POV-Ray : Newsgroups : povray.general : media+normal Server Time
18 Aug 2025 15:27:43 EDT (-0400)
  media+normal (Message 1 to 2 of 2)
Subject: media+normal
Date: 9 Mar 2003 08:10:43
Message: <Xns9339909D22085raf256com@204.213.191.226>
<manual>
6.11.11.2.12  Normal and Radiosity
Radiosity estimation can be affected by normals. To enable this feature,
add normal on to the radiosity{} block. The default is off
</manual>
In with way normals do affect radiosity? Where can I find more detailed
explanation of how some options/algorithms work (how they work in phisics
model, and how they are computed by Pov) - apart from source code?
Subject: Re: media+normal
Date: 9 Mar 2003 08:14:18
Message: <3e6b3e2a@news.povray.org>
  By default the normal modifier is not taken into account when
calculating the illumantion of a surface caused by radiosity samples.
This means that if you have a surface (not illuminated directly by
any light source) with a normal modifier, it won't show any (it will
be flat, as if it didn't have any normal modifier).
  By turning this option on, you can make POV-Ray to take the normal
modifier into account. (The reason why it's off by default is because
it slows down the rendering.)
