POV-Ray : Newsgroups : povray.general : looking for a macro to turn an array of points into one of triangles.... Server Time
7 May 2026 10:17:48 EDT (-0400)
  looking for a macro to turn an array of points into one of triangles.... (Message 1 to 4 of 4)
Subject: looking for a macro to turn an array of points into one of triangles....
Date: 6 Dec 2003 13:20:02
Message: <web.3fd21c9aca6ea6d53527d1b40@news.povray.org>
does anyone know of a way to convert an array of points into non-overlapping
series of points, and test the first array for distance to each point; the
three closest points on the first array to a point on the second set become
the vertices of a triangle. however, this will result in a lot of identical
Subject: Re: looking for a macro to turn an array of points into one of triangles....
Date: 6 Dec 2003 14:30:58
Message: <cjameshuff-78A169.14303706122003@netplex.aussie.org>
In article <web.3fd21c9aca6ea6d53527d1b40@news.povray.org>,
Creating a triangle mesh from an unordered set of points is a very
difficult problem. There are ways to do it, but it is still an area of
active research...and simple points do not have enough information to
unambiguously reconstruct the original surface. Doing this in POV script
is probably impractical.
If you have a bit more information about the points, it makes the
problem a lot easier. For instance, if you know they are points of a
height field, it is pretty simple to generate a height field mesh.
http://tag.povray.org/
Date: 6 Dec 2003 14:45:51
Message: <3fd231ef$1@news.povray.org>
The Delaunay triangulation provides a more optimized algorithm for doing
the distance comparison and building the triangles. But as Christopher
pointed, this operation will result in the wanted mesh only if you have
a set of points with certain properties.
I have writen and posted a POV-script delaunay algorithm, but it's a 2D
algo while you need a 3D one. You should be able to find it in
useful in your case, it can point you toward interesting links on the net.
I hope that helps,
JC
Subject: Re: looking for a macro to turn an array of points into one of triangles...=
Date: 10 Dec 2003 14:15:01
Message: <web.3fd770a3fa5134f7403272380@news.povray.org>
>I hope that helps,
them a 0 z-value, since I plan to start off with a flat surface first, then
do transformations from there to get the exact shape I want.... Thanks! =)
