POV-Ray : Newsgroups : povray.general : Trying to create a particular object Server Time
13 May 2025 15:40:14 EDT (-0400)
  Trying to create a particular object (Message 1 to 6 of 6)
Subject: Trying to create a particular object
Date: 25 Sep 2019 21:10:01
Message: <web.5d8c0f91b070c22db80758900@news.povray.org>
Hi there. Over the many years of playing with POVray, I have often tried to
recreate things that require a certain object. I want to go from a cylinder to a
cone, but I want it to be tapered in, rather than a straight cut into the angle
of the cone. Sort of like going from cylinder to half-sphere to cone. Does this
make sense? Maybe this helps to picture what I had in mind. Right now I want to
recreate a Navy submarine. The shape of the sub transits smoothly from a
cylinder to ending in a cone shape in the rear, without a sharp change in angle.
Anyone have any suggestions?
Subject: Re: Trying to create a particular object
Date: 26 Sep 2019 06:30:00
Message: <web.5d8c925d97ff03a54eec112d0@news.povray.org>
> make sense?
Convex, concave, or sigmoid (both - one, then the other)?
Spindle of a spindle torus, difference a "horn" torus away from a cylinder
https://en.wikipedia.org/wiki/Torus
non-linearly scaled sphere,
http://www.econym.demon.co.uk/isotut/substitute.htm
the lemon
http://wiki.povray.org/content/Reference:Lemon
isosurface,
Do any of these shapes look interesting?
http://www.econym.demon.co.uk/isotut/builtin2.htm  (and subsequent pages)
use intersecting spheres around an axis to make a sort of 3D lemniscate (if
that's not redundant with any of the above...
Date: 26 Sep 2019 06:59:54
Message: <5d8c9a2a$1@news.povray.org>
Op 26/09/2019 om 12:26 schreef Bald Eagle:
>> make sense?
> the lemon
> isosurface,
I would add to that the 'ovus' object from the basic round objects
library in POV-Ray.
[aside]
This is typically a case where the Moray program would come in handy...
[/aside]
Date: 26 Sep 2019 08:35:00
Message: <web.5d8caff297ff03a51b6c6b3a0@news.povray.org>
> of the cone.
In addition to the other suggestions, you could use a lathe object:
http://www.povray.org/documentation/3.7.0/r3_4.html#r3_4_5_1_8
which takes a 2D curve and rotates it around an axis. If you don't fancy
creating the curves by hand, you could use Inkscape (https://inkscape.org/)
which can export curves as POV-Ray splines. These can then be pasted into your
scene files.
Bill
Date: 26 Sep 2019 13:40:06
Message: <web.5d8cf74097ff03a54eec112d0@news.povray.org>
Ah, yes, and the SOR object as well.
Plus there's EP-Spline
https://agalena.nfshost.com/b1/software/epspline-prism-and-lathe-editor/
Date: 27 Sep 2019 12:03:56
Message: <5d8e32ec$1@news.povray.org>
What about a sphere_sweep ?
In some cases, using blobs can be the way to go.
If all else fails, there are bicubic patches and meshes that can be used.
