POV-Ray : Newsgroups : povray.general : elastic cube Server Time
16 Aug 2025 17:18:32 EDT (-0400)
  elastic cube (Message 1 to 10 of 11)
Subject: elastic cube
Date: 1 Apr 2002 10:43:50
Message: <Xns91E3B441CD252gergelyvamoraviaitco@204.213.191.226>
I've made an elastic cube (a cubic grid of spheres connected with springs).
I've posted a version of the source to povray.binaries.scene-files. It
basicly shows an animation of the cube falling down on a surface.
Unfortunately, the thing itself has serious "bugs". In the animation you'll
see that the springs seem to "lose strength", which seems unnatural.
(Render the scene and you'll see what I mean.)
Another, more serious bug is that if you rotate the cube before dropping
it, it simply falls apart after hitting the surface. (A somewhat similar
problem arises if you try to "pull away" one of spheres.)
Right now I don't really know the cause of these problems. Please help.
Gergely
Subject: Re: elastic cube
Date: 1 Apr 2002 10:45:59
Message: <Xns91E3B49FB360Bgergelyvamoraviaitco@204.213.191.226>
Gergely Vandor <ger### [at] moravia-itcom> wrote in
news:Xns### [at] 204213191226:
<snip>
Oh, I hope you won't tell me that someone has already done the exact same
thing much better. :)
Gergely
Date: 2 Apr 2002 03:04:48
Message: <k3jhauouekul0fja6lbmi892rcp96ipmop@4ax.com>
On 1 Apr 2002 10:45:59 -0500, Gergely Vandor
Err... quite a lot of people, actually :)
Peter Popov ICQ : 15002700
Date: 2 Apr 2002 15:59:21
Message: <Xns91E4E9BE78884gergelyvamoraviaitco@204.213.191.226>
Peter Popov <pet### [at] vipbg> wrote in
news:k3jhauouekul0fja6lbmi892rcp96ipmop@4ax.com:
>>same thing much better. :)
My search engines seem to fail me this time. :) Could you please point me
to some post/website about spring systems/elastic objects etc. made with
povray? I've found only a couple of posts about springs here, and no
animations or source.
Gergely
Date: 2 Apr 2002 16:12:48
Message: <3caa1ed0$1@news.povray.org>
I don't know if this is helpful but:
    http://www.darwin3d.com/gdm1999.htm#gdm0499
has some applications and the full c source code for this sort of thing.
There's a cloth mesh made of springs and I think the particle dynamics one
is similar as well.
jim
"Gergely Vandor" <ger### [at] moravia-itcom> wrote in message
> Gergely
Date: 2 Apr 2002 17:23:48
Message: <Xns91E53ECA8BB8gergelyvamoraviaitco@204.213.191.226>
"jimbobjim" <jim### [at] blueyondercouk> wrote in
news:3caa1ed0$1@news.povray.org:
> thing. There's a cloth mesh made of springs and I think the particle
> dynamics one is similar as well.
> jim
This is simply great. :)
Though not PoV-Ray related, it gives some very useful general info about
spring systems, not to mention the cool apps.
Big thanks, jim! :)
Gergely
Date: 2 Apr 2002 20:13:04
Message: <3caa5720$1@news.povray.org>
Check my clothing experiments at http://geitenkaas.dns2go.com/experiments/.
Those sheets are exactly what you're talking about: just a bunch of
particles, interconnected with lots of springs.
I'm working on a new version (on and off, I'm a bit busy nowadays) that is
capable of cloth/jelly/spunge interaction with csg objects (union,
difference, merge, box, sphere, torus, cone, cylinder, and maybe maybe
triangle mesh or even blob).
Apache
apa### [at] yahoocom
Date: 2 Apr 2002 21:33:35
Message: <Xns91E52E466486gergelyvamoraviaitco@204.213.191.226>
"Apache" <apa### [at] yahoocom> wrote in
news:3caa5720$1@news.povray.org:
> http://geitenkaas.dns2go.com/experiments/. Those sheets are exactly
> what you're talking about: just a bunch of particles, interconnected
> with lots of springs. I'm working on a new version (on and off, I'm a
> bit busy nowadays) that is capable of cloth/jelly/spunge interaction
> with csg objects (union, difference, merge, box, sphere, torus, cone,
> cylinder, and maybe maybe triangle mesh or even blob).
Pretty cool, is the source available? :)
Meanwhile it seems I've found the basic problems with my springs. Here's a
basic anim. The springs are pretty stiff this time, so it behaves almost
like a solid cube.
http://www.progressive.hu/gero/drum.m1v
Gergely
Date: 2 Apr 2002 21:40:02
Message: <3caa6b82$1@news.povray.org>
I wrote the thing in C, although I started in in pov-ray script. But that's
too slow for this kind of mathematically heavy duty stuff. Especially with
spring objects containing 300x300=90000 particles with even more springs....
And I absolutely love your simple animation, because the movement is really
realistic IMHO.
Apache
Date: 3 Apr 2002 09:46:47
Message: <3CAB15D8.45A3E54E@gmx.de>
The obvious solution is doing it as a Povray patch.  You have the
adventages of fast compiled code and have access to the internal shapes.
Last updated 18 Mar. 2002 _____./\/^>_*_<^\/\.______
