's a little 1x1 hf - render a bunch of them all at once, and label them
all with text {} objects, and post it so you can put all the permutations side
by side and have more eyes and minds trying to figure it out.
