On Tue, 23 Mar 2004 21:28:58 -0500, Tyler Eaves wrote:
> Okay, I've got a vector math question for those of you who are good with
> that kinda stuff.....
> Here's the setup. Imagine a spline describing a 3D curve with undulations,
> rather like, say, a roller coaster track. (Indeed, that is exactly what I
> intend to do with it.) I want to be able to translate a point relative to
> the origin 'along' the spline, so that basically the Z-axis at the origin
> would point along the tangent of the spine at the point. Now the tricky
> part. I want to *twist* the spline, with a another 1d spline that
> represents the twist in degrees at any given point.
Well, with some various ideas, I've worked out a way to handle it without
using Spline_Trans. Still not as fast as I'd like, but it works, kinda.
Except that if the track comes back along the -z axis, the banking goes
crazy.
180 turn - problems: http://tylere.com/coaster1.png
90 turn - no problems: http://tylere.com/coaster2.png
270 turn - problem at the 180o point: http://tylere.com/coaster3.png
Here's the code I've hacked up:
#include "transforms.inc"
camera{location <100,60,-100> look_at <100,0,50>}
light_source{<0,200,-400>,1}
plane{y,-25 pigment{rgb <0,1,0>}}
#declare track = spline{
natural_spline
-1, <0,60,-1>
0, <0,60,0>
100, <0,60,100>
200, <50,20,150>
300, <100,5,100>
400, <100,5,-50>
#declare banking = spline{
linear_spline
0,0
100,0
200,-60
300,-70
400, 0
#declare p = -1;
#declare last = transform{rotate <0,0,banking(p).x>
Reorient_Trans(<0,0,1>,vnormalize(track(p+.5)-track(p))) translate track(p)};
#declare s = 0;
#declare p = 0;
#while (p < 400)
#declare vec = vnormalize((track(p+.5)+<0,.01,0>)-track(p));
#declare trans = transform{rotate <0,0,banking(p).x>
Reorient_Trans(<0,0,1>,vnormalize((track(p+.5)+<0,.01,0>)-track(p))) translate
track(p)};
union{
cylinder{vtransform(<-2,-4,0>,trans),vtransform(<-2,-4,0>,last),.25}
cylinder{vtransform(<2,-4,0>,trans),vtransform(<2,-4,0>,last),.25}
cylinder{vtransform(<-2,-4,0>,trans),vtransform(<2,-4,0>,trans),.2}
pigment{rgb <0,0,1>}
#declare s = s + 1;
#if (s > 10)
#declare s = 0;
cylinder{vtransform(<0,-8,0>,trans),
vtransform(<0,-8,0>,trans)-<0,vtransform(<0,-8,0>,trans).y + 25,0>,.5 pigment{rgb 1}}
cone{vtransform(<0,-8,0>,trans),.5, vtransform(<0,-4,0>,trans),.2 pigment{rgb
<0,0,1>}}
#debug concat(str(p,0,0)," - ",str(banking(p).x,0,2),"\n")
#debug concat(str(vec.x,0,1),",",str(vec.y,0,1),",",str(vec.z,0,1),"\n")
#declare last = trans;
#declare p = p + 3;
