POV-Ray : Newsgroups : povray.general : Mesh Subdivision? Server Time
6 Nov 2026 20:11:33 EST (-0500)
  Mesh Subdivision? (Message 1 to 13 of 13)
Subject: Mesh Subdivision?
Date: 14 Aug 2007 12:19:59
Message: <46c1d62f$1@news.povray.org>
Hello,
I'm working on visualizing some simulation data with POVRay. Since what
I'm dealing with is a set of 3D finite-element meshes, it looks like the
best method is to convert the surface of my mesh into a POVRay mesh of
smooth triangles and go from there. What I've done is split the
quadrilaterals I have into triangles and compute normal vectors with a
bunch of cross products. This works OK, but it has some problems, such
as the shadow line artifact. Also, I don't see any easy way to
distribute a range of colors on the surface of the mesh to represent a
variable (ie, pressure or velocity magnitude).
What (I think) I'd like to do is split the elements of my mesh into many
more elements and smooth it out. I've found a few sets of macros and
things for doing this, like the "New Surface Subdivision Suite" (
http://www.geocities.com/evilsnack/nsss.htm ) and "POV-Ray with
Subdivision". They all seem to be unmaintained, though, or at least very
out of date. Does anyone here have a preferred way of smoothing /
subdividing meshes? Also, is there any experience out there in general
with using POVRay with finite element analysis data? I know that's not
at all what it's designed for, but I think it could be very useful for
generating images for presentations/posters/etc. Thanks,
Jesse
Subject: Re: Mesh Subdivision?
Date: 14 Aug 2007 15:41:13
Message: <46c20559$1@news.povray.org>
> subdividing meshes?
Yes, I use the aforementioned "POV-Ray with Subdivision" It's good for
many things, though it suffers from strange artifacts sometimes. I
mention it because I hope more people will start using it, and then
maybe it will be supported in the new version of POV.
~Sam
Date: 14 Aug 2007 17:50:39
Message: <46c223af$1@news.povray.org>
> Hello,
> Jesse
PoseRay can subdivide meshes and export them to POV code. Load a mesh
and in the groups tab select subdivision and then press update. There
are several options you can play with for different results.
http://mysite.verizon.net/sfg0000/
good luck,
FlyerX
Date: 14 Aug 2007 20:52:05
Message: <46c24e35$1@news.povray.org>
MeshLab can subdivide, cull, re-mesh etc.
(but it's not a modeler)
http://meshlab.sourceforge.net/
Wings3d can subdivide stuff.
http://www.wings3d.com/
And of course you'll need PoseRay
to import stuff.
Date: 15 Aug 2007 11:51:21
Message: <46c320f9$1@news.povray.org>
Thanks for all the advice! I'm leaning towards POV-Ray with Subdivision
right now, mostly because the format conversions look like they'll be a
bit of a pain otherwise. (Too bad there's no source available for
PoseRay; it looks useful but I'd rather not fiddle with Wine at the moment.)
A few last questions for whoever might know: Is it likely that POV-Sub
will make it into the official packages in the future? Also, what's with
the three years without an update to the website/code? (That was what
worried me in the first place.) And finally, if I have color set at each
triangle in a mesh, would POV-Sub do something to interpolate them when
subdividing? (Don't want to get my hopes up, but that would be pretty
great.) Thanks again,
Jesse
Date: 15 Aug 2007 12:03:26
Message: <46c323ce$1@news.povray.org>
> moment.)
I'd like to second that. :-)
William Tracy
afi### [at] gmailcom wtr### [at] calpolyedu
You know you've been raytracing too long when you know how far away a
scene's light source is just by looking at the shadows.
Taps a.k.a. Tapio Vocadlo
Date: 16 Aug 2007 06:10:00
Message: <web.46c4215d95c01edf731f01d10@news.povray.org>
I've never tried it, but if you use a mesh2 object you can texture triangles
or even vertices individually. It looks like you need to put the textures
into a list and reference them by index but it can be done.
http://www.povray.org/documentation/view/3.6.1/293/
Bill
Date: 16 Aug 2007 07:00:35
Message: <46c42e53@news.povray.org>
  Actually you can do that with a mesh too, but it becomes more verbose.
Date: 16 Aug 2007 11:34:03
Message: <46c46e6b$1@news.povray.org>
Ah, I hadn't notice the individual vertex possibility. That's definitely
something I can use. Thanks!
Jesse
Date: 16 Aug 2007 21:39:55
Message: <46c4fc6b$1@news.povray.org>
> out of date.
Jesse,
Last time I tried the NSSS macros they worked very well, so I don't
think that the suite needs much maintenance at the moment.
Here's some images I rendered with NSSS (and some macros of my own):
http://home.online.no/~t-o-k/POV-Ray/Mesh-Moebius_Band.jpg
http://news.povray.org/povray.binaries.images/thread/%3C41450e47%40news.povray.org%3E/
http://news.povray.org/povray.binaries.images/thread/%3C4131f02f%40news.povray.org%3E/
Tor Olav
http://subcube.com
Date: 17 Aug 2007 11:38:42
Message: <46c5c102$1@news.povray.org>
>> out of date.
> Jesse,
OK, thanks. I thought that might be the case. Glad to hear from someone
who's used it. Like you say, it looks like it works pretty well!
Jesse
Date: 17 Aug 2007 16:19:55
Message: <46c602eb@news.povray.org>
>>out of date.
Maintenance happens when the maintainer is told there is a bug.  That
hasn't happened in a while (almost three years), so there's been no need
for updates.
At the moment I am upgrading my modeler to use polygons with more than
four sides, and I'm rewriting my macro suite to go with it.  There will
be an appropriate announcement when it's ready to be seen in public.
John
Date: 20 Aug 2007 15:23:30
Message: <46c9ea32$1@news.povray.org>
>>> out of date.
> for updates.
> Regards,
> John
I've ended up putting my meshes through the NSSS macros, and they're
working great for me. Thanks for quelling my fears about maintenance; it
looks like I spoke too soon in my first post.
Jesse
