POV-Ray : Newsgroups : povray.general : Random thoughts about povray and xml Server Time
7 May 2026 03:47:06 EDT (-0400)
  Random thoughts about povray and xml (Message 1 to 10 of 41)
Subject: Random thoughts about povray and xml
Date: 19 Mar 2004 18:15:39
Message: <Xns94B1A5863FF0DZenZenPsychocom@203.29.75.35>
Okay well, as often happens when I've got a ton of work to get done, I've
come up with a ton of ideas that I probably won't have the opportunity to
implement, completely unrelated to anything I have to do. Fun.
So, I know that there's been much talk about using XML for povray scene
description language, and a lot of sunk in povray purists will have none
of it! Well, I'm sure there's really good reasons for it, but hear me out
anyway. I'd like to share, and I figured I need someone to either tell me
I'm being retarded, or that it's a great idea, or whatever and maybe I'll
be able to move on to some real work!
I've been reading quite a bit about XML, X3D (new vrml), XSLT, and DTD,
all  are very neat technologies, most with a tiny drawback. They're
terrible at handling binary format. Apparently X3D will have 3 versions.
A classic curly bracket version of syntax, an XML compatible syntax, and
a binary syntax, each with it's own advantages. This got me thinking
about povray, of course.
My idea is that it may be possible to implement the same type of idea for
povray.
Suppose a standard XML syntax were established that implemented most or
all of the features of povray SDL, with correct nesting and such and all
that, with its own DTD and everything.
Then, you could use XSLT language to create a converter, which would be
able to translate between standard SDL, and this XML version, easily and
quickly.
now this is the part that's really weird, and very likely dumb:
The DTD for the XML syntax could be used to create a binary version of
the povray language. That is, each opening and closing tag could be
assigned its own byte, or word, and be assembled into sort of a binary
shorthand of the XML syntax.
This by itself brings the advantage of smaller filesizes for huge
datasets like meshes, and such, which at this point uses huge amounts of
data, uneccesarily by storing vector and context information as ascii
characters.
This would also bring the advantages that XML brings, of easy
portability, parsing, and flexibility of presentation, eliminating the
difficulties involved in creating alternative rendering engines for quick
preview of povray scenes.
Suppose then that a patch in povray would allow the automatic translation
between these 3 formats, and the direct parsing of the formats into
internal tokens.
This may bring a number of other advantages that I won't mention here.
Anyways, I'd be interested in hearing why this is a stupid idea.
-Zen
Subject: Re: Random thoughts about povray and xml
Date: 19 Mar 2004 22:59:29
Message: <MPG.1ac56ef08bcbb1779899ed@news.povray.org>
In article <Xns94B1A5863FF0DZenZenPsychocom@203.29.75.35>,
Zen### [at] ZenPsychocom says...
Not sure if it is stupid exactly. However, XML is not a language so much
as a container. You can organize things with it, but nearly all
implementations use a <SCRIPT> block of some sort to provide the 'real'
code that makes all of the stuff work. That block contains all the stuff
that actually provides functions, program control, etc. In other words,
it is still a container, it just happens to contain the code that ties
all the pieces together. If you make it so it does more, then it really
isn't XML anymore.
The other issue is the discussion being done about object oriented
design. XML can provide a 'known' structure, but it contains no
implementation for changing that structure dynamically during use. So,
you could do:
<union>
  <box ...>
  <box ...>
  <sphere ...>
</union>
but not programmatically use if/then or other mechanisms that provide
flow control to selectively remove one of those objects. The XML only
provides the structure and data, not a means to manipulate it. Again, if
you change it to allow this, then it isn't XML anymore. The result would
either end up being nothing more that a drastic redesign of the existing
SDL that adds a lot of extra junk, but with the same function, or if you
stuck to more strict XML standards, you would make it too inflexible to
do even half of what the existing system allows.
XML is useful for what is was designed to do, but for some reason
everyone thinks it is the answer to every problem now. It isn't, nor was
it ever intended to.
void main () {
    call functional_code()
  else
    call crash_windows();
Date: 19 Mar 2004 23:35:21
Message: <Xns94B1DBBA41E8ZenZenPsychocom@203.29.75.35>
Actually, I was thinking along the lines that either the XML version of
the language would either unroll the traditional SDL, so when deriving
XML from from a #while, statement for instance, it would merely run the
while loop to create the XML, so and so times.
Either that, or the conditionals in povray seem like they may be simple
enough to just make them container elements. This wouldn't invalidate it
as XML. it would merely be a way of containing the information relevent
to the scene description.
like for instance
<if value="true">
<box a="1", b="-1"><pigment><color r="1"/></pigment></box>
</if>
As far as I know, this is valid xml, and it would simply be a matter of
interpretation to convert this into the proper scene.
However, I am not suggesting XML as a replacement of SDL, as you say,
the loops and conditionals and programmatic elements are not so easy to
implement in XML. however, XML could possibly be a solution to a very
specific problem POVRAY has..... interoperability with other 3d
programs.
For instance, we no longer have polyray to fall back on for previewing
our scenes before doing a full raytraced render.  The closest thing is
the patched povray with limited openGL support.
If it were possible to unroll povray's "compile time" programmatic
elements into an XML file with some level of automation, conversion to
other formats for preview would be that much easier.
Patrick Elliott <sha### [at] hotmailcom> wrote in
news:MPG.1ac56ef08bcbb1779899ed@news.povray.org:
> much as a container. You can organize things with it, but nearly all
> 'real' code that makes all of the stuff work. That block contains all
> the stuff that actually provides functions, program control, etc. In
> other words, it is still a container, it just happens to contain the
> code that ties all the pieces together. If you make it so it does
> more, then it really isn't XML anymore.
> you could do:
> <union>
>   <box ...>
>   <box ...>
>   <sphere ...>
> </union>
> if you change it to allow this, then it isn't XML anymore. The result
> would either end up being nothing more that a drastic redesign of the
> existing SDL that adds a lot of extra junk, but with the same
> function, or if you stuck to more strict XML standards, you would make
> it too inflexible to do even half of what the existing system allows.
> was it ever intended to.
Date: 20 Mar 2004 04:25:40
Message: <405c0e14@news.povray.org>
In article <Xns94B1A5863FF0DZenZenPsychocom@203.29.75.35> , Breton Slivka
You cannot easily create a converter using XSLT for anything.  Ever seen a
XSLT that converts some simple piece of data contained in XML to PDF?  Just
forget it!  XML/XSLT are a late internet-bubble hype that create bloated,
slow and complex programs in absolutely every place they have ever been
used.  Consequently, every responsible designer and programmer should avoid
this combination like the plague!  They are no good for anything they have
ever been used for.  XHTML is the perfect example - HTML was for everyone to
learn and use.  XHTML needs a fancy editor for the plain user as only
programmers can grasp the strict validation rules it enforces.  Of course,
if you don't want humans to edit your data, it is a waste of resources to
use text as interchange format in the first place.  The frequently cited
easy conversion of XML is just more hype, as it has exactly zero to do with
the problem of data interchange.  It only adds yet another layer of
problems.
Consequently, even the suggestion to use XML is a total waste of time!
    Thorsten
e-mail: tho### [at] trfde
Date: 20 Mar 2004 04:29:09
Message: <405c0ee5@news.povray.org>
In article <Xns94B1DBBA41E8ZenZenPsychocom@203.29.75.35> , Breton Slivka
> programs.
You are confusing chicken and egg here:  POV-Ray is older than almost all
commercial non-CAD 3D render programs you can buy today.  Hence, it is not
that POV-Ray does not interoperate with them, but that they do not
interoperate with POV-Ray! ;-)
    Thorsten
Date: 20 Mar 2004 07:06:15
Message: <405c33b7$1@news.povray.org>
news:Xns94B1A5863FF0DZenZenPsychocom@203.29.75.35...
> of it!
The problem is less purism than the fact that the benefits of XML for
POV-Ray hand-coded scene development aren't exactly obvious while I wouldn't
rank the other (very theoretical) benefits as a top priority.
In any case, YafRay is a new free raytracer that uses XML for scene coding
(usually in combination with Blender). You may want to have a look and see
how it works.
http://www.coala.uniovi.es/~jandro/noname/
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 20 Mar 2004 11:28:43
Message: <pan.2004.03.20.16.30.33.653544@NOSPAMml1.net>
> of it!
Look at a file for yaf-ray sometime, it's XML based. You'll see why it's a
bad idea.
For the sake of convience, here is an example file for the yaf-ray docs:
<scene>
<shader type = "generic" name = "Default">
        <attributes>
                <color r="0.750000" g="0.750000" b="0.800000" />
                <specular r="0.000000" g="0.000000" b="0.000000" />
                <reflected r="0.000000" g="0.000000" b="0.000000" />
                <transmitted r="0.000000" g="0.000000" b="0.000000" />
        </attributes>
</shader>
<transform
m00 = "8.532125" m01 = "0.000000" m02 = "0.000000" m03 = "0.000000"
m10 = "0.000000" m11 = "8.532125" m12 = "0.000000" m13 = "0.000000"
m20 = "0.000000" m21 = "0.000000" m22 = "8.532125" m23 = "0.000000"
m30 = "0.000000" m31 = "0.000000" m32 = "0.000000" m33 = "1.000000"
<object name = "Plane" shader_name = "Default" >
        <attributes>
        </attributes>
                <mesh>
                <include file = ".\Meshes\Plane.xml" />
                </mesh>
</object>
</transform>
<light type="pathlight" name="path" power= "1.000000" depth "2" samples = "16" use_QMC
= "on" cache"on"  cache_size="0.008000"  angle_threshold="0.200000"
shadow_threshold="0.200000" >
</light>
<camera name="Camera" resx="1024" resy="576" focal="1.015937" >
        <from x="0.323759" y="-7.701275" z="2.818493" />
        <to x="0.318982" y="-6.717273" z="2.640400" />
        <up x="0.323330" y="-7.523182" z="3.802506" />
</camera>
<filter type="dof" name="dof" focus = "7.97854234329" near_blur "10.000000" far_blur
"10.000000" scale "2.000000">
</filter>
<filter type"antinoise" name"Anti Noise" radius = "1.000000" max_delta = "0.100000">
</filter>
<background type = "HDRI" name = "envhdri" exposure_adjust = "1">
        <filename value = "Filename.HDR" />
</background>
<render camera_name = "Camera" AA_passes = "2" AA_minsamples = "2" AA_pixelwidth =
"1.500000" AA_threshold = "0.040000"
        raydepth = "5" bias = "0.300000" indirect_samples = "1" gamma = "1.000000"
exposure = "0.000000" background_name"envhdri" >
        <outfile value="butterfly2.tga"/>
        <save_alpha value="on"/>
</render>
</scene>
Date: 20 Mar 2004 13:52:16
Message: <cjameshuff-DF698E.13522620032004@news.povray.org>
> of it!
It isn't purism, it's pragmatism...try to imagine what it would be like
to code scenes in XML. Or to read scenes coded in XML. It's a terrible
language for human editing, and not a very good one for machines.
Okay...now you have a much less readable, much longer form of the same
scene. Now what?
You could just as well create a binary version of the script itself. Or
better, create a binary scene format...a straight binary representation
of a script would still be wasteful of space.
> characters.
I agree that a binary format would be useful for things like large
models. XML is hardly a space-saver, though, and is not needed as an
intermediate step between POV script and a binary file.
But it doesn't do that. Another rendering engine will still need to know
what data is there, and it can't do anything with data that isn't there.
XML doesn't fix this. You end up with another subsystem in POV Ray that
doesn't really do anything but take up developer time and confuse users.
http://tag.povray.org/
Date: 20 Mar 2004 14:04:53
Message: <cjameshuff-EE45D7.14050220032004@news.povray.org>
In article <Xns94B1DBBA41E8ZenZenPsychocom@203.29.75.35>,
> <if value="true">
> </if>
It'd be a bit more complex than that. Maybe something like:
<if>
    <condition>
        <equal>
            <lhs><varref identifier="foo"></lhs>
            <rhs><boolean value="true"></rhs>
        </equal>
or maybe:
        <compare type=equal lhs="foo" rhs="true">
    </condition>
    <then>
        <box x1="1" y1="1" z1="1" x2="-1" y2="-1" z2="-1">
            <plainpigment red="1"/>
        </box>
    </then>
</if>
This would be equivalent to:
#if(foo = true)
    box {< 1, 1, 1>, <-1,-1,-1>
        pigment {color red 1}
Date: 20 Mar 2004 14:57:47
Message: <MPG.1ac64ffb580d95fe9899ee@news.povray.org>
In article <cjameshuff-EE45D7.14050220032004@news.povray.org>,
cja### [at] earthlinknet says...
> > <if value="true">
> > </if>
> <if>
>     <condition>
>         <equal>
>         </equal>
> or maybe:
>     </condition>
>     <then>
>         </box>
>     </then>
> </if>
> #if(foo = true)
> #end
Yep. All you really accomplish is replacing a slightly more obscured
syntax with one that is simpler to read, but takes up more space and more
time to parse. It doesn't really improve matters to fiddle with XML.
void main () {
  else
