POV-Ray : Newsgroups : povray.general : Adjusting display not 1.333:1 "squishing" image Server Time
29 Jul 2025 06:32:56 EDT (-0400)
  Adjusting display not 1.333:1 "squishing" image (Message 1 to 7 of 7)
Subject: Adjusting display not 1.333:1 "squishing" image
Date: 27 Feb 2003 00:05:04
Message: <web.3e5d9c61467512b2505fccb70@news.povray.org>
I am trying to adjust the display so a sphere I am generating will fit right
inside the display. Basically, I need a 1:1 x:y ratio. However, doing this
squishes my image. I'm sure there is a solution, but I have searched and
not found it.
Valia
Subject: Re: Adjusting display not 1.333:1 "squishing" image
Date: 27 Feb 2003 01:09:48
Message: <3E5DAC77.19F835F2@Rapidnet.com>
Why not render it in 1.33 : 1 and then copy out the area you want using the
select area button in the render window?
Or you could take the image into a graphics app like photoshop and crop it down
to the size you want without squeezing anything.
If however you are set on using pov for everything, try looking under camera
types in the docs.  You may find what you need there.
A.D.B
> not found it.
> Valia
Date: 27 Feb 2003 02:00:16
Message: <web.3e5db6dc56750726505fccb70@news.povray.org>
I am doing an animation, and I can't find a gif animator that will crop
every frame in a set. If I can render to the size i want, then I don't need
to crop every individual image.
Valia
>A.D.B
>> not found it.
>> Valia
Date: 27 Feb 2003 03:05:20
Message: <3e5dc6c0$1@news.povray.org>
In article <web.3e5d9c61467512b2505fccb70@news.povray.org> , "Valia"
> not found it.
In the manual, read section 6.4.1.5.1 Aspect Ratio.
    Thorsten
e-mail: tho### [at] trfde
Date: 27 Feb 2003 03:06:41
Message: <3e5dc711$1@news.povray.org>
Use the right and up vectors from the camera.
right is set to <1.33,0,0> and up <0,1,0>, so
if you just use right <1,0,0> and up <0,1,0> you
can use squared image output and get the correct
ratio.
Tim
Tim Nikias
Email: Tim### [at] gmxde
right
> not found it.
> Valia
Date: 27 Feb 2003 11:00:16
Message: <web.3e5e351256750726b23bff510@news.povray.org>
Apparently, having thought of the words "aspect ratio" would have helped a
lot when looking through the documentation. Danke schoen and thanks.
Valia
>ratio.
>Regards,
>Tim
Date: 27 Feb 2003 11:09:00
Message: <3e5e381c$1@news.povray.org>
Valia,
Try using a camera statement like this:
//<POV-Ray script>
camera {location <0, 1, -100>
            look_at <0,1,0> }}
//</POV-Ray script>
Using this camera syntax, the values of your render size
are automatically used to set the aspect ratio. You can
then use any shape of rectangle and the image will always
be correctly proportioned. Note that the words "image_width"
and "image_height" are POV-Ray keywords and not
not the actual values (ie. not 800 or 600).
Harold
"Valia" <tuc### [at] yahoocom> wrote in message
news:web.3e5d9c61467512b2505fccb70@news.povray.org...
right
> not found it.
> Valia
