POV-Ray : Newsgroups : povray.general : Slightly faster VRand_On/In_Sphere() Server Time
22 Jul 2025 13:55:34 EDT (-0400)
  Slightly faster VRand_On/In_Sphere() (Message 1 to 10 of 30)
Subject: Slightly faster VRand_On/In_Sphere()
Date: 6 Nov 2003 01:56:34
Message: <3fa9f0a2$1@news.povray.org>
The following macro gives an uniform distribution within the sphere{0,1}
and is slightly faster (by 9%) than VRand_In_Sphere() from rand.inc:
#macro VRand_In_Sphere(Stream)
  #local Y = 2*rand(Stream)-1;
  vrotate ( (<sqrt(1-Y*Y),Y,0>*pow(rand(Stream),1/3)), 360*rand(Stream)*y )
And this macro gives an uniform distribution on the surface of the
sphere{0,1}. It's slightly faster than VRand_On_Sphere() from rand.inc:
#macro VRand_On_Sphere(Stream)
  vrotate ( <sqrt(1-Y*Y), Y, 0>, 360*rand(Stream)*y )
I suggest to replace the original rand.inc macros by these macros.
   Sputnik
Subject: Re: Slightly faster VRand_On/In_Sphere()
Date: 6 Nov 2003 09:10:45
Message: <3faa5665$1@news.povray.org>
> <sqrt(1-Y*Y),Y,0>
I think that will cause points to be more dense towards the top and bottom
of the sphere, won't it?
It might be possible to correct it by running Y through some function like
acos() or something, but that would have to be researched.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 6 Nov 2003 13:55:42
Message: <3faa992e@news.povray.org>
Can you mathematically prove that the distribution is even?
Date: 6 Nov 2003 14:52:26
Message: <cjameshuff-4BAFBE.14520006112003@netplex.aussie.org>
In article <3fa9f0a2$1@news.povray.org>,
Hmm, I haven't had time to go over the mathematics, but these look like
they do give even results...
http://tag.povray.org/
Date: 7 Nov 2003 09:56:27
Message: <3fabb29b@news.povray.org>
Well, after understanding the message and going into its math a bit
more, I came to following conclusions.
I think we can agree that if Frank's VRand_On_Sphere is uniform on the
sphere then VRand_In_Sphere is uniform within the sphere.
So I considered VRand_On_Sphere which is a bit easier.
First remark I made is that the repartition is not obviously uniform.  :-)
What seem to happen here is that we have a combination of two
non-uniform transformations that may lead to a uniform repartition.
<sqrt(1-Y*Y), Y, 0> is non uniform in terms of length of the circle,
there will be more points in the middle of the circle and less at the
top and bottom, but then the rotation is not uniform either as it will
spread the points of the top and bottom on smaller surfaces.
The remaining question is : does the one exactly counter the other ?
I haven't answered this one yet, and I would really like to avoid doing
it with my rusty math, isn't any math student around willing to do it ??
There's just a few arcos integrals and stuff like that implied I think.  :-)
JC
> #end
> #end
>    Sputnik
Date: 7 Nov 2003 14:48:46
Message: <3fabf71e@news.povray.org>
Good point. It may very well do so. The <sqrt(1-Y*Y), Y, 0> distribution is
related to the cosine of the angle from the center of the circle to the
point <sqrt(1-Y*Y), Y, 0>. Also, the circumference of the circle which that
point is then randomly placed on is proportional to the cosine of the same
angle. Therefore, it's possible that this VRand_On_Sphere() function does in
fact work properly.
It needs to be worked out formally though.
 - Slime
Date: 7 Nov 2003 15:35:36
Message: <3fac0217@news.povray.org>
Well... I just posted an article until it popped up in my mind that
it was complete nonsense, so I canceled it again (hope that helps...)
Furthermore (as non-native speaker) I mixed up longitude and latitude
again -- @#$%!!!
I had to take pencil and paper and have a closer look:
>> #end
Okay, so the area size on a sphere between latitudes theta1 and theta2
is (where theta is not really the latitude but measured downwards from
the pole):
  integral theta1..theta2 over 2*pi*sin(theta) d(theta)
which is
  area = 2*pi*(cos(theta1)-cos(theta2))
The probability for the vector to be inside that area is:
  P(v in area) = P(cos(theta2)<= y < cos(theta1))
where y=2*rand(Stream)-1, i.e. uniformly distributed, so
  P = ( cos(theta1)-cos(theta2) )/2
Now, if the probability is proportional to the area, the distribution
is uniform. Looking at the formulas, this is evident:
  P/area = 1/(4*pi)
...which is just what we expect and independent of theta1 and theta2.
So I think that it really works.
Cheers,
Wolfgang
Date: 7 Nov 2003 18:58:00
Message: <3fac3188@news.povray.org>
  Well, I think this is not automatic, but needs proof. :)
  (Btw, has anyone proven mathematically that the current official
macros produce even distributions?)
Date: 7 Nov 2003 21:36:47
Message: <3fac56bf$1@news.povray.org>
I am convinced that they do.
Honestly, I'm not sure of the proper mathematical procedures to use when
evaluating a distribution curve. Nonetheless, I understand the logic behind
what causes an uneven distribution and how to go about correcting it; I have
a very good intuition about this sort of thing (IMO at least ;) ) and during
the POV-Ray 3.5 beta I took a good look at the two functions out of
curiosity. I determined, simply by reading the code, that the
VRand_In_Sphere function provided an uneven distribution, because it wasn't
using the pow(..., 1/3) trick to pull things away from the center. I
verified my suspicions, fixed the problem and submitted what is now the
current VRand_In_Sphere function.
Anyway, I've thought long and hard about both functions, and I am absolutely
certain that both of them provide even distributions.
I have been known to be wrong... =)
 - Slime
Date: 8 Nov 2003 04:14:40
Message: <3facb400@news.povray.org>
I think my posting from yesterday proofs it.
The vector is rotated by a random amount around the Y axis, so it
is sufficient to prove that the probability for the vector being
in a certain latitude range is equal to the area covered by it
(divided by 4pi, of course). Now read on in my previous posting.
Wolfgang
