POV-Ray : Newsgroups : povray.general : Request for Comments: Quadratic Bezier Splines Server Time
17 May 2024 18:54:20 EDT (-0400)
  Request for Comments: Quadratic Bezier Splines (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Request for Comments: Quadratic Bezier Splines
Date: 6 Jun 2021 19:16:52
Message: <60bd5764$1@news.povray.org>
I just wanted to point out that there seems to be something wrong with
the web interface.
I just posted this, and when I went to read it, it was corrupted.   But
the strange thing is, the post looks FINE when I open it in Thunderbird.
So it's getting written properly, but read/displayed improperly.
Here's what it looks like in the web interface, for anyone reading with
Thunderbird:
thoughts:
used in fonts/typfaces and svg representations of glyphs.  Cousin Ricky
was nice
enough to provide me with an early release of his sphere sweep macro
that allows
QBS.
degree.
So, you may not have to code a whole separate section for QBS - just
write an
algorithm to degree-elevate a QBS to a cubic.  I have my SDL version
that you
can have to adapt into suitable c++ source code.
IIRC degree reduction was a bit trickier, and I hadn't implemented that.
maybe he already has something to do that side of the degree manipulation.
What would be very nice would be a generic "bezier" keyword followed by the
desired degree, or perhaps, by the degree of the supplied control points
followed by the desired degree after elevation / reduction.
But that is JUST something to think about, before anything becomes
"concrete".
Does that help?  :D
Date: 6 Jun 2021 20:10:45
Message: <60bd6405$1@news.povray.org>
Am 07.06.2021 um 01:16 schrieb Bald Eagle:
> the web interface.
Yes, it looks like the web interface mangles anything with non-ASCII
characters. Such as in Mr. Bezier's properly-spelled name.
Date: 6 Jun 2021 20:24:23
Message: <60bd6737$1@news.povray.org>
Am 07.06.2021 um 00:40 schrieb Bald Eagle:
> used in fonts/typfaces and svg representations of glyphs.  Cousin Ricky was nice
> enough to provide me with an early release of his sphere sweep macro that allows
> QBS.
> degree.
> So, you may not have to code a whole separate section for QBS - just write an
> algorithm to degree-elevate a QBS to a cubic.  I have my SDL version that you
As a matter of fact, fonts is exactly the topic I'm implementing this
for in the first place, because I'm working on throwing out our
dedicated `text` shape rendering code and replacing it with `prism`
under the hood.
And yes, so far I have been using degree-elevation to map conic outlines
to cubic ones as already supported by `prism`.
But this turns out to come at the cost of slower render times, and I
have a hunch that's because TrueType fonts exclusively use conic (or
linear) outline segments, so by adding native support for conic bezier
outlines I hope to regain some of the lost performance.
Date: 6 Jun 2021 22:00:00
Message: <web.60bd7d7984e2d21b1f9dae3025979125@news.povray.org>
> under the hood.
Very nice.  I recall that was one of the things on your list.  Maybe the visual
quality of the fonts will improve with the new implementation.
Of course you have.  :D
Your toolbox of coding stuff must be astonishing to behold.
So, it hit me - while trying to get to sleep, of course - that something useful
would be to have an outline-only version of the text object - that traces out
the ttf outlines without filling them in like a prism would do.  I know a lot of
people have played with various font projects, and this would save a lot of work
in achieving the end-results.
keyword could be outline_text or text2 or something.
I don't know if daisy-chaining the spline with a sphere sweep would be the way
to go, or maybe if there's some way to take the font segment data and make it
visible to the SDL in the form of an array or something.  I've seen some very
nice technical drawings when I was researching working with the splines and font
data, and I think that such a an additional low-level tool would be attractive
to folks who work with typefaces and might want to make technical drawings,
presentations explaining how fonts are drawn, etc.
http://www.mathisintheair.org/wp/wp-content/uploads/2015/03/G-45-90_5373.gif
It would also be a very nice way to have the font data at one's fingertips in
case a user wanted to make small edits to the coordinates, or anything else
requiring the actual font data.
I'm not sure how much of your work would cross over into making SVG a useable
format, but maybe that's something to keep in mind and at least plop a juicy
comment into the source code.  ;)
Date: 6 Jun 2021 22:24:22
Message: <60bd8356$1@news.povray.org>
Am 07.06.2021 um 03:59 schrieb Bald Eagle:
Well, that didn't go as planned...
As it turns out, converting conic-outline fonts straight to 2nd order
Bezier `prism`s (amended to provide direct support) is actually slower.
My hunch is that it results in poorer bounding, because elevating the
order also "tightens" the control points, and I suspect the `prism`
bounding computations just plain braindeadly bound to the convex hull of
the control points.
So there might still be potential there, but not the low-hanging fruit I
was hopong for.
Also, turns out that the loss of performance was just empty prisms I
created for whitespace characters. Which is of course dumb. Now that
I've fixed that, rendering of text actually seems to be faster than ever
before.
Oh, there's plenty of potential there for such things indeed.
One day, one fine morning, all the spline-related features will be
combined into one glorious unified system, and text will just be another
source of splines.
Date: 7 Jun 2021 05:36:31
Message: <XnsAD42761851048seed7@news.povray.org>
in news:60bd43a2$1@news.povray.org clipka wrote:
> Thoughts, anyone?
as it is clear that it is a spline, or curve, bezier2, bezier3
A few minutes ago in http://news.povray.org/povray.binaries.scene-
files/message/%3CXnsAD427355E3A62seed7%40news.povray.org%3E/#%
3CXnsAD427355E3A62seed7%40news.povray.org%3E I posted a new version of a
curvers / splines include file. I think the concept would make a nice
addition to POV-Ray if implemented in C++ (that I sadly don't speak) as a
substitute/addition to the current splines.
https://ingoogni.nl
Date: 7 Jun 2021 08:33:55
Message: <60be1233$1@news.povray.org>
On 2021-06-06 5:52 PM (-4), clipka wrote:
> For certain technical reasons, I may need to add support for _quadratic_
> Bezier splines at the render engine level as well, but it would be a
> waste to not expose them to the scene description language (and, while
> I'm at it, possibly also extend `lathe` accordingly).
> An open question is, what keyword should be used for this type of spline?
> - `quadratic_spline` is already in use for some quirky flavor of
> quadratic spline that, in my mind, doesn't even deserve to live, [snip]
I'm inclined to agree with you there.  And I will speculate that Bald
Eagle also agrees.
> Here are some ideas:
> - `quadratic_bezier_spline`, being the most accurate term.
> - `conic_bezier_spline`, being a bit shorter.
> - `conic_spline`, being yet shorter.
> - `bezier2_spline`, the "2" referring to the polynomial order.
For what it's worth, when I implemented the quadratic Bezier sphere
sweep in the Object Collection, I used the name SSWP_BEZIER2_SPLINE to
select that spline type.  So of course I'm biased in favor of the last
option.
Date: 7 Jun 2021 10:54:41
Message: <XnsAD42AC07BF9DEseed7@news.povray.org>
actually, it is a curve, not a spline ;)
https://ingoogni.nl
Date: 7 Jun 2021 10:54:46
Message: <60be3336$1@news.povray.org>
On 6/6/2021 5:52 PM, clipka wrote:
> - Quadratic splines are also occasionally referred to as "conic splines"
> or "conic arcs", for reasons I'm not entirely sure of.
IIRC, quadratic splines are parabolic segments or arcs, which are also
conic sections.
Mike
Date: 7 Jun 2021 13:16:26
Message: <60be546a$1@news.povray.org>
Am 07.06.2021 um 16:54 schrieb ingo:
That very much depends on the context you're using the word in. It has
different definitions in computer graphics, mathematics and traditional
shipbuilding.
The mathematical definition is certainly the one with can lay the least
claim to the term. Because what they call splines actually started out
as nothing more than a mathematical framework invented to _describe_
_proper_ splines. The "function of a variable" is something the
mathematicians bolted on to a pre-existing concept.
In all other fields that don't define "spline" as a physical tool, a
"spline" _is_ the very thing that a mathematician might call a "spline
curve". Or whatever they tend to call it.
