POV-Ray : Newsgroups : povray.general : Output File Caching Server Time
25 Mar 2026 00:45:31 EDT (-0400)
  Output File Caching (Message 1 to 10 of 14)
Subject: Output File Caching
Date: 6 May 2021 03:36:11
Message: <XnsAD2261AC0EB58seed7@news.povray.org>
One question and one remark,
https://www.povray.org/beta/
in "Changes between 3.7.beta.RC2 and 3.7.RC3"
describes the output file caching mechanism.
- I may have missed it or have old docs, but it seems nothing of this is
in the documentation. The "File Output Options" section may be a good
spot.
- Is it possible to write the .pov-state file to a different location than
the current dir? Ramdisc?
Ingo
Subject: Re: Output File Caching
Date: 6 May 2021 03:55:00
Message: <web.6093a03922f25cb879819d986cde94f1@news.povray.org>
hi,
yes.  my '/tmp/' lives in memory and I use:
  $povray foo.pov +o/tmp/foo
or 'output_file_name' in an .ini.
regards, jr.
Date: 6 May 2021 06:37:52
Message: <XnsAD22807CD7724seed7@news.povray.org>
But that means you also have the final image in ram?
Ingo
Date: 6 May 2021 07:30:00
Message: <web.6093d2c022f25cb879819d986cde94f1@news.povray.org>
hi,
yes.  (and, depending, run the final render w/out a directory)  afaik there's no
mechanism for dealing only with the state file; something like "PreferredTmpPath
= ..." would be a nice feature to have in 'povray.conf'.
regards, jr.
Date: 6 May 2021 07:35:07
Message: <6093d46b$1@news.povray.org>
> Ingo
https://wiki.povray.org/content/Reference:General_Output_Options#Max_Image_Buffer_Memory
set it to zero?
https://wiki.povray.org/content/Reference:General_Output_Options#Resuming_Options
i use -C when i don't care about state file
Date: 6 May 2021 07:35:57
Message: <6093d49d$1@news.povray.org>
The final written image too, yes. I like Ingo typically work on ram
disk. Everything is faster - if you have the ram for what you are doing
- and you bang on your physical disk(s) a lot less.
I hope Jérôme will double check me here, but there are two types of file
'disk caching' in play.
An image buffer which is already in ram up to some size (200mb?) which
can be set larger by option. The image file ends up on disk in one go at
the end being written from that image buffer.
We have too the continuation state file which I believe is indeed always
on disk (unless your disk is a ramdisk). Partly, I suspect it's because
this file is harder to cache in structure. It's software, so yeah,
expect it could be maintained in ram. It would be another large file in
memory and for those with limited ram (Raspberry PIs for example) this
starts to become an issue if you always do it.
An issue with v3.7 is the continue trace cannot be turned off (-cc /
Create_Continue_Trace_Log=no). This was one of the first things added to
v3.7+ after v3.7 was released. Would caching that file matter as much if
you could just turn off the state caching altogether as you can in v3.8?
I second your thought not enough detail about the caching got into the
documentation. At least, I've never run across it - those beta change
notes are there, but that is not where most will look for documentation
of the output file caching.
Bill P.
Date: 6 May 2021 07:37:53
Message: <6093d511$1@news.povray.org>
i do not... y'all were just looking in the wrong place
Date: 6 May 2021 07:42:21
Message: <6093d61d$1@news.povray.org>
>> Ingo
> set it to zero?
-cc
Date: 6 May 2021 07:51:57
Message: <6093d85d$1@news.povray.org>
>> documentation of the output file caching.
Perhaps we do disagree. :-) I was aware of the documentation to which
you pointed us.
I believe our documentation would be better if somewhere it included
everything in those beta release notes about output file caching - after
the first paragraph. Those realease notes are well written and clear
with several useful tips. I believe our documentation today describes
switches with not enough about implications and use - information in
those release to release notes.
(And yes, I meant jr where I wrote Ingo...)
Bill P.
Date: 6 May 2021 08:08:47
Message: <6093dc4f$1@news.povray.org>
>>> the documentation. At least, I've never run across it - those beta
>>> change notes are there, but that is not where most will look for
> you pointed us.
isn't that covered in changes.txt and / or revision.txt
