POV-Ray : Newsgroups : povray.general : Posting exes a problem for some clients? Server Time
26 May 2026 00:18:26 EDT (-0400)
  Posting exes a problem for some clients? (Message 1 to 4 of 4)
Subject: Posting exes a problem for some clients?
Date: 25 Mar 2025 10:11:39
Message: <67e2b99b$1@news.povray.org>
I have been using, or trying to use, thunderbird, and more recently
betterbird to read the posts from this server for a while. Recently I
have run into cases of it just crashing out on me within seconds of
clicking on a post. I finally figured out what "one" of them at least
had that was different - it contained not a sensible "zip" file, or the
like, but an actual EXE. Not sure why this is the case, other than that
maybe the "preview" functionality for showing things in-message, is
somehow trying to "show", i.e., run these things, and the client is
going, "Nope!", and crashing. But.. I have to wonder, having noted this
case, if somehow this is what is taking place.
In any case, I would recommend, just for sanity sake, if these where
zipped anyway. And, maybe, if its just me, or if others might be having
the same issue, this would also resolve crashes.
Its annoying when a crash does happen, because the client "forgets"
everything you did that session for me. As in, it reverts back, not to
the point just before the message you clicked that caused it, but to
before you even started reading any from the server at all. This makes
pinning down both a) what is causing it, and b) why, and even c) which
message. I just got real lucky this time, since the one that caused to
thing to blow up happened to be both clearly labelled as a new utility,
and I got a brief flash of the message, just before things went boom, so
knew what to look for. :(
Commander Vimes: "You take a bunch of people who don't seem any
different from you and me, but when you add them all together you get
this sort of huge raving maniac with national borders and an anthem."
Subject: Re: Posting exes a problem for some clients?
Date: 25 Mar 2025 10:30:00
Message: <web.67e2bcd9af743781721a48e56cde94f1@news.povray.org>
hi,
> clicking on a post. ...
use the "other" interface to read ?
<https://news.povray.org/digest/allmessages/>
regards, jr.
Date: 25 Mar 2025 13:37:19
Message: <67e2e9cf$1@news.povray.org>
Strange. I also use Thunderbird and I've never had this kind of crash.
This is the macOS 128.7.1esr (64-bit) version.
Clearly, posting “.exe” directly is dangerous and should not be done.
But from that to crashing the software...
Do you have a reference to a message containing an exe so that I can
redo a test and see what happens?
kurtz le pirate
compagnie de la banquise
Date: 27 Mar 2025 04:20:33
Message: <67e50a51$1@news.povray.org>
Op 25/03/2025 om 15:11 schreef Patrick Elliott:
For the record, using Win11, I have been using Thunderbird for ages to
read the POV ng's and never had any crashes with .exe files included in
a message. So this seems to be a particular/special case? just my two
eurocents...
