POV-Ray : Newsgroups : povray.general : prase error on WinXp Server Time
12 Dec 2025 15:11:44 EST (-0500)
  prase error on WinXp (Message 1 to 3 of 3)
Subject: prase error on WinXp
Date: 4 Jan 2023 14:30:00
Message: <web.63b5d2dde81c0ba21950d6ebf712fc00@news.povray.org>
I ran this with POV3.7 on my Xp 32bit and it crashed half way through
with a cannot parse Error.
#declare Thing=box{-1,1}
#for(i,-2048,2048)
 #for(j,-2048,2048)
   object{Thing pigment{rgb 1} translate <i,j,0> }
That computer has about a gig of memory.
I also used {box{-1,1} pigment{rgb 1} translate <i,j,0> }
 It crashed sooner.
I ran it with POV3.7 on my windows 10 64bit and it ran fine.
This computer has about 8 gig of memory.
which was the most important reason, memory size or bit count?
Subject: Re: prase error on WinXp
Date: 4 Jan 2023 16:27:50
Message: <63b5ef56$1@news.povray.org>
> #for(i,-2048,2048)
>  #for(j,-2048,2048)
>  #end
> #end
> [snip]
You are asking for 16,785,409 objects.  Unfortunately, POV-Ray 3.7 does
not give memory statistics, so I converted your scene to POV-Ray 3.6,
and ran it on my GNU/Linux machine with 1,000,000 objects.  It used
988,560,213 bytes, almost a gigabyte.  So yeah, you would have blown the
memory on the 32-bit computer early on.  My new question is why it even
worked on your 8 gig computer... unless 3.7 stores objects more
efficiently than 3.6?
Memory is certainly the deciding factor in this particular case, but bit
count is an  upstream factor, as a 32-bit machine cannot address more
than 4 gig.
Date: 5 Jan 2023 09:57:06
Message: <63b6e542$1@news.povray.org>
>> #for(i,-2048,2048)
>>   #for(j,-2048,2048)
>>   #end
>> #end
>> [snip]
> than 4 gig.
It worked on an 64 bits 8Gb system thank to virtual memory.
On the 32 bits system, even using the cache, it exceeded the hard 4Gb
limit of adressable memory for a single process.
